Galant VR-4 Forums » Galant VR-4 » Technical Discussions » This dont look right to me....
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 920688 posted 08/05/10 09:26 PM     Remind Me!  Send Private Message   Edit Post
Ok, im still trying to diagnose this noise im hearing . Now is it just me or do these pics of my driveshaft look a little out of wack and possibly cause my car to make weird noises/vibrations when im decelerating in gear. Now what your looking at is the front yoke going into the transfercase and some view looking to the rear from the front, to me looks like its at a crazy angle. i went to one of my fellow dsm friends house and took a look at his driveshaft and his doesnt look like mine, his looks alot straighter then mine. Their kind of hard to see but ill try to get more pics if u guys cant see what im talking about. Please let me know this noise is bothering me.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1633 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (76.229.145.19) | Report this post to a Moderator
Whoodoo
buff guys = good time but my dream is to fondle 1051
62/2000
Galant VR-4 org Post #: 920715 posted 08/05/10 11:01 PM     Remind Me!  Send Private Message   Edit Post
This has been covered pretty thoroughly. I think one solution to the driveline decel noise is to check relative driveshaft angle. Get an angle finder and try to get the different sections of the driveshaft to be as close to the same angle as possible by putting stainless washers under the carrier bearing bolts.
The reason why this happens is because a universal joint creates dissimilar angular velocities between the slave and drive shafts when an angle exists between them.
Searching '+decel +noise +solution' yields the thread I was referring to.
62/2k
Posts: 923 | From: Binghamton, NY | Member Since: 07/11/09 | IP: (98.111.86.120) | Report this post to a Moderator
bmod530
88/2000
Galant VR-4 org Post #: 920720 posted 08/06/10 12:01 AM     Remind Me!  Send Private Message   Edit Post
Maybe your front and/or rear roll engine mounts are shot?
Biking is life. Everything else is just waiting.
Posts: 80 | From: Salt Lake City, UT | Member Since: 05/23/10 | IP: (76.216.174.101) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 920722 posted 08/06/10 12:03 AM     Remind Me!  Send Private Message   Edit Post
i know i can find the angles with a angle finder but i replaced the driveshaft support mounting metal bushings that tunersnation sells, so theoredacly all the angles should be right, and they do. But not the front section of the driveshaft that looks more off then the rest of the driveshaft. Which makes me belive thats were my noise is coming from, but the question is why is it like that, whats causing it to be off at a angle like that. is it the way my engine and trans are mounted.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 920723 posted 08/06/10 12:04 AM     Remind Me!  Send Private Message   Edit Post
Quoting bmod530:
+1
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (71.83.255.249) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 920725 posted 08/06/10 12:07 AM     Remind Me!  Send Private Message   Edit Post
You look to have a combo issue, sagged out motor mounts & wasted carrier brg mounts.
try this, with the hood up give it a little load in forward & watch the engine movement, again in reverse. while with stocker mounts you should see a little movement I guessing your going to see a lot, like a couple inches. I.e. motor mount time.
as for the drive shaft you can center up the brgs & inject a little 3m window weld into the mount to take up some slack, if that helps then start budgeting for having your driveline done. the fact joints are non-serviceable. so, source a driveline shop to replace the u-joints & install new carrier brgs. You can source the brgs to save a few bucks but it's probably best to let then source the joints. Make sure they also balance the assembly.
