FS: 92 Galant VR4 802/1000 SoCal - $13K
KiNgMaRtY
Corona, CA
Hello everyone. I have been sitting on the fence about selling 802/1000 for some time now. I think it may be time.
Here are the details:
It is #802/1000. I have owned it for nearly the last 14 years and it has spend most of its life garaged. I am the third owner and have taken very good care of her. She runs healthy and handles amazingly. The transmission shifts smoothly. The exterior of I would say is an 7/10 for the age and the leather sunroofed interior is a 7.5/10 for its age. (Driver seat recently tore)
Rust free and no hack jobs.
I commute 70 miles round trip to work and can sit in traffic without any worries.
I can do $12.5K if I sell her with the OEM wheels.
Stock 6 Bolt 212,000
HKS 264/272 Cams
16G Turbo
ETS FMIC
ETS Hot IC Piping
Brodie IC Cold Piping
2g MAF
K&N Air Filter with Dejon tool 2g MAF adapter to 1g OEM Style K&N filter
Injen Intake
Road Race Engineering 3" Custom Turbo Back Stealth Exhaust
Aeremotive FPR
Fuel Filter to Fuel Rail SS line
Walbroh 255
RC 720 Fuel Injectors
12" Biggest Spal Fan
Koyo Double Row Brass Radiator
Greddy Radiator Cap
TMZ Rebuilt Throttle Body - 9/24
FIAV Block off Plate
Ralliart Sparkplug Cover
NGK BPR7ES
Optima Yellow Battery in Trunk
Jack's Transmission Stage 2 HD Rebuild - at 190K ~
Spider Center Differential
Quaife Front LSD
TMZ TZ/FE Clutch
Rebuild Clutch Pedal By Shepard
New Front Axels at 205K~
JNZ Tuning Short Shifter
Shifter Base Derlin Bushings
New OEM Shifter Cables 3/2024
Handling
Ohlins DFV 9K Front / 9K Rear.
Galant Specific BC Front Camber Plate Bases with Ohlins Pillow Ball Mount Plates
3SX Rear Camber Arms
Whiteline Front Strut Tower Bar
Whiteline Rear Strut Tower Bar
Whiteline Front Sway Bar
Whiteline Rear 26mm Adjustable Sway Bar
New Front Control Arms
Refurb Rack & Pinion
Energy Suspension Poly rear control arm bushings
Work XD-9 17x8.5 with 225/45/17
Mods-Exterior
JDM RS Front Bumper
JDM Rear Bumper
Clear Turn Signals
Mods-Interior
MOMO Steering Wheel, Rockford Amplifier, Eclipse and Kicker Speakers, AEM Type-X Gauges AFR, Water, & Boost gauges
Owner since 11/2010+
Cons:
It still needs to be tuned for cams but runs fine. It will sometimes dip low when coming to a stop.
Oil pan leaks a little.
Leather seat ripped earlier this year.
Driver side molting on the top that goes from the A to B pillar snapped. I still have the piece and it will need to be bonded and reclipped.
Driveshaft U-joints will need to be replaced.
Needs AC Recharge/Service
212K on the bottom end.
NanaVr4
New member
Florida
Did you keep the full length of the shift lever for the Jnz short shifter? Would you consider selling that on its own?
KiNgMaRtY
Corona, CA
Stock length in how JNZ sent it. Shifter is awesome.
No, not worth the time and effort to remove it to put in an OEM shifter. Removing the center console isn’t very fun with the seatbelts.
