Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Vibration I can't seem to diagnose
turboneon
Galant VR-4 org Post #: 1225846 posted 03/23/16 06:18 PM     Remind Me!  Send Private Message   Edit Post
newbie thread
Hello everyoneveryone! Fist off I've been living my gvr4 but I have put a new aluminum drive shaft, front axles and changed out my front motor mount and can not get this vibration I have gone. It only does it under mild acceleration and seems to be not near as bad at wide open throttle. I have attached the link to my thread in the newbie section but I can not seem to figure this out and I'd like to fix it myself rather than pay who knows what at a shop. If anyone has any input I'd greatly appreciate it!
Thanks !
Jake
Posts: 49 | From: greenville sc | Member Since: 04/17/15 | IP: (66.169.44.84) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 1225849 posted 03/23/16 07:58 PM     Remind Me!  Send Private Message   Edit Post
If the clutch is really slipping, I'd yank that thing out and install a good flywheel/clutch setup to rule that out and fix an existing issue at least.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2354 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:387:1:816::) | Report this post to a Moderator
turboneon
Galant VR-4 org Post #: 1225851 posted 03/23/16 08:19 PM     Remind Me!  Send Private Message   Edit Post
I think the main reason the clutch was slipping bad at first was because the car had been sitting for years without being ran. If I pull the Trans I'll probably rebuild it too because the synchros are bad. I guess my main scare is doing all that work and it still vibrates lol
marvinmadman
136/1000
Galant VR-4 org Post #: 1225853 posted 03/23/16 08:27 PM     Remind Me!  Send Private Message   Edit Post
I've gotten bad front axles before from a parts store. My damn DD b16 ef sedan would shake between 30-45 no matter what. After 3 axles I got a good pair.
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1225854 posted 03/23/16 09:19 PM     Remind Me!  Send Private Message   Edit Post
Quoting turboneon:
I don't see the problem with fixing known issues (slipping clutch and bad synchros) with the possibility of it still vibrating. Those things still need to be addressed anyway, so it would be the right path to getting the car back to where it should be anyway. Hopefully those fixes would help though. Good luck!
Posts: 2766 | From: Savannah, GA | Member Since: 08/30/05 | IP: (73.21.58.201) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1225862 posted 03/24/16 07:10 AM     Remind Me!  Send Private Message   Edit Post
What king of mount/gromets are you using for the driveshaft/carrier bearings? Are they solid or stock?
Thom
Posts: 887 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (50.58.165.200) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 1225863 posted 03/24/16 07:55 AM     Remind Me!  Send Private Message   Edit Post
Also, did the shop balance the whole driveshaft and correctly install the u joint snap shims?
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
gtluke
Fegbasket
Galant VR-4 org Post #: 1225867 posted 03/24/16 10:04 AM     Remind Me!  Send Private Message   Edit Post
I had an axle that would sometimes shift or something and have a bad vibration.
Make sure the jack shaft is bolted in properly with the correct spacers or AC bracket
Recently my front trans bolt worked it's way out and caused a strange vibration at highway speed.
86gt pte67gtq
galant vr4 1464 12.83 @ 106
05sti, 400whp
00 2.5rs, for sale
Posts: 4210 | From: dirty jersey | Member Since: 09/16/01 | IP: (50.182.169.238) | Report this post to a Moderator
turboneon
Galant VR-4 org Post #: 1225881 posted 03/24/16 08:12 PM     Remind Me!  Send Private Message   Edit Post
Solid carrier bearing mounts from torque solutions
Posts: 49 | From: greenville sc | Member Since: 04/17/15 | IP: (75.139.75.179) | Report this post to a Moderator
turboneon
Galant VR-4 org Post #: 1225882 posted 03/24/16 08:13 PM     Remind Me!  Send Private Message   Edit Post
I don't think any additional balancing happened I was told it should bolt up fine as is.
turboneon
Galant VR-4 org Post #: 1225883 posted 03/24/16 08:15 PM     Remind Me!  Send Private Message   Edit Post
The ac bracket is still in tack. I'm assuming the jack shaft is the Trans to driver side front axle extension? Do you have any info on this because I was at a loss as to how to check anything on it.
turboneon
Galant VR-4 org Post #: 1225884 posted 03/24/16 08:16 PM     Remind Me!  Send Private Message   Edit Post
Thanks a million on this input guys!
marvinmadman
136/1000
Galant VR-4 org Post #: 1225885 posted 03/24/16 08:42 PM     Remind Me!  Send Private Message   Edit Post
I'm interested in these spacers too. I don't have any and I don't remember what they look like. Last time I removed a half/jack/intermediate shaft was like 10 years ago. My memory isn't all that great with this piece
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
marvinmadman
136/1000
Galant VR-4 org Post #: 1225886 posted 03/24/16 08:56 PM     Remind Me!  Send Private Message   Edit Post
Nevermind. I found the info. 1 spacer is only needed if you don't have the AC bracket installed. The bracket acts as a spacer.
