Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Hydraulic System Failure: Clutch and ACT 2600
alansupra94
Excuse the retarded question.
4/1000
Galant VR-4 org Post #: 970237 posted 02/16/11 09:26 AM     Remind Me!  Send Private Message   Edit Post
Well I was wondering did anyone else have their clutch system fail because the ACT 2600 is so god damn stiff? Last night while driving, the clutch system on my car just gave way. No warning, or leaking. Just stuck to the floor
I have braided lines so I am not sure if that compounded the effect but is there a better replacement option for the master and slave if you have a ACT 2600? I really don't feel like replacing the clutch as besides the heavy pedal, it works really well.
Thanks,
Alan
1992 Galant VR4
1996 Toyota Supra TT
Edited by alansupra94 (02/16/11 07:20 PM)
Posts: 1909 | From: Wayne,NJ | Member Since: 03/03/10 | IP: (173.3.24.20) | Report this post to a Moderator
Street Surgeon
Professor Street Surgeon
501/1000
Galant VR-4 org Post #: 970240 posted 02/16/11 09:32 AM     Remind Me!  Send Private Message   Edit Post
You sure you haven't just snapped your clutch fork in 1/2?
Cory O.
'92 Mitsubishi Galant VR-4 501/1000
Heavily modified, barely driven, some assembly required.
Posts: 941 | From: Omaha, Nebraska | Member Since: 03/03/04 | IP: (131.43.10.25) | Report this post to a Moderator
Muskrat
665/2000
Galant VR-4 org Post #: 970244 posted 02/16/11 10:03 AM     Remind Me!  Send Private Message   Edit Post
What part actually failed?
Brian L.
91 Galant VR-4 #665/2000
Posts: 2105 | From: Lexington, KY | Member Since: 06/13/04 | IP: (63.238.139.239) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 970252 posted 02/16/11 10:43 AM     Remind Me!  Send Private Message   Edit Post
I hate my 2600!! Too stiff, such a thin line for adjustment, puts too much pressure on the whole system... I just replaced master and slave last weekend. Still can't get the carit into gear when the car is on. I will have to try bleeding it some more. If I have to go in there to replace the T/O bearing, don't see what else it can be then I am changing the clutch out to something else.
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (99.32.5.18) | Report this post to a Moderator
dmj
Rod Stewart
998/1000
Galant VR-4 org Post #: 970257 posted 02/16/11 10:51 AM     Remind Me!  Send Private Message   Edit Post
ACT 2600 here as well but not stiff at all .I taught my wife to drive stick shift about a month ago on this clutch and she did not complain. Check for leaks if none look elsewhere in the system, was your clutch pedal rebuilt?
Posts: 673 | From: orlando FL | Member Since: 02/02/08 | IP: (97.100.20.147) | Report this post to a Moderator
chrisfullwood
Member +
Galant VR-4 org Post #: 970258 posted 02/16/11 10:53 AM     Remind Me!  Send Private Message   Edit Post
i have the same setup, although i think i have the 2900lb and it is a really really stiff clutch. I too have had issues with it, but mine was the clutch fork going Ping! at the gas station, snapped that b!tch clean in 2.
i have a really strong left leg though...lol
Posts: 256 | From: bartlesville, ok | Member Since: 04/28/06 | IP: (69.7.176.150) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 970262 posted 02/16/11 11:11 AM     Remind Me!  Send Private Message   Edit Post
It really sucks in Cali traffic going about 0-5 mph in a 70 mile round trip.
92 GVR4 #802 link
SOLD: 92 GVR4 #611
alansupra94
4/1000
Galant VR-4 org Post #: 970269 posted 02/16/11 12:02 PM     Remind Me!  Send Private Message   Edit Post
Well after a quick inspection, it seems that there is a break in the line somewhere where the two lines connect near the fusebox. Reason I say this is when I opened the hood, there was clutch fluid all over the fusebox, air filter/intercooler pipes and on the back up sensor. The master and slave have 0 leaks and the fork looks fine.
I think it where the previous owner installed a stainless steel line but looks all retard/weird. I will take pictures and post them.
1992 Galant VR4
Muskrat
665/2000
Galant VR-4 org Post #: 970295 posted 02/16/11 01:11 PM     Remind Me!  Send Private Message   Edit Post
Doesn't sound like an issue the ACT caused. Probably either corrosion, or my favorite failure diagnosis RPO (retarded previous owner).
