Galant VR-4 Forums » Galant VR-4 » Technical Discussions » wtf rear axle too short???
tsiboy
has one ambihelical hexnut
810/1000
Galant VR-4 org Post #: 731417 posted 12/06/08 04:29 PM     Remind Me!  Send Private Message   Edit Post
so a about a week ago i changed the rear end on the g-ride and removed the 4ws.
i swapped it for a 3bolt lsd rear. i bought some lsd rear axles installed everything and now i find that the driverside rear axle is popping out of place, it looks almost like it is too short. has anybody had any experience with this?? i thought i was done with the car and would be able to drive it now, but i guess i was wrong.
-alex
810/1000 Nile black
damn it where did all my 12mm's go
Posts: 1137 | From: Los Angeles, Ca | Member Since: 01/26/05 | IP: (69.230.67.15) | Report this post to a Moderator
tsiboy
810/1000
Galant VR-4 org Post #: 731419 posted 12/06/08 04:34 PM     Remind Me!  Send Private Message   Edit Post
im going to try to replace the c-clip, and i guess go from there.
810/1000 Nile black
gtluke
Fegbasket
Galant VR-4 org Post #: 731435 posted 12/06/08 05:36 PM     Remind Me!  Send Private Message   Edit Post
sounds like a good start
86gt pte67gtq
galant vr4 1464 12.83 @ 106
05sti, 400whp
00 2.5rs, for sale
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (69.242.29.31) | Report this post to a Moderator
tsiboy
810/1000
Galant VR-4 org Post #: 731651 posted 12/07/08 01:12 PM     Remind Me!  Send Private Message   Edit Post
any other input on this incase the clips are not the problem??
there are only 4 types of axles right???
3bolt non lsd
3bolt lsd
4bolt non lsd
4bolt lsd
auto and manual are the same correct???
810/1000 Nile black
Posts: 1137 | From: Los Angeles, Ca | Member Since: 01/26/05 | IP: (208.15.90.2) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 731658 posted 12/07/08 01:36 PM     Remind Me!  Send Private Message   Edit Post
I don't think there are 4 bolt non-lsd's but I may be wrong. Auto/Manual is the same.
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
belize1334
1334/2000
Galant VR-4 org Post #: 731670 posted 12/07/08 02:24 PM     Remind Me!  Send Private Message   Edit Post
Are you sure you don't have the left/right axles switched? I believe one is longer than the other on the LSD units.
Roger B. Scott
'91 Belize Green
Posts: 3312 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (69.144.198.97) | Report this post to a Moderator
tsiboy
810/1000
Galant VR-4 org Post #: 731671 posted 12/07/08 02:25 PM     Remind Me!  Send Private Message   Edit Post
are the clips something that is available at the parts store or do i have to go through the dealer or jnz
i went to autozone and as usuall they had no idea what i was talking about.
810/1000 Nile black
gtluke
Fegbasket
Galant VR-4 org Post #: 731672 posted 12/07/08 02:26 PM     Remind Me!  Send Private Message   Edit Post
My local parts store has a selection of clips, but its not a chain and they actually have good stuff and not just oil filters.
Dealer should have them though
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 731857 posted 12/08/08 12:46 AM     Remind Me!  Send Private Message   Edit Post
Quoting gtluke:
Cars with ABS don't have LSD so a 94 Talon with ABS will have a non-LSD 4-bolt.
I love my crazy mother!!!
Posts: 1594 | From: Manchester, NH | Member Since: 07/17/06 | IP: (24.147.43.251) | Report this post to a Moderator
H05TYL
Hover/Stand/Bend
Galant VR-4 org Post #: 731870 posted 12/08/08 01:30 AM     Remind Me!  Send Private Message   Edit Post
Are you sure? plenty of JDM spec cars have abs and viscous lsd's.
mechanical 4bolt lsd's have different axles to viscous ones, will be the same as non-lsd 4bolt ones, assuming such exists.
JDM E39A - 0010362 VR-4 Project 燃えないゴミ(Unburnable Junk) - stolen
JDM E39A - 0020096 VR-4 Daily - sold
Posts: 752 | From: Wgtn, NZ | Member Since: 06/09/07 | IP: (121.73.146.65) | Report this post to a Moderator
dsmer06
I fail at the internet.
246/1000
Galant VR-4 org Post #: 731894 posted 12/08/08 05:50 AM     Remind Me!  Send Private Message   Edit Post
Quoting CutlassJim:
Quoting gtluke:
I thought they changed the abs computer on the 92 or 93 models so they could have both. My 93 parts car has abs, and I'm 90% sure it has a lsd.
#246/1000
Posts: 636 | From: Des Moines, IA | Member Since: 02/27/08 | IP: (69.66.30.212) | Report this post to a Moderator
gtluke
Fegbasket
Galant VR-4 org Post #: 731902 posted 12/08/08 07:58 AM     Remind Me!  Send Private Message   Edit Post
That was only true with 3 bolts, ABS 1GB talons all got LSD 4 bolts.
Come to think of it, I know that even Automatic 1GB's got LSD 4 bolts so I don't think there are any that are non-lsd
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (75.151.164.150) | Report this post to a Moderator
tsiboy
810/1000
Galant VR-4 org Post #: 732751 posted 12/09/08 07:02 PM     Remind Me!  Send Private Message   Edit Post
well i think i found the problem. dont know if this happened before or after i intalled the axle but the ds axle splines are worn at the end. so the diameter of the shaft at the end is smaller than the rest allowing the clip to slide out when enough force is applied. sad thing is i need a rear diff again since i found pieces of metal inside when i removed the axle
810/1000 Nile black
Edited by tsiboy (12/09/08 07:03 PM)
gtluke
Fegbasket
Galant VR-4 org Post #: 733260 posted 12/10/08 05:39 PM     Remind Me!  Send Private Message   Edit Post
i'm sure someone will give you a 3 bolt diff and axle
86gt pte67gtq
05sti, 400whp
00 2.5rs, for sale
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 733453 posted 12/11/08 12:52 AM     Remind Me!  Send Private Message   Edit Post
Quoting tsiboy:
Yeah, I had that happen once. The clip messed up the splines on the axle shaft so I had to file the grooves back in to it.
-Jeff
1881/2000
50/1000
Posts: 7871 | From: KC, Missouri | Member Since: 08/08/04 | IP: (75.87.128.187) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.097 seconds in which 0.072 seconds were spent on a total of 14 queries. Turbo powered.