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (76.176.146.238) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 920726 posted 08/06/10 12:09 AM     Remind Me!  Send Private Message   Edit Post
Guess we all hit this post at the same time
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 920727 posted 08/06/10 12:12 AM     Remind Me!  Send Private Message   Edit Post
Quoting bmod530:
i replaced all motor mounts besides the one in the rear of the engine with polyurethane mounts. Now when i did that, the poly mount mounting holes were not offset like a normal oem mount would be. so i modified the passanger and front motor mount brackets so the bolt can go threw the motor mount. idk if i mesured wrong and thats causing my driveshaft to look like that or make the noises. not sure but i was thinking about that, but it was making those noises before i did them, but its still in the back of my mine.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 920728 posted 08/06/10 12:15 AM     Remind Me!  Send Private Message   Edit Post
Quoting SouthCaliVR4:
replaced all driveshaft support mounts and mounting holes bushings already.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 920729 posted 08/06/10 12:16 AM     Remind Me!  Send Private Message   Edit Post
if you guys notice in the pic that the driveshaft looks like its not all the way in the transfercase. beacause of the angle
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 920730 posted 08/06/10 12:23 AM     Remind Me!  Send Private Message   Edit Post
ok, but it really does appear from the pics that you motor angle is off. you may have duplicated the same bad angle when you did the mounts.
bmod530
88/2000
Galant VR-4 org Post #: 920756 posted 08/06/10 03:33 AM     Remind Me!  Send Private Message   Edit Post
If you doubt your own work, that is the first place to check. Not hatin, just sayin...
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 920773 posted 08/06/10 08:07 AM     Remind Me!  Send Private Message   Edit Post
i mean if it was my mistake on how i did the motor mounts im gonna try to correct it, and hopefully that fixes the problem
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
475/1000
Galant VR-4 org Post #: 920777 posted 08/06/10 08:48 AM     Remind Me!  Send Private Message   Edit Post
Quoting MellowVR4:
Quoting bmod530:
What do you mean modified.I you just drilled the holes bigger now you have slop in the system. Remember if you open up the hole even a 1/16 of an inch at 2ft away 1/16 is probably 3 degrees. 2ft being the centerline distance from the front mount to the rear of the transfer case. Also the factory mounts being offset means worn out from years of having 500+ lbs and a few G's of force being applied constantly. I think from the factory there a little sagged but no where what a worn mount is.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11891 | From: Clarksville TN | Member Since: 05/04/03 | IP: (208.95.177.176) | Report this post to a Moderator
Gizmovr4
Member +
431/1000
584/1000
Galant VR-4 org Post #: 920910 posted 08/06/10 05:50 PM     Remind Me!  Send Private Message   Edit Post
That picture looks familiar. When I bought 431 the transfer case to driveshaft looked just like that. Turns out that someone who owned the car before I got a hold of it had replaced the motor with a 1g and didn’t realize that the front mount bracket for the VR4 is different. I would check the front motor mount bracket I think it should have a 244 stamped on it for a Vr4 if memory serves me right… 1g front mounts are different and will give you the result your looking at…this is the bracket that is bolted to the block and attaches to the motor mount that goes to the radiator support (the one below the turbo)
Nate Crisman Racing www.performancepartout.com
Vinny Ten Racing click
431/1000 [email protected] 584/1000 556AWHP
Edited by gizmovr4 (08/06/10 06:30 PM)
Posts: 366 | From: andover,NJ | Member Since: 11/18/09 | IP: (24.152.235.109) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 921104 posted 08/07/10 05:32 PM     Remind Me!  Send Private Message   Edit Post
+1 ^^^^
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1548 | From: Midlands, UK | Member Since: 08/04/04 | IP: (83.67.97.128) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 921108 posted 08/07/10 05:40 PM     Remind Me!  Send Private Message   Edit Post
Quoting MellowVR4:
Quoting bmod530:
This is probably your problem. The reason the OEM bushings are offset is that they're expected to sag under the weight of the engine. The poly bushings are more rigid and don't sag so they aren't offset. By modifying the mounting brackets you made your motor sit fun which is why the t-case is too low and why the prop-shaft is having to droop down and intersect it at an angle.
Roger B. Scott
'91 Belize Green
Posts: 3312 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (174.45.93.14) | Report this post to a Moderator
TurboTrader
Galant VR-4 org Post #: 921627 posted 08/09/10 08:29 PM     Remind Me!  Send Private Message   Edit Post
Did you say you are running the stock rear mount (probably shot), and not the Prothane?
