Galant VR-4 Forums » Marketplace » Cars For Sale » SOLD: 1992 Galant VR4(199-623/1000) $3,300 - Bradenton FL
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 930346 posted 09/12/10 04:35 PM     Remind Me!  Send Private Message   Edit Post
$3,500 - Willing to trade for Jeep Cherokee 4 Door 4WD OR 1G-2G Auto AWD/FWD
I have had the car for 3 years now, and I have loved every moment of it. I daily drive this car, and it just made the 1500 mile trip from NY to FL with out a single issue. Other then getting 35 MPG and not breaking the bank on fuel costs.
With in the past few weeks its made many trips to Tampa and also to Orlando (110 miles 1 way)
The Original badge number was 623/1000. Her interior was needed help. Center council was busted seats were ripped and all in all. Not up to my standards. I picked up 199/1000 as a non running parts car. The dash was in much better shape, and so was the front seats and center council. I switched dashes and since I had both badge and matching fob for 199 I left it on there. Due to hard times and unemployed I let badge number 623 leave my hands. Everyone can hate me but I made 1 good car out of 2.
The Shell has 161,XXX I drive it daily so miles will change
There is a Hallman pro MBC on it set @ 15 psi
Engine:
ARPs
OEM Mitsu head gasket
BS Elim
40k on water pump and T belt.
Wiseco Pistons
1G rods
Bored .50mm over
Done in October of 2004.
ACT 2100 pressure plate - Excedy clutch disc
Whats been replace in the last few months:
Outer tie rods
Right front inner tie rod
Sway bar links
Left front control arm
Radiator
2 new 10 inch slim fans
AC does now work, No leaks. Blows out @ 48 degrees
Transmission shifts smooth
All pictures are current as of today
Exterior is a 8 out of 10. It needs a hood and a R/F fender. It was in a accident (minor) before I got her. The hood came off 199 and is rusty. I installed new hood pins to hide the rust
There is some very minor surface rust on the L/F fender by the door
The drivers door I believe will need some hinges. It doesn't line up 100% with the rear door.
Here are some more general pictures.
I have installed a FMIC, I got it for free and didn't leak. Painted it flat black and put it behind the bumper. I didn't see myself ruining something so nice.
Engine Bay
Interior: I would give it a 8 out of 10. It needs some sewing on the drivers seat and the passenger side sun visor needs some love
The drivers seat has developed a rip. Looks like it can be repaired
Has the typical TEL shifter inside
Current interior, need a vacuum.
2 Pillar gauge pod with Prosport Boost (mechanical) and Oil Pressure (Electronic)
JVC CD player, HKS Type O tubro timer. Sorry, the XM wont stay.
Under body:
The 4 Wheel Steer is still intact and does not leak.
The ABS fuse has been pulled, and light removed for cluster. I started to removed the Electronic component.
The downpipe and "cat" need to be replace. The cat broke off at the flange to the I pipe back. I sleeved the cat and slid it inside the I pipe (temp fix so I can drive it to work and back with out getting bothered because of the noise) Will be fixing it in the next 2 weeks
The right front wheel bearing is starting to make some noise, Not lose just starting to make a rotational noise while driving
I have a clean title on hand!
I'm sure I am missing stuff, So just let me know.
Thanks for looking
Cory
Edited by bmxkid415 (07/09/11 03:41 PM)
Posts: 204 | From: Bradenton FL | Member Since: 01/27/08 | IP: (72.185.236.53) | Report this post to a Moderator
Turboman_456
456/1000
Galant VR-4 org Post #: 930367 posted 09/12/10 05:56 PM     Remind Me!  Send Private Message   Edit Post
Valve cover looks good professionally done not cheesy.
If you don't have AWD you don't have SheIit!
