Galant VR-4 Forums » Galant VR-4 » Technical Discussions » What pistons and what rods?
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 1197372 posted 12/26/14 02:50 PM     Remind Me!  Send Private Message   Edit Post
i wanted to build my own bottom over the winter for minimal investment while focusing on the details that really matter.
i have never bought upgraded pistons or rods but have done stock rebuilds. after just looking on parts are fairly cheap.
i have spare 6 bolt virgin blocks, i can drop one off at a machine shop for inspection, etc.
eagle rods $289 i thought was pretty cheap. 6 bolt rods for 2 pistons. which is the setup i would like to do.
now for pistons i have no idea what i want. i found a few sets of forged pistons for under $400 and some Nippon racing Pistons for $175
add some bearings and machine shop time and i think $1000 total cost would be achievable.
curious to hear from you guys.
my goals are to have a strong built bottom end able to handle 500-600hp if i ever get there one day. 400hp reliably for 20k miles would be a dream come true i think.
E16g, fmic, 1000's, SD, v3, LC2 WB, fp2 cams, ARP's, etc
Posts: 681 | From: mass | Member Since: 02/17/09 | IP: (2601:6:6300:17a:) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1197374 posted 12/26/14 03:00 PM     Remind Me!  Send Private Message   Edit Post
Why can't you do 400 reliably on a stock engine with headstuds and gasket?
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (172.56.32.51) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1197377 posted 12/26/14 03:12 PM     Remind Me!  Send Private Message   Edit Post
I'm kind of with Coyotes on this, unless you're trying to bump compression and get a bit more low end...?
For "cheap" pistons, wiseco 1400HD? Not *that* cheap but regular wiseco seem to have skirt cracking issues and the 1400HD are bulletproof. I will caveat that with the fact that I ran a 2.0 with regular wisecos and it held up fine with an evo3 @ ~22psi (9:1 compression) for quite a long time before I sold it.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3689 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (209.189.196.1) | Report this post to a Moderator
jeverts
Member +
909/1000
Galant VR-4 org Post #: 1197382 posted 12/26/14 03:59 PM     Remind Me!  Send Private Message   Edit Post
Eagle-Wisecos are pretty much the cornerstone to 4g63 lower end building. Probably the best price for the power you can make on it. A lot of people can get into the 700hp range safely with that. After that you are looking at a new crank and turbo tuffs or some sort of I beam rod. ACL race bearings, mains and a 20g or 5858 you can drive 400hp all day long.
Posts: 305 | From: Hartford, WI | Member Since: 07/14/11 | IP: (23.30.240.177) | Report this post to a Moderator
jeverts
Member +
909/1000
Galant VR-4 org Post #: 1197383 posted 12/26/14 04:02 PM     Remind Me!  Send Private Message   Edit Post
I would agree with Coyote. On the other hand...you are already at the stage of putting in rods and pistons..spend the money and be done with it.
slugsgomoo
461/1000
Galant VR-4 org Post #: 1197385 posted 12/26/14 04:29 PM     Remind Me!  Send Private Message   Edit Post
also unless you're going for insane power levels, building a forged internal engine with <9:1 compression is stupid IMO.
All the money, virtually none of the benefits. Stock pistons will hold ~500hp and be good for 130mph traps. Built motors in a street car are all about low/mid range, hilarious power. One of my friends is building a 10:1 2.4L... that's where the hilarity factor goes straight to 11.
-andrew
{witty signature}
2014 Ford Focus ST
Galant VR-4 org Post #: 1197398 posted 12/26/14 06:33 PM     Remind Me!  Send Private Message   Edit Post
I vote Eagle rods with 22mm wrist pin And the nipon 2g pistons with floating pin.
I think I'm going to be putting one of these together with my spare block.
7 1G DSM's now a GGSX build.
Posts: 1476 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1197399 posted 12/26/14 06:36 PM     Remind Me!  Send Private Message   Edit Post
Quoting slugsgomoo:
one of these years it'll run
1226/2000
slugsgomoo
461/1000
Galant VR-4 org Post #: 1197402 posted 12/26/14 06:54 PM     Remind Me!  Send Private Message   Edit Post
machininst took a long time. The short block is actually assembled, but progress has been slow due to a couple other things. The car is fine on the stock bottom end though.
