Hey guys, I have the option of getting a Garrett GT2052V variable geometry turbo for a rediculously cheap price - it was pulled from a VAG 2.5 V6 turbo diesel engine and has done less than 1000kms. Pic here:
Now I don't know a great deal about VG turbos but have a general idea on how they work, but for all you turbo buffs I would like some advice before committing to buying it.
For starters is the GT2052V an ideal size for a 4G63 SOHC engine? It will be the DASH engine bored out to 2.1L (using 86.5mm pistons), I am wishing to run it on moderate boost levels of about 15psi, and I would be hoping to achieve 175-200kW ATW (will be multipoint inj with megasquirt, modified VR-4 cooler with 2.5" piping, 3" exhaust etc)
Secondly is the GT2052V even suitable for petrol engines? Given that it's on a diesel they typically run with lower EGT's, so am unsure how the GT2052V will cope with the higher EGTs of a petrol engine. There are a few factory petrol cars out there which run VGT's but not the GT2052V specifically (well, as far as I know).
Lastly, how would I go about controlling the vanes? The GT2052V doesn't appear to have a built in waste gate but it does have an actuator which controls the vanes, which from a general glance looks like your typical vacuum/boost activated wastegate actuator - is it simply a case of hooking the vane actuator up to a boost/vacuum source and away it goes, or is there typically a more complex controller involved? With the diesel I'm guessing the turbine is adequately designed so it full boosts a certain amount when governed by the vanes, but with the petrol am I likely to go beyond this boundary?
I was otherwise going to use the Evo3 16G but I like the idea of a VGT being able to spool much earlier and provide boost all the way through the rev range. I'm not after all out power but more so very drivable power with a good dollop of mid range torque and some power right until the 7000rpm redline.
I hope this all makes sense! Any comments appreciated!