Posts: 80 | From: Mason OH | Member Since: 10/24/09 | IP: (24.20.168.48) | Report this post to a Moderator
coreyc123
1755/2000
760/1000
Galant VR-4 org Post #: 930382 posted 09/12/10 07:12 PM     Remind Me!  Send Private Message   Edit Post
u live in ny or flordia
Posts: 29 | From: pougkeepsie ny | Member Since: 03/18/08 | IP: (69.121.96.126) | Report this post to a Moderator
jay4725
Galant VR-4 org Post #: 930393 posted 09/12/10 07:55 PM     Remind Me!  Send Private Message   Edit Post
I think he is in Florida. He said that he made a drive from New York to Florida with no problems.
| | | IP: (98.231.129.50) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 930394 posted 09/12/10 08:01 PM     Remind Me!  Send Private Message   Edit Post
Quoting Turboman_456:
Thanks,I did it one day because I had it laying around. Turned out well.
Coreyc123, I live in Florida now. Car still has NY plates on it and a NY Title.
Cory McGee
1997 Jeep Cherokee - DD/Tow Rig
1992 Galant VR4 #623 - SOLD
1992 Galant VR4 #199 - Parted and Gone
Senior Ricer
1552/2000
Galant VR-4 org Post #: 930664 posted 09/13/10 03:54 PM     Remind Me!  Send Private Message   Edit Post
Please add a location to title as per the rules or the ad will be removed.
Thanks.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (96.246.120.204) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 932745 posted 09/19/10 03:54 PM     Remind Me!  Send Private Message   Edit Post
Weekly bump, Trying to get rid of this so I can start a new project I have in mind. Still 4G63 powered of course.
Cory McGee
smurf
Galant VR-4 org Post #: 933185 posted 09/21/10 06:44 AM     Remind Me!  Send Private Message   Edit Post
PM sent
| | | IP: (72.5.142.135) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 934645 posted 09/26/10 06:44 PM     Remind Me!  Send Private Message   Edit Post
Weekly Bump, I would like to see this car gone. Debt needs to get paid off so I can start over. Toss me an offer
Cory McGee
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 936442 posted 10/03/10 06:27 PM     Remind Me!  Send Private Message   Edit Post
I need the car gone, After a trip to Orlando this afternoon the ACT failed 3 miles from my Apartment. I will take a reasonable offer. I have another clutch and PP to put in it, But if someone wants it before I toss the new clutch in it, Take it and I will leave the other clutch in the trunk. Its just a OEM replacement style.
Looking to get $3,000 OBO at this point. Needs clutch, PP, Plugs and a Knock Sensor (logging phantom knock)
Cory McGee
stealthtt24
Holy deer monkey donkey balls looking for a pole
Galant VR-4 org Post #: 936448 posted 10/03/10 07:02 PM     Remind Me!  Send Private Message   Edit Post
Plugs and a knock sensor are nothing. Sounds like the car just needs some preventive maintenance. Great deal, glws.
91 GVR4s 1332, 1635, 1507, all sold
Posts: 2746 | From: Orlando, FL | Member Since: 05/25/05 | IP: (97.173.186.82) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 936493 posted 10/03/10 09:55 PM     Remind Me!  Send Private Message   Edit Post
Quoting stealthtt24:
Thank you for the kind words. I will be ordering all of that from my buds @ STM on Tuesday.
Cory McGee
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 937960 posted 10/08/10 09:00 PM     Remind Me!  Send Private Message   Edit Post
Transmission and Clutch have been fixed
Cory McGee
Edited by bmxkid415 (06/27/11 10:46 PM)
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 942446 posted 10/23/10 05:01 PM     Remind Me!  Send Private Message   Edit Post
Its been a few weeks, Car is back to DD Status. I finshed up fixing the transmission and replacing the blown up ACT disc with a new Excedy disc I had from a past part
out.
Looking to get $3,500 - OBO. Car is going to get cleaned and detailed this week after being pushed around the shop for the past 3 weeks. Will post pictures after that happens.
Cory McGee
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 961191 posted 01/02/11 03:23 PM     Remind Me!  Send Private Message   Edit Post
New Year, and I am still looking to get rid of the Galant. Nothing has changed just installed a new slave cylinder that was leaking. I have driven it to Tampa and back a few times and she is looking for a new home.
