Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Custom 75mm Throttle Body
TheBoz
Galant VR-4 org Post #: 702032 posted 09/28/08 02:21 PM     Remind Me!  Send Private Message   Edit Post
After my BBK Throttle body took a shit, my brother and I decided that we would build on that could handle the abuse that I was going to dish out. The Body is 6061 Aluminum, and the Butterfly and shaft are both 304 Stainless. The Rotor matches the stock rotor size, and the TPS Sensor is the stock one.
This is just Revision 1, we still have some changes we need to make to it. I need to find a better spring for it. Sometime the spring will bind and the throttle will slowly close. So after we have sourced a new spring this thing should be perfect.
We did some 25psi pulls on it last night and it held up great. We are going to continue beating on it to see if we can get it to break . however I dont think we are going to have any luck breaking it.
Let me know what you guys think.
IMG_0007
IMG_0008
IMG_0009
IMG_0010
IMG_0011
IMG_0012
IMG_0014
IMG_0015
IMG_0017
IMG_0018
IMG_0019
IMG_0020
IMG_0021
IMG_0022
| | | IP: (69.12.176.160) | Report this post to a Moderator
cOmpressor
also-ran member
Galant VR-4 org Post #: 702033 posted 09/28/08 02:24 PM     Remind Me!  Send Private Message   Edit Post
Looks awesome man! CNC machines are the shiz.
"Life's too short to drive slow cars"
1992 Galant VR-4 KG Just taking a break
2005 Lexus IS300 Dropped but mostly stock
2014 Evo X MR Plastering a smile on my face daily
Posts: 2044 | From: Bay Area, CA | Member Since: 07/03/07 | IP: (76.103.213.121) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 702034 posted 09/28/08 02:24 PM     Remind Me!  Send Private Message   Edit Post
Looks really nice. What are you doing in lieu of a closed throttle switch?
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.197.59.65) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702036 posted 09/28/08 02:25 PM     Remind Me!  Send Private Message   Edit Post
AEM EMS, it just uses the TPS to see when it is closed.
475/1000
Galant VR-4 org Post #: 702040 posted 09/28/08 02:32 PM     Remind Me!  Send Private Message   Edit Post
Sweet.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (208.88.172.170) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 702041 posted 09/28/08 02:33 PM     Remind Me!  Send Private Message   Edit Post
Nice work. It's about time someone did this.
| | | IP: (75.74.8.7) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702042 posted 09/28/08 02:39 PM     Remind Me!  Send Private Message   Edit Post
After we get done with a lot more testing, I will offer them up to the dsm community. I need to go through and do a full run of pressure tests, and make sure it can handle the abuse of 35+psi runs. All in all it is working great so far, we need to adjust the throttle plate, it seems that we need to taper it a little, and we also want to add the ISC to this. We learned a lot about building Throttle bodies, it is not as easy as it looks, however there is really not much to them .
cOmpressor
also-ran member
Galant VR-4 org Post #: 702045 posted 09/28/08 02:51 PM     Remind Me!  Send Private Message   Edit Post
Quoting TheBoz:
IMG_0019
No half shaft mod LoLzx
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 702046 posted 09/28/08 03:07 PM     Remind Me!  Send Private Message   Edit Post
Nice work. You may want to bead the opening though, so there is less chance of the coupler blowing off.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock
Posts: 2766 | From: Savannah, GA | Member Since: 08/30/05 | IP: (71.229.63.35) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702060 posted 09/28/08 04:21 PM     Remind Me!  Send Private Message   Edit Post
It is a full shaft. We were just doing all the testing on Rev 1, we will put a bead on it. But it held on just fine at 25psi, on a t67.
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 702066 posted 09/28/08 05:01 PM     Remind Me!  Send Private Message   Edit Post
Peter Griffin and I agree, that's freakin sweet!
A very cool and unique mod, although I agree on lengthing the area for a coupler to attach or add a bead.
A great first effort for never making a TB before.
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (32.147.188.60) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702084 posted 09/28/08 06:34 PM     Remind Me!  Send Private Message   Edit Post
Ya, keep the input coming. I want to make a lot of changes for rev 2. So anything you guys can think of that this needs. We used the BBK 75mm as our template for this. We did make a lot of little changes that would help to make mine a lot stronger and seal much better.
Also this was all done on a 3 axis milling machine. The only part we did with a lathe was the TB Shaft, and that was just to cut it down to size. The only lathe I have access to is from WWII so it is very loose.
I can tell you for sure that there is a lot more to a TB than meets the eye. The Butterfly was the hardest part, and getting it to seal up properly has been a huge pain in the ass.
Also Thanks for all the input so far.
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 702087 posted 09/28/08 06:59 PM     Remind Me!  Send Private Message   Edit Post
Quoting CarRacer:
+1, maybe both ( longer and beaded ) on the input.
Still a beauty! Great job...
