High Idle GGSX
18GVR4
snohomish, wa
I bought a non running GGSX. Swapped the ECU and CAS and it fired up. Drove it around and it runs pretty good. On start up the idle is 2,500. after warm up, it drops down to 1,500. Biss screw all the way in and it will not drop any lower. I blocked off the EGR, checked all the vacuum lines. still 1,500. could the timing be off, or a leak somewhere? Thanks in advance.
strokin4dr
Savannah, GA
"Biss screw all the way in"
Did you ground the timing connector and adjust it correctly, or just screw it in as far as it'd go?
tombaman
rensselaer, in
I had this problem the whole time on my ggsx. Start up idle was about 2200 til it warmed up. Then it would go down slightly. Tried adjusting biss screw correctly. Could never get it right. Either really low stumbling idle or a high idle. No in between. It was really weird.
18GVR4
snohomish, wa
Strokin4dr, I did not have the connectors grounded. I'll try that this afternoon.
Tombaman, did you ever figure it out?
holeshotmoe
VA
Check the wire on the throttle stop switch. If it falls off it will idle high like that, even when warmed up. Notice the blade on this one is short, so the wire falls off easily.