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
turboneon
Galant VR-4 org Post #: 1225939 posted 03/26/16 09:46 PM     Remind Me!  Send Private Message   Edit Post
Anyone know if the intermediate shaft goes bad? Also can I get a new one? I'm so at a loss on this I'm ready to buy cheaper parts to try to get somewhere with this vibration
marvinmadman
136/1000
Galant VR-4 org Post #: 1225940 posted 03/26/16 10:06 PM     Remind Me!  Send Private Message   Edit Post
Never seen one go bad. There's a bearing inside it though. Definitely can go bad and would cause a vibration.
1982/2000 sold
1263/2000 parts
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2354 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:387:1:812::) | Report this post to a Moderator
MegaSuiter
256/1000
729/2000
Galant VR-4 org Post #: 1225957 posted 03/27/16 01:05 PM     Remind Me!  Send Private Message   Edit Post
I have used a microphone system before to locate different noises around the car. the one I used had six microphones you can place wherever you want. If you can get your hands on one, try using it to maybe isolate the vibration. Maybe it'll make enough noise to pick it up on a mic?
Posts: 122 | From: Oscoda, MI | Member Since: 12/06/11 | IP: (75.133.31.201) | Report this post to a Moderator
turboneon
Galant VR-4 org Post #: 1225970 posted 03/27/16 04:58 PM     Remind Me!  Send Private Message   Edit Post
I have thought about that but most mechanics here just give up easy when there's a problem like this. I definitely don't want to invest in one but I will see if I can find someone who had one! Anyone know the intermediate shaft part number? Can't seem to find it anywhere.
Eager Beaver
Galant VR-4 org Post #: 1225974 posted 03/27/16 08:10 PM     Remind Me!  Send Private Message   Edit Post
Partsbase.org is online ASA.
Any luck finding what you need on that site?
C53A 1 of the ~1500
Posts: 1617 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.241.192.124) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1225978 posted 03/27/16 08:13 PM     Remind Me!  Send Private Message   Edit Post
Also, what is the brand of aluminum driveshaft ? DSS ?
Was it balanced/checked for balance as mentioned before?
It was bolted in but that means nothing, IF, it is still not balanced.
Do you have the original driveshaft setup?
Pop it in, and compare.
C53A 1 of the ~1500
866/1000
Galant VR-4 org Post #: 1225995 posted 03/28/16 09:07 AM     Remind Me!  Send Private Message   Edit Post
I suggest swapping out the Torque Solutions solid mounts for some factory mounts and check. Though they are good mounts, they allow driveline vibrations to be transferred directly to the body. I just swapped out my TS solid mounts and put in stockers. No more vibration
Thom
Posts: 887 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c403:80) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1225999 posted 03/28/16 10:26 AM     Remind Me!  Send Private Message   Edit Post
^^^ Easier still!
C53A 1 of the ~1500
turboneon
Galant VR-4 org Post #: 1226137 posted 03/31/16 09:23 AM     Remind Me!  Send Private Message   Edit Post
It is dss and I don't think there was any balancing that we did. It seems like it really only does it bad around 4k rpm. Full throttle isn't near as bad as slow driving.
Posts: 49 | From: greenville sc | Member Since: 04/17/15 | IP: (2600:1004:b107:5) | Report this post to a Moderator
turboneon
Galant VR-4 org Post #: 1226138 posted 03/31/16 09:35 AM     Remind Me!  Send Private Message   Edit Post
Just called the dss and the said try to rotate the aluminum shaft 180 degrees. That everything is balanced and shouldn't have to be balance when assembled to existing shaft.
475/1000
Galant VR-4 org Post #: 1226162 posted 03/31/16 05:11 PM     Remind Me!  Send Private Message   Edit Post
bolts holding diff to subframe
pinion angle
pinion nut tight
diff bearings
did someone or you fill the carrier bearings with rtv or window weld urethane.....this can cause bad vibrations
t case mount bolts
is the front axles clicked in all the way
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (2602:306:bc76:d4) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.099 seconds in which 0.065 seconds were spent on a total of 14 queries. Turbo powered.
