Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Auto trans AN adapter fitting leaking
Wookalar
ignore this pathetic weasel he's just not worth the time
3/1000
Galant VR-4 org Post #: 1197502 posted 12/28/14 03:11 PM     Remind Me!  Send Private Message   Edit Post
Hey all, I am having some trouble with some AN adapter fittings for auto transmission lines leaking. How on earth do I get these little @!*#!s to seal?
I am thinking that the brass fitting I am screwing the AN adapter into threads have been stretched beyond spec. Maybe I just need new brass master fitting. I am thinking that they install the lines at the factory with pneumatic tools because they were in so darn tight.
OR, the angles on the flared part are not the same on the brass fitting as they are on the AN adapter fitting which is causing fluid to get by. See the photo for reference.
I have tried the permatex sealant and it worked on one but the other is still leaking quite a bit, and I know people say to not use Teflon tape so what does that leave me with?
</font><blockquote><font class="small">Quoting 89Patches:</font><hr />
Brett gstwithpsi is the nut rider!
<hr /></blockquote><font class="pos
Posts: 458 | From: Arizona USSA | Member Since: 11/27/13 | IP: (24.251.4.211) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1197506 posted 12/28/14 03:43 PM     Remind Me!  Send Private Message   Edit Post
There are 2 main flares, JIC (AN for car guys) and SAE. If they are different, that would cause a leak. Also, the brass ones are prone to over tightening, and flaring the threads as you mentioned. You can use teflon tape or paste on the threads of NPT (pipe thread) but not on a flare fitting, as the threads don't seal anything, the taper does. I would try a new brass fitting, and just be a little more careful (read gingerly) tightening it. Could be that simple depending on where it's leaking from. Also, I've had the cheaper aluminum AN fittings split the flare if over tightened, so that's possible as well.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.15.96) | Report this post to a Moderator
Wookalar
3/1000
Galant VR-4 org Post #: 1197515 posted 12/28/14 05:20 PM     Remind Me!  Send Private Message   Edit Post
Much appreciated info, thank you. Here is the adapter fitting I'm using. Hard to tell if the angle is the same. I believe this is an inverted flare, AN on the left, oem piece on the right. Yes I cut that sob off.
The AN flare looks more steep, or maybe it's my imagination.
Spyke169
Member +
Galant VR-4 org Post #: 1197518 posted 12/28/14 05:40 PM     Remind Me!  Send Private Message   Edit Post
JIC comes in both 45 degrees and 37 degrees flare. -AN is basically 37 degree JIC, but tighter machining tolerance. As long as the JIC you are using is 37 degrees you can use it with -AN no problem. If I was you I would take the fitting into a hydraulic shop, If what you are working with isn't correct they will be able to tell you right away, and get you the correct fittings. Or you could try putting a little bit of grease on the flare surface, gently thread it together and apart, if the pitch is different you should get a distinct line in the grease.
'90 Galant GSX, Daily Driver
'93 TSI AWD, Project Car
Sold the VR4s that I have owned, miss them everyday.
Posts: 324 | From: Greenfield, Wi | Member Since: 08/17/05 | IP: (72.128.101.206) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1197521 posted 12/28/14 06:23 PM     Remind Me!  Send Private Message   Edit Post
JIC/AN is 37*, SAE flare is 45* (along with different threads on some sizes) but Spyke is correct AN has tighter thread tolerances. For anything automotive , JIC/AN spec are interchangeable (not the degree of flare), aerospace and NASA etc needs to use the precision AN rated ones. I think inverted flare (I.E. brake and fuel lines etc) are 45* but I could be wrong. I know they make adapters to eliminate the factory fittings that thread into the case, so that would be my suggestion. Eliminate all your adapters etc.
After a quick Google search, looks like you need 12mmx1.25 (one that allow an o-ring or crush washer) to -6 AN. Looks like most online shops (I use JNZ Tuning) have these available.
91 #108/2000- link
09 Hummer H3T
Edited by EMX5636 (12/29/14 08:52 PM)
Wookalar
3/1000
Galant VR-4 org Post #: 1197533 posted 12/28/14 08:01 PM     Remind Me!  Send Private Message   Edit Post
Thank you both for the info and suggestions, I was unaware of what JIC referred to but had read earlier today about the two different angles.
I will bring these two fittings to a local shop and see what they have to say. The main fittings I would like to keep since they are a major pita to remove with the trans in the car. I just need a male fitting with matching angle that adapts to a -6 male flare and I'm in business.
Thanks again.
Galant VR-4 org Post #: 1197560 posted 12/29/14 09:55 AM     Remind Me!  Send Private Message   Edit Post
In general, good responses, but I disagree with the quoted part of this statement. Sealing of flared fittings relies on complete circumferential point contact between fitting halves. For any fluid I would not recommend mixing these (semms small, 8 degrees, but it is significant). Mixing is most likely the reason for his issue in the original post. I would certainly never mix for brake or other pressure lines.
Quoting EMX5636:
JIC/AN is 37*, SAE flare is 45*. For anything automotive, they are interchangeable,
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10745 | From: Michigan | Member Since: 03/05/01 | IP: (76.204.115.93) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1197603 posted 12/29/14 08:50 PM     Remind Me!  Send Private Message   Edit Post
Sorry Iceman, I should have worded that differently. I'll edit, but I meant that JIC and AN spec are interchangeable in our automotive applications, not 37 and 45 degree.
91 #108/2000- link
09 Hummer H3T
dsmless
gay without homosexual tendencies
96/1000
Galant VR-4 org Post #: 1197664 posted 12/30/14 02:22 PM     Remind Me!  Send Private Message   Edit Post
Is that setup on a galant?
96/1000 back in the driveway jsb getting a
lego motor
Posts: 224 | From: tucson,az | Member Since: 06/12/08 | IP: (172.56.41.9) | Report this post to a Moderator
Wookalar
3/1000
Galant VR-4 org Post #: 1197673 posted 12/30/14 03:11 PM     Remind Me!  Send Private Message   Edit Post
No. It's a A340E 4 speed auto on a Lexus.
715/1000
1284/2000
Galant VR-4 org Post #: 1197677 posted 12/30/14 03:29 PM     Remind Me!  Send Private Message   Edit Post
Have you cleaned it off and ran it and watched to see the leak form? Just curious if you've pinpointed the real leak.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Wookalar
3/1000
Galant VR-4 org Post #: 1197694 posted 12/30/14 07:05 PM     Remind Me!  Send Private Message   Edit Post
Yeah, I was under it when someone started it. Actually I think it came loose on me when I installed the hose end fitting to the adapter, so I just used some med Loctite on it today and I will check it in the am.
I spoke to a guy at a local store today and he said the angle is the same on the adapter side as the stock fitting, 45*, and that the AN hose end is the 37*.
Update. The Loctite worked well, no leaks. Basically I just cleaned the threads with parts cleaner and used a bit of med Loctite on the adapter fitting into the brass fitting and let it dry for a few hours. Then I went back and put the hose ends onto the adapter fitting carefully using two wrenches so as not to break free the Loctite seal or overtightening (with a small amount of anti seize to prevent galling/binding damaging the aluminum threads). No leaks today after a test drive.
Edited by Wookalar (01/01/15 07:38 PM)
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.237 seconds in which 0.201 seconds were spent on a total of 14 queries. Turbo powered.
