Grrr! Broken 2 prong connecter on top of thermostat assembly
I noticed that the plastic connector [2 prong] on top of the thermostat assembly has a broken wire, and the other wire is hanging on by a couple of threads,
I managed to pull the pins from the connector, and wanted to know where I could get NEW pin connectors and start over with new pins and fresh wire.......
JNR
ca
I ended up using two small, insulated spade connectors (that fit snug on the terminals) and butt-splicing onto the factory connector, until I get a replacement. Just make note which wire goes to which terminal, to not mix them up (may not matter on this, but still)...Not the best way (I want to get an oem replacement and eliminate the butt splices], but works for now...
Thanks JNR.. Imight go that route too!!
But I'm sure someone has sourced some replacement connectors!!!
JNR
ca
No doubt.
Well, your plastic housing is in good shape (I think mine was cracked, iirc), so if you're tricky, you could undo the factory crimp on those spades and put in the wire (oem, if you have enough slack) and re-crimp...as you're probably aware, since you took them out, they have little barbs (or maybe it's those black, notched 'sleeves' in this case) that snap into place...This is the way I would've done it, if my housing was alright...
Another option is to look at an AMP catalog (or similar), as most oem's use various styles like that, although many of them are proprietary, for obvious reasons...
Yeah, there was a plastic locking lip that just needed to be pressed downwards while I pulled on the wire and the connector slid out of the plastic housing!!
I'll check online under "mini spade" conntectors.
strokin4dr
Savannah, GA
Iceman may be able to help you out. He has a source for certain pins for making adapters. Send him a PM.
atc250r
Orange County, NY
Does your AC work? If it doesn't then you don't need that anyway. In fact, you might not need it anyway. I think its just to turn the AC off under an overheat condition. I could be wrong but I think that's what its for. You can carefully disassemble the spades and solder new wires to them. I rebuilt my CAS plug like that.
John
ktmrider
Tempe, AZ
^^ +1 to John, that is only relevant to the A/C ( cuts off A/C clutch if coolant is overheating ).
No A/C = no need.
Rausch
Cleveland, OH
I'm hoping he does still have A/C, and it still works. He might actually be one of the few that needs that connection to work. /ubbthreads/images/graemlins/rofl.gif
I did the same fix (Little spade connectors/soldered) before I yanked out the A/C parts.
JNR
ca
Well, my A/C still blows cold and want to keep it that way /ubbthreads/images/graemlins/tongue.gif and I hate mickey mouse stuff; especially electrical, so I would love to hear if somebody can get the oem housing and connectors...The second option is to cut a pigtail off another harness, but rather not even do that, unless I can get a long length to play with...
Quoting VRausch4:
It gets to be about 135 degrees out here at the height of the summer. So yes, I'll definitley need it.
Quoting CP:
If it uses the same pins as the ECU plugs, I can send you several of those.
you have PM !!!!!!!
Polish
NE, IN
I also did the insulated spade connector trick on some of mine, worked perfect for me.
CO VR4
Colorado
A Mitsubishi dealer tech friend of mine told me that Mitsu dealers have available a replacement kit that has all of the female connectors with wire pigtails, and they can get you whichever one they need with some help from the friendly parts counter guy...
I have a few of the connector bodies that will work for that plug, but no pins. I resoldered mine onto the original pins when I fixed it.
If someone knows where to get those pins, that would be great. IIRC, I did not have the right size in my selection.
dmj
orlando FL
go to the junk yard and look for any hyundai with the 2.0 engine u will get a connector that is a direct fit.it is in the same position as the gvr4.I located one on a 1997 model sonata 2.0 i also took the valve cover.
CP
West Simsbury, CT
Quoting iceman69510:
Are they the same size/type of lins that are in the plugs that connect to the ECU? If so I've offered to send him several. We just need to verify that the ECU pins will work for this application.
Rausch
Cleveland, OH
Quoting dmj:
5th Fleet Naval NSA, Bahrain |......Probably not going ot have much luck there. /ubbthreads/images/graemlins/crazy.gif