-andrew
{witty signature}
2014 Ford Focus ST
biglady112
or what
359/2000
Galant VR-4 org Post #: 1197411 posted 12/26/14 11:03 PM     Remind Me!  Send Private Message   Edit Post
Going to a larger 22mm wrist pin gains you no advantage if you still have a flacid wrist pin. When will people understand that? If you are going to make a big deal about it go with a quality material in a thickness that will actually benefit you. I would invest correctly if you are going that far. If you get a low end for like that or any rod for that matter have the machinists check for weight equality, bore sizing, pin fitment and if you go through with it please invest in a more modern design than a cheap ass $350 piston. In my eyes the heavier the better across the board. As with everything we start to get greedy and push things. Might as well over build it if you are in there.
With that said I have had tremendous luck with Arias pistons and either GRP aluminum or Pauter chromoly rods. I am going to say those are likely not economical or focused towards where this car will be used. Just remember, you get what you pay for.
I GIVE ZERO FUCKS. I HATE YOU ALL.
Posts: 1242 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (174.16.160.150) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1197414 posted 12/27/14 12:15 AM     Remind Me!  Send Private Message   Edit Post
Tektic mentioned using a 22mm wrist pin because that's what standard 2G pistons come with, not because they are stronger. I'm assuming he said that due to the OP wanting to run 2G pistons hung on 6 bolt rod...A normal 6 bolt rod having a 21mm little end of course.
WTF is a flacid wrist pin anyways?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3423 | From: SoCal | Member Since: 01/02/12 | IP:
(72.45.2.251) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1197422 posted 12/27/14 06:19 AM     Remind Me!  Send Private Message   Edit Post
Any off the shelf piece of shit .200" and thinner. The kind you get with cheap ass pistons.
Posts: 1242 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (205.197.242.160) | Report this post to a Moderator
Galant VR-4 org Post #: 1197426 posted 12/27/14 09:12 AM     Remind Me!  Send Private Message   Edit Post
The op asked for an economy build, and you suggest aluminum rods. Ok 3/4 of the budget down.
Then after suggesting aluminum rods you say get the heaviest pistons you can find? Is that to make up for the weight lost using aluminum rods? Off the shelf Pistons are infered to all be shit. So custom heavy pistons with a wrist pin bigger than .200", so they are not flacid right?
Edited by tektic (12/27/14 11:02 PM)
Posts: 1476 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.23.61) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1197427 posted 12/27/14 09:25 AM     Remind Me!  Send Private Message   Edit Post
I've had great luck with my eagle wisecos. I wish I had gone higher compression, but it was my first build. I do hate on my wisecos though. They make a crappy noise at idle once hot. No performance issues and I've gone 27k miles with no loss in compression. Just an annoying knocking type sound. When I do rebuild it again, I plan on going to 9.5:1 on JE or Mahle pistons. I've heard both brands hold up good in under 600whp builds. Got a buddy making 900whp on Mahle with no issues so far.
I do vote that if your building it, go for it. Do it now otherwise you'll regret not forging the bottom end. I did it to lose rotating weight, which is noticeable. I had a frozen pin on #4, so I needed parts anyway. It wasn't much more to run the eagle/wiseco combo anyway. I think it was about 400 bucks more than fixing the stuck pin.
Sure you don't NEED to, but seriously, do it once and be happy. Otherwise you'll want to rebuild it and then your on jackstands again and you grow to hate the car cause you can't drive it.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
biglady112
or what
359/2000
Galant VR-4 org Post #: 1197444 posted 12/27/14 12:41 PM     Remind Me!  Send Private Message   Edit Post
Get the heaviest piston and rod you can. Plain and simple. The lighter is better thought does not apply when pushing a forced induction engine. And you will see that I did not recommend the rods first. Anyone considering investing needs to look past the basic 15 year old designs that are the cheapest options out there. For another $150-200 you can get a quality piston. And for those that do not know, make sure you invest in a quality wrist pin. The thin pins are crappy material and do not hold up to long term abuse. A motor I just tore down proves this. And get a thick pin as that is a key element people look past. The off the shelf ones are garbage and flex quite easily. I was pretty clear in what i thought would work, even though it is not in most folks budget. Regardless of what you spend, you better make sure the parts are right and not just assume.
Posts: 1242 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (205.197.242.151) | Report this post to a Moderator
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1197451 posted 12/27/14 01:35 PM     Remind Me!  Send Private Message   Edit Post
Possibly newb question here:
What is the benefit of a heavy piston/rod combination vs a lighter piston/rod combination on a forced induction engine?
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2331 | From: USA | Member Since: 01/07/12 | IP: (96.255.218.126) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1197457 posted 12/27/14 02:23 PM     Remind Me!  Send Private Message   Edit Post
More material to take the abuse and girth for the durabilty/longevity. Something I learned racing at Bonneville. Just look at the diesel stuff and follow their lead. Each motor we have put together with heavier parts has just lasted and taken an ass whooping. 600-1000hp four cylinders wide open for five miles at a time. Multiple times in a day, for an entire week of racing. Of course issues arise and other things like head gaskets and such may not last
362Ryan
Not Newbie
362/1000
Galant VR-4 org Post #: 1197468 posted 12/27/14 07:02 PM     Remind Me!  Send Private Message   Edit Post
I'm with Biglady on this one.
