Galant VR-4 Forums » Galant VR-4 » Technical Discussions » having trouble Installing Oil Press Sender have Pics
Giomangiee
Galant VR-4 org Post #: 980264 posted 03/27/11 06:25 PM     Remind Me!  Send Private Message   Edit Post
Im installing a boost and oil Gauge i have the Car lifted up and every thing right now and im trying to install the oil sender but not quite sure were it goes exactly they sent me a pic on another post put mine looks a little different. is this the right place where im pointing at??
| | | IP: (71.131.135.27) | Report this post to a Moderator
14u2nV
Resident Pedobear
Galant VR-4 org Post #: 980268 posted 03/27/11 06:46 PM     Remind Me!  Send Private Message   Edit Post
Take the old sensor out, and replace it with the new one.
~Kenneth Brian
"Censorship offends me" ~Author Unknown
Posts: 9397 | From: Agency/St. Joe, MO | Member Since: 07/22/04 | IP: (24.121.148.174) | Report this post to a Moderator
Giomangiee
Galant VR-4 org Post #: 980283 posted 03/27/11 08:18 PM     Remind Me!  Send Private Message   Edit Post
ok i took it off and tried installing the one for the gauges and it wont go in ..will I be able to use the old sender for the gauges or will in not work??
14u2nV
Resident Pedobear
Galant VR-4 org Post #: 980284 posted 03/27/11 08:21 PM     Remind Me!  Send Private Message   Edit Post
Not sure on that one. You could try it and see.
~Kenneth Brian
Giomangiee
Galant VR-4 org Post #: 980314 posted 03/27/11 09:47 PM     Remind Me!  Send Private Message   Edit Post
yea i just tried it and it didnt work so what would i have to do in order to make this oil sender work.
dsmtalontsi95
Herdgate
1902/2000
Galant VR-4 org Post #: 980316 posted 03/27/11 09:49 PM     Remind Me!  Send Private Message   Edit Post
It depends on what voltage the gauge is looking for. I personaly wouldn't mount the sending unit directly to the motor, the vibrations will kill some sending units. When I was putting mine together last year I talked to extremepsi and put this together click Works well.
Chance
91 galant 1902/2000 sold
91 vr4 "unknown"
97 tsi awd race car
90 tsi awd dd sold
05 evo ssl
Posts: 1222 | From: Glenville, PA | Member Since: 12/05/05 | IP: (67.232.226.79) | Report this post to a Moderator
BluFalcon
Fantastic Parts Seller
Galant VR-4 org Post #: 980318 posted 03/27/11 09:53 PM     Remind Me!  Send Private Message   Edit Post
What's circled in the picture is the factory oil idiot light switch on a stock GVR-4 oil filter housing. It's what switches the low oil pressure light on the dash when engine oil pressure drops below 4 psi or so. The oil filter housings that come on 91-94 DSM's are almost identical, except that they have an extra port available to mount a oil pressure sending unit in addition to the low oil pressure switch.
The thread pitch on most aftermarket oil pressure sending units is 1/8 NPT, while the factory hole is threaded for something very similar, but not exactly 1/8 NPT. You can screw the sending unit in and force it in until it stops leaking, but I would not recommend it. I've ran a 1/8 NPT tap into the sensor hole on the oil filter housing with it on the engine, but I also wouldn't recommend doing that. If I were going to do it the "right" way, I'd pull the oil filter housing off the engine, tap the hole for the right thread pitch, and re install after carefully cleaning out any debris that might have been created while tapping the thread. The hole is a pipe fitting, so it's going to get tighter as you thread the sensor into the hole, however don't get too crazy as you can crack the housing.
Ed
93 Eagle Talon TSi/AWD
92 Dodge Stealth R/T TT
06 Mitsubishi Raider V8 DuroCross
521/1000
"SOLD"
Posts: 1307 | From: Wichita, KS | Member Since: 01/20/02 | IP: (76.184.131.73) | Report this post to a Moderator
grocery_getter
Senior Crab
836/2000
Galant VR-4 org Post #: 980454 posted 03/28/11 02:51 PM     Remind Me!  Send Private Message   Edit Post
American 1/8" NPT have 27 thread per inch.
Japanese 1/8" pipe thread is 28 thread per inch.
That's why it wont go in smooth. You can re-tap it with a 1/8" NPT tap so it will work properly. Becareful when you are tapping the hole, it is after the oil filter, so whatever debris you created and not cleaned out will go straight to your main bearing.
And like Ed said above, it is a tapered hole and fitting, it gets tighter the deeper you go. Becareful how much torque you put on it, it cracks very easy.
Andre
836/2000
PINA MOTORSPORTS
Facebook page
Edited by grocery_getter (03/28/11 02:54 PM)
Posts: 1225 | From: Kent - industrial suburbs of S... | Member Since: 06/20/04 | IP: (76.121.219.143) | Report this post to a Moderator
BluFalcon
Galant VR-4 org Post #: 980551 posted 03/28/11 08:34 PM     Remind Me!  Send Private Message   Edit Post
So To Speak...
Ed
521/1000
"SOLD"
Giomangiee
Galant VR-4 org Post #: 980788 posted 03/29/11 06:58 PM     Remind Me!  Send Private Message   Edit Post
Just got done installing My Gauges and they work Great Except for the boost gauge somtimes it take a minute or so then kicks in not sure what it is yet but im messing with it Thursday.. the day light Pic is when the car is idling does it seem accurate
Hard Snarker
1051/2000
Galant VR-4 org Post #: 980790 posted 03/29/11 07:02 PM     Remind Me!  Send Private Message   Edit Post
Yes, 18-19in/hg is normal at idle.
Did you wrap duct tape around the pillar to install the gaugepod? And I can see wires at the bottom. Do you plan on cleaning that up?
-Mark
1051
Posts: 11900 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.113.5.156) | Report this post to a Moderator
Giomangiee
Galant VR-4 org Post #: 980792 posted 03/29/11 07:09 PM     Remind Me!  Send Private Message   Edit Post
yea I used Duck Tape But this is for mean While i need to go to the junk Yard and find another pillar or what ever its call the dam thing was so old and dry it would crack before i could drill a hole through it Seriously
1990ggsxnj
Member ++
1578/2000
Galant VR-4 org Post #: 980942 posted 03/30/11 08:45 AM     Remind Me!  Send Private Message   Edit Post
It sounds like you're running your boost off of the FPS if it takes a minute to kick in. This is the ECU taking a minute to open the Solenoid. You might want to run it directly off of the manifold if that is the case.
"Is that Spool Drool? EWW!"
90GGSX Blue-Chesapeake
91GVR4 Nile Black-Sidney (Sid)
Posts: 525 | From: Blackwood, NJ | Member Since: 11/21/08 | IP: (12.175.119.76) | Report this post to a Moderator
Generated in 0.122 seconds in which 0.092 seconds were spent on a total of 14 queries. Turbo powered.
