please help with alternator swap
yeti
san diego california
i don't want to remove things that are not needed
so i have friend who's getting a manual for 91 galant is the vr4 in there?
i have pictures that if someone could tell me which bolts to remove
(sorry for so many questions) but if any but could help it would be great
the last one is before i removed ic piping and are the three gold bolt the ones for the power stering
will post more pictures if needed
14u2nV
Agency/St. Joe, MO
How about instead of making 25 different posts about the same things, you just make one thread and stick with it. Also, if you search you will find tons of info about alternators.
yeti
I have the info about switching the alternator
I'm just lookin for a play by play and I got the manual
Still don't kno where 2 start
Do I have to remove power steering and drain it?
yeti
that is a very informative link
its what i need i just dont know what the pivot bolt is or any of that im going to try right AND START RIGHT AFTEr i get back from kragen
yeti
anything i'm missing
my main problem is i don't know how to remove the power steering
i undid the mouting brackets for radiator but couldent move it over any
do i have to lift it up more than 3 or 4 inches and over?
DO NOT remove those 3 power steering bolts.
There are two bolts that you get to through the pully. It has two holes that line up and you can get a deep well socket on them. They are 14mm. And a third bolt dead middle on the back of the pump that attaches the pump to the rear of the bracket.
This should help visualize what we are saying.
Near Seattle, Washington
^^ this. (what terry said, 2 posts ago)
DO NOT REMOVE THE LINE ON TOP OF THE PUMP! especially if it does not leak yet.
Disconnect neg battery terminal. Remove the hotpipe. Remove the radiator. Move the PS pump out of the way after removing the 3 retaining bolts, and THEN disconnect the alternator and remove the two bolts retaining it.
REMOVAL Should be as follows, IIRC: 2 hose clamps on hotpipe. 4 rad mount bolts. 2 more hose clamps on radiator/engine. 1 radiator electrical connector (goes to fan and sensor, pass side). Radiator. 3 PS pump bolts. Two fasteners to alternator which retain +(pos) cable. One alternator plug. One Alternator tensioner bolt. One alternator mounting/pivot bolt. Belt. Alternator.
Installation is reverse of removal.
Oh, and one last thing!!
OMG WATCH OUT FOR THE HAIRS! You do NOT want any of that stuff getting into your turbo. It could ruin it!
yeti
you made me laugh pretty good right there
considering that actually went threw my head as i have the pipe sitting open
i should get a bumper sticker that says turbohair
and that picture clears everything up
i thank everybody ALOT
and hope i don't post another question about it
yeti
i have every bit of info i need now to remove the alternator
but the second bolt for the power steering resevoir THE PULLY WAS IN THE Way
I COULD GET ON IT SIDEWAYS AND with a normal wrench but could'nt move it past one turn in either direction
is that pully some how moveable?
with the car not running
Yes, if you move the radiator over, it will come out and up.
Remove the alt belt and then you can spin the power steering pully freely. That way you can line up the hole in the pully with the bolt.
yeti
should the fan have to come off the radiator?
and there is only the bottom rubber hose and the top that connects the radiator(other than the mounts)
rgeier11
Chicago Suburbs, IL
Don't remove the fan. Just remove the upper radiator mounts so that you can swivel the radiator. The alternator should be able to sneak out.
yeti
but the top hose from the radiator to the thermostat and the bottom of the engine to the radiator are the only two keeping it in right? (other than the mounts or are you saying i don't have to pull the radiator)
steve
NJ
Quoting rgeier11:
Don't pull the radiator, just do exactly as rgeier says. Remove the upper mounts only, and you will have enough play to get the alt out.
misterfixit
Midlands, UK
Make room to get it out before you do. You need double jointed wrists and just underneath it is the oil warning light sender. Its plastic and brittle.
Rich