I had the exact problem, I replaced my two sides and front mount with Prothanes, and the driveshaft sat at that angle. It vibrated very badly upon accel. as well. Turns out it was the rear stock mount causing all the problems.
To test the theory I put a block underneath the jack right under the long mount on the rear of the engine block, got it to right center in the mount, and sure enough the propeller shaft was at a perfect angle. Replaced the mount, and the vibration went away completely.
Posts: 161 | From: Pemberton, NJ | Member Since: 01/30/09 | IP: (66.177.164.126) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 923936 posted 08/19/10 08:51 AM     Remind Me!  Send Private Message   Edit Post
the rear mount right, yea i gotta get to work on this asap. ivr been really lazy lately and i miss my beast.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Posts: 1633 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (69.217.173.16) | Report this post to a Moderator
beefajita
153/1000
Galant VR-4 org Post #: 924343 posted 08/20/10 03:56 PM     Remind Me!  Send Private Message   Edit Post
Mine does the same thing. Noise under decel, specific RPMs and load.
Try making your car make the noise while deceling uphill, I bet it goes away.
I actually drive around it when in crowed areas because it is embarrassing to have something soo fast and yet so crappy.
Shep told me it was cause the clutch I have in there is not balanced with engine driveline ect.
but then again, I was asking him to diagnose it over the phone.
It did it with the stock driveshaft (like yours) and it does it with my lightened aluminum driveshaft too.
I had the aluminum one shortened a little this actually helped a little, it made the noise not as awful.
I have tried different rear subframes because it may be the bushings, geometry,etc.
Still made the noise.
Now I have polyurethane mounts on every thing front and back(including the big rear subframe ones that no one can find)
Still makes the noise.
My only hope is sooner or later,(probably later 'cause this one is holdin') I will destroy my clutch only to purchase a "balanced" one
So that I may have a fair and balanced drivetrain, enabling me to engine brake to my hearts desire.
One can dream can't he?
Posts: 39 | From: Ansonia, CT | Member Since: 06/02/08 | IP: (67.87.55.197) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 926333 posted 08/29/10 12:22 PM     Remind Me!  Send Private Message   Edit Post
WHEIR DO I FIND A BALANCED CLUTCH, because im going to change my rear motor mount and see if that fix my problem. If that dont work, im about to give up
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Posts: 1633 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (63.111.38.122) | Report this post to a Moderator
Gizmovr4
Member +
431/1000
584/1000
Galant VR-4 org Post #: 926521 posted 08/30/10 06:31 AM     Remind Me!  Send Private Message   Edit Post
check out this post
having the wrong front mount bracket will cause what you have pictured in your post - did you check to see if the number "344" was stamped on it? this is the bracket that mounts to the block below the turbo.. motor mounts are the same for DSM's but that bracket is different. If the car had a motor swap from a dsm in the past there is a good chance its got the wrong bracket. They look very simular and people dont realize they are different. The wrong bracket will cause the motor to be higher in the front and the diff to be lower in the back...
Edited by gizmovr4 (08/30/10 06:40 AM)
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 957814 posted 12/15/10 02:48 PM     Remind Me!  Send Private Message   Edit Post
so by looking at the pics does this mean my driveshaft is too short
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
Key Fob Guy
Galant VR-4 org Post #: 957819 posted 12/15/10 03:19 PM     Remind Me!  Send Private Message   Edit Post
Would you please address Gizmo's question??
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 957826 posted 12/15/10 03:47 PM     Remind Me!  Send Private Message   Edit Post
Quoting MellowVR4:
Your mounts are mis-matched, you should be able to spot that the engine is not cantered as far forward as it should be. Make sure all four mounts are Galant VR-4 specific and you should be fine.
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.8.48) | Report this post to a Moderator
Pages: 1 | 2
3 registered and 7 anonymous users are browsing this forum.
Generated in 0.213 seconds in which 0.137 seconds were spent on a total of 15 queries. Turbo powered.
