Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » 89-92 GVR4 Alumnium radiator (ebay Item, from china)
Vman911
Member +
1667/2000
Galant VR-4 org Post #: 966889 posted 02/01/11 07:07 PM     Remind Me!  Send Private Message   Edit Post
I purchased the radiator off ebay for a 89-92 GVR4 and it didn't really fit right. First thing I did was cut off the 1/8" of rubber on the Bottom holes to drop it down a little. Then I had to move the holes over toward driver side a 1/4". The top brackets I had to elongate the holes to fit cause the radiator was wider then stock. The sensor in bottom doesn't fit. You need a Drill bit and tap for 14x1.5mm for the sensor. After all said and done it fits pretty good. Tight fit by intercooler pipe but it works fine. Good luck... Vinman
Posts: 357 | From: Douglas county, Ga | Member Since: 09/18/05 | IP: (72.148.214.106) | Report this post to a Moderator
Generated in 0.029 seconds in which 0.022 seconds were spent on a total of 14 queries. Turbo powered.