I went with Wiseco HD's, tool steel wrist pins and K1 rods.
The machinist said the rods were some of the toughest he has worked with.
92 Galant VR4 362/1000
Posts: 116 | From: Alaska | Member Since: 08/09/13 | IP: (24.113.75.201) | Report this post to a Moderator
Galant VR-4 org Post #: 1197474 posted 12/27/14 10:51 PM     Remind Me!  Send Private Message   Edit Post
Quoting turbophein:
When I see things like "if i ever get there one day" it makes me think this engine will never see more than a 16g turbo. A reliable 400hp makes me think he shouldn't even bother with a forged piston.
It Sounds to me like he wants an engine that starts in the cold and doesn't make noise, not one that can handle 1000hp.
Biglady; you may have the right answer, just not to this mans question.
Edited by tektic (12/27/14 10:53 PM)
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1197489 posted 12/28/14 09:37 AM     Remind Me!  Send Private Message   Edit Post
Quoting 362Ryan:
Not trying to divert too much off topic, but everything I've seen about K1 is they are the same as Eagle/Scat. I've been lucky with 9.0 Wiseco's, and R&R rods in mine, costly, but has been 100% reliable for close to 30k miles now at over 500whp.
And to answer the OP's question a bit more, your Eagle 2G setup is a decent cost effective one, but for not much more money, you can an off the shelf from various companies and have a higher window if you want that 5-600hp later on.
Are people still looking for the factory forged Evo9 pistons and installing them? It's been a few years since I've looked for factory parts builds.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Edited by EMX5636 (12/28/14 09:43 AM)
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.15.96) | Report this post to a Moderator
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 1197495 posted 12/28/14 12:54 PM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
Quoting turbophein:
i want to build a reliable engine with the correct tolerances needed, thats what i meant about focusing on details. i can afford to build whatever i want, i choose not to, its my nature. but if i can get a good deal on parts and do the build myself which i really enjoy doing, thats what i want. maybe one day i will get a turbo setup capable of 500hp plus.
also my signature is not updated. i just bought back my old car with heaps of problems i am sorting through and it has none of the original parts. i just finished putting in a engine i assembled this week. spare stock 6 bolt bottom end i had and rebuilt 2g head. its raining or i would finish the tranny install and attempt the first start up.
Thanks for all the posts, lots of food for thought.
Edited by turbophein (12/28/14 12:56 PM)
presterone
'92 Protege VR-4
Galant VR-4 org Post #: 1197510 posted 12/28/14 04:06 PM     Remind Me!  Send Private Message   Edit Post
So I take it your not gonna sell it? Lol good to see another gvr4 is going to be kicking around new england
98 BMW 328i
92 GVR-4 #221
92 GVR-4 belize green#702
Posts: 514 | From: brunswick maine | Member Since: 01/23/12 | IP: (50.177.209.148) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1197520 posted 12/28/14 05:48 PM     Remind Me!  Send Private Message   Edit Post
Mahle 4032 forgings are super low expansion. Cold weather starts aren't really an issue like with 2618 slugs.
Also, eagle does now sell 6 bolt rods that fit a 22mm pin. I just bought a set today along with a set of mahle 4032 2g/evo 9:1 stroker pistons. 2.3L build is coming together.
Edited by mitsuturbo (12/28/14 05:53 PM)
Posts: 3535 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (73.181.182.82) | Report this post to a Moderator
Galant VR-4 org Post #: 1197522 posted 12/28/14 06:26 PM     Remind Me!  Send Private Message   Edit Post
Evo head volume - 43cc
2G head volume -- 47cc
1G head volume -- 49cc
So when you say "2g/evo 9:1 stroker pistons" which is it 9:1 on a 2g or 9:1 on an evo.
Just something to think about before you start it up.
Banthony
555/1000
Galant VR-4 org Post #: 1197525 posted 12/28/14 06:52 PM     Remind Me!  Send Private Message   Edit Post
I've cc'd a few 1g heads and they've all been 47cc.
97 CBR900RR
2012 Hyundai Veloster
Pages: 1 | 2
0 registered and 48 anonymous users are browsing this forum.
Generated in 0.144 seconds in which 0.073 seconds were spent on a total of 14 queries. Turbo powered.