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Posts: 3116 | From: Portland, OR | Member Since: 09/10/07 | IP: (76.113.121.3) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 702088 posted 09/28/08 07:03 PM     Remind Me!  Send Private Message   Edit Post
I'd have to agree 110%, make the flange for the TB inlet longer and either machine a bead into it or weld one there. How about putting a CTP switch mount for those of us that aren't baller enough to run an AEM EMS?
John
Hard Snarker
1051/2000
Galant VR-4 org Post #: 702091 posted 09/28/08 07:06 PM     Remind Me!  Send Private Message   Edit Post
Where does the FIAV and ISC go?
Looks good. +1 on a longer and beaded coupler section.
-Mark
1051
Posts: 11940 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702095 posted 09/28/08 07:14 PM     Remind Me!  Send Private Message   Edit Post
It is crazy because it is hard to decide what to put on and what to leave off. For me I dont need any of the fancy stuff , it is ok for my car to idle at 1300 rpm. However I would like to offer these up to the DSM community, but dont want to add a lot of features that people will not use.
I know I would love to have the Idle Control Motor and a BISS on there instead of using the Throttle body to set the idle.
The existing cupler mounting surface is long enough for a tbolt clap. How much more do you guys think it should be extended? (5mm, 10mm, 20mm)
Things to add
1. Idle Controller
2. BISS
3. Throttle Closed Sensor
4. Additional Cupler Mounting Surface with Bead
chris
Galant VR-4 org Post #: 702098 posted 09/28/08 07:18 PM     Remind Me!  Send Private Message   Edit Post
thats bad ass! do you have access to a cnc machine all the time? and do you write your own code?
Edited by chris (09/28/08 07:19 PM)
| | | IP: (72.200.148.16) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 702110 posted 09/28/08 07:49 PM     Remind Me!  Send Private Message   Edit Post
I would say 10 or 20mm added to the TB inlet would be nice to give the user some breathing room with it. I don't run a ISC or a FIAV on my car and IMHO, the majority of 4G63's that could benefit from a larger TB don't need them anyway. I only asked about the CTP switch because it does have a significant effect on idle and when coasting downhill. Without it the stock ECU won't shut the injectors off when coasting and the idle will usually surge for no apparent reason.
John
Hard Snarker
1051/2000
Galant VR-4 org Post #: 702133 posted 09/28/08 08:38 PM     Remind Me!  Send Private Message   Edit Post
The throttle body coupler in the pic below is a spare from a past setup I ran. It is 2.00" long. The one on my car now is 1.25" long, which is the shortest I would go comfortably. It leaves just enough room between the bead and the TB flange to clamp the coupler down.
-Mark
1051
Edited by turbowop (09/28/08 08:39 PM)
Jonvr4
Galant VR-4 org Post #: 702146 posted 09/28/08 09:19 PM     Remind Me!  Send Private Message   Edit Post
That thing is pimp. Waaay over built, I love it.
| | | IP: (67.165.240.171) | Report this post to a Moderator
mean_green
Member +
1632/2000
Galant VR-4 org Post #: 702245 posted 09/29/08 01:29 AM     Remind Me!  Send Private Message   Edit Post
+1 on getting it done yourself...
-1 for the duralast...
Posts: 313 | From: Park City, MT 59063 | Member Since: 11/12/07 | IP: (24.72.223.108) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702257 posted 09/29/08 01:57 AM     Remind Me!  Send Private Message   Edit Post
LOL, duralast is mad tight JDM Yo!
| | | IP: (32.155.103.47) | Report this post to a Moderator
CarRacer
83/2000
Galant VR-4 org Post #: 702281 posted 09/29/08 08:30 AM     Remind Me!  Send Private Message   Edit Post
One more thought, what are you using for a gasket? I'm sure people who would use this are going to have aftermarket manifolds, but the flange surface could still get damaged causing a bad seal.
I think NAPA sells flat sheets of gasket material, so it's possible to just trace and cut one out.
James
83/2000
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (68.117.55.130) | Report this post to a Moderator
GIjoe
lol, Im an idiot
1562/2000
Galant VR-4 org Post #: 702389 posted 09/29/08 12:55 PM     Remind Me!  Send Private Message   Edit Post
wow, nice!
1991 Galant VR-4 1562/2000 SOLD as of 03/2016
1998 Subaru Forester
2011 BMW 1M
Posts: 1044 | From: Budapest | Member Since: 07/27/08 | IP: (78.92.26.107) | Report this post to a Moderator
TheBoz
Galant VR-4 org Post #: 702419 posted 09/29/08 01:55 PM     Remind Me!  Send Private Message   Edit Post
Quoting CarRacer:
Yep, some cut out pepboys gasket . As long as it holds boost that is all I care about.
| | | IP: (38.104.76.130) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 24 anonymous users are browsing this forum.
Generated in 0.123 seconds in which 0.083 seconds were spent on a total of 14 queries. Turbo powered.
