1991 Galant VR-4
fast af boiiii
#338/2000
Specs
Ownership Status
Currently Own
Year
1991
Production Number
338
Mods-Power
Borg Warner 7670 turbo .83ar
Revhard cast iron exhaust manifold
41mm turbosmart wastegate
6 950cc fic low impedance injectors
Walbro 255 pump(inline 392 pump)
e85
ACT 3200 unsprung 6 puck
Mods-Drivetrain
5 lug conversion
evo 8 rear diff
4 bolt axles
14 gal fuel cell
Mods-Engine
machined factory crank,
.0025 main bearing and rod bearing clearance,
Manley turbo tuff I beam connecting rods,
Arias 8.8-1 pistons,
.230 wall wrist pins,
.020 second ring gap,
.024 top ring gap,
ARP head studs,
stock head,
272 hks cams,
1mm oversized intake and exhaust valves,
Manley single springs and retainers
Mods-EMS/Tuning
ecmlink v3
AEM/cavlico 5 bar map sensor
ebc controlled w/DSMLINK
PLX M300 wideband
Mods-Handling
Subframe connectors
Poly bushings
Rear tubular mustache bar
Adjustable tubular rear control arms
Hotbits suspension 30 way adjustable 400lb front springs
800lb rear springs
Whiteline rear adjustable sway bar
Wilwood 4 piston brakes
17x9 cobra rims
Nitto NT01 255/40/17
Mods-Exterior
none
Mods-Interior
fully gutted with evo 8 front seats
Background/Plans
was a roadrace car. planning on driving it on the street and bringing it back to prime.
Car information
Added by
Young_Dunahoo77
Views
751
Last update
More in 1991-1992 Galant VR-4