Brian L.
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 970321 posted 02/16/11 03:08 PM     Remind Me!  Send Private Message   Edit Post
:d rpo!
92 GVR4 #802 link
SOLD: 92 GVR4 #611
alansupra94
4/1000
Galant VR-4 org Post #: 970356 posted 02/16/11 05:53 PM     Remind Me!  Send Private Message   Edit Post
Quoting Muskrat:
Looks like an RPO. Upon inspection, I realize this line is a goodwrench brake line crappily fabricated to work. Sigh. And I start my new job tomorrow :/
1992 Galant VR4
grocery_getter
Senior Crab
836/2000
Galant VR-4 org Post #: 970369 posted 02/16/11 06:38 PM     Remind Me!  Send Private Message   Edit Post
It is so much easier to bad mouth a product or a company before even doing a simple inspection on the real cause of failure.
Andre
836/2000
PINA MOTORSPORTS
Facebook page
Posts: 1225 | From: Kent - industrial suburbs of S... | Member Since: 06/20/04 | IP: (96.26.33.230) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 970371 posted 02/16/11 06:44 PM     Remind Me!  Send Private Message   Edit Post
Definitely sounds like a loss of hydraulics (leak), so start with the simple stuff first. IMO, I don't think the 2600 is 'too' stiff or hard on other parts and grabs and holds up really well on hard lauches, but pretty tame around town. I have one in #20 and don't feel it's *too* stiff, but is much more than an oem setup (like the ones I had in GTO or CTS-V) and my only complaint is it engages way too soon from the floor (which makes it feel stiffer than it really is), although I believe there is some adjustment and something I'll definitely look into, as it can/does make it tricky in traffic.
Posts: 9770 | From: ca | Member Since: 04/23/04 | IP: (71.103.2.163) | Report this post to a Moderator
alansupra94
4/1000
Galant VR-4 org Post #: 970377 posted 02/16/11 07:19 PM     Remind Me!  Send Private Message   Edit Post
Quoting grocery_getter:
I guess I should have been more specific in my post. I wanted to replace the master and slave with stronger components because I like my ACT 2600.
1992 Galant VR4
Edited by alansupra94 (02/16/11 07:21 PM)
alansupra94
4/1000
Galant VR-4 org Post #: 970701 posted 02/17/11 10:47 PM     Remind Me!  Send Private Message   Edit Post
Holy shit! After I replaced the line with a goodwrench stainless steel brake line and bled it, the clutch pedal is like butter now! I don't know what that previous owner did but man it is amazing now. Transmission engages like butter now and requires less effort than the brake pedal by far!
1992 Galant VR4
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 970820 posted 02/18/11 11:29 AM     Remind Me!  Send Private Message   Edit Post
Wow, good to hear man!
92 GVR4 #802 link
SOLD: 92 GVR4 #611
1990ggsxnj
Member ++
1578/2000
Galant VR-4 org Post #: 970840 posted 02/18/11 01:38 PM     Remind Me!  Send Private Message   Edit Post
Could have the restrictor removed.
"Is that Spool Drool? EWW!"
90GGSX Blue-Chesapeake
91GVR4 Nile Black-Sidney (Sid)
Posts: 525 | From: Blackwood, NJ | Member Since: 11/21/08 | IP: (12.175.119.76) | Report this post to a Moderator
Launch
Member +
634/1000
395/1000
Galant VR-4 org Post #: 976757 posted 03/14/11 07:36 PM     Remind Me!  Send Private Message   Edit Post
2600 for the win. Everything else for the fail
Posts: 350 | From: Texas | Member Since: 08/17/06 | IP: (99.91.161.25) | Report this post to a Moderator
alansupra94
4/1000
Galant VR-4 org Post #: 976762 posted 03/14/11 07:49 PM     Remind Me!  Send Private Message   Edit Post
Yeah I am not sure but it looks like he crimped on end with a plastic crimp. I dunno wtf this guy was doing. Praise the lord I got this car and brought it back to the condition it should be in.
1992 Galant VR4
1 registered and 35 anonymous users are browsing this forum.
Generated in 0.072 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