$3,500 OBO, Will consider trades for a 1G AWD plus a little extra cash.
Thanks for time,
Cory
Cory McGee
TARZAN
Newbie
Galant VR-4 org Post #: 961437 posted 01/03/11 07:55 PM     Remind Me!  Send Private Message   Edit Post
PM Sent
-Will
Too many toys never hurt anybody
Posts: 12 | From: Memphis | Member Since: 04/26/09 | IP: (76.107.181.237) | Report this post to a Moderator
91NTTalon
Galant VR-4 org Post #: 962934 posted 01/12/11 05:59 PM     Remind Me!  Send Private Message   Edit Post
Lets get a little bump for Cory, BUY ME IM A GALANT
| | | IP: (66.66.167.117) | Report this post to a Moderator
Boostjunki84
Newbie
Galant VR-4 org Post #: 963245 posted 01/15/11 02:32 AM     Remind Me!  Send Private Message   Edit Post
PM Sent.
Adam
Posts: 13 | From: Candler, NC | Member Since: 10/13/09 | IP: (96.36.65.193) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 963555 posted 01/16/11 06:41 PM     Remind Me!  Send Private Message   Edit Post
Adam, Never got your PM. I sent you a PM though.
Cory McGee
Posts: 204 | From: Bradenton FL | Member Since: 01/27/08 | IP: (97.97.90.92) | Report this post to a Moderator
drf3576
Newbie
Galant VR-4 org Post #: 963562 posted 01/16/11 07:45 PM     Remind Me!  Send Private Message   Edit Post
pm sent...
Posts: 0 | From: North Port, FL | Member Since: 01/16/11 | IP: (68.56.241.136) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 966270 posted 01/29/11 07:32 PM     Remind Me!  Send Private Message   Edit Post
Been awhile. Looking to really get this thing gone.
New shift cables
Serviced the Trans
Service the T Case
Oil Changed.
New Plugs
Just needs a knock sensor, AC pig tailed fixed on the T stat housing and its good.
Cory McGee
4orced4door Galant VR4.org Moderator
Out Standing
Galant VR-4 org Post #: 966276 posted 01/29/11 08:38 PM     Remind Me!  Send Private Message   Edit Post
Looks like a good deal. If I were in the market I'd be tempted, never bought one from so close before. GLWS.
'17 GTI Sport, '02 V70
96/1000, 229/1000, 1788/2000... a long time ago
Posts: 9846 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (24.250.164.33) | Report this post to a Moderator
3rdstrikedsm
Now mandatory for Wendy's Chili to come with cheese
Galant VR-4 org Post #: 966281 posted 01/29/11 09:49 PM     Remind Me!  Send Private Message   Edit Post
I am in the market for one but just can't bring my self to buy one that has not lived in a southern state all of its life however at this price it should go quick.
1994 supra 6spd 612whp and more to come soon!
1995.5 Audi s6 Vi-pec powered!
Posts: 3402 | From: 32159, FL | Member Since: 02/18/08 | IP: (71.52.116.44) | Report this post to a Moderator
bmxkid415
623/1000
199/1000
Galant VR-4 org Post #: 966372 posted 01/30/11 01:51 PM     Remind Me!  Send Private Message   Edit Post
3rd strike. The car is from VA and only seen a few months of NY winter. Not lying when I said I washed it daily, Even the under body on my lift.
Cory McGee
Out Standing
Galant VR-4 org Post #: 966375 posted 01/30/11 02:18 PM     Remind Me!  Send Private Message   Edit Post
Yeah the bumper support and shock towers look pretty rust free. I usually look at the radiator brackets too but they are missing. You might want to throw up some underbody shots since you're down south where we usually don't want rusty cars from up north.
Pages: 1 | 2
2 registered and 10 anonymous users are browsing this forum.
Generated in 0.093 seconds in which 0.047 seconds were spent on a total of 15 queries. Turbo powered.
