bazeng
Hey guys,
I got bored after work so dropped by Springy Motors for a play on the DYNO COMPUTER.
Enjoy some different specs of my various 4g builds.
E39A 2.4L (my current setup air to air)
E39A 2.3L (my old setup water to air)
E33A 2.3L (my old setup with stockish head and AMG intake manifold)
STIKLR (you guys know that car)
I've had enough dyno play with my car. Time to not break and start racing.
link
What I found interesting was the difference with an ELECTRIC BOOST CONTROLLER vs SPRING PRESSURE on the waste gate.
Also, my old GT30 setup has a much better power band than the new GT35 setup BUT that is based on a full tune vs run in tune. If you compare run in vs run in tune, the 2.4L is better.
Also C16 makes a massive difference doesn't it!! I've got a log that did 400kw's but that isn't really fair coz the block cracked on that run!
STI KLR has run high 11's with his setup and wheel spin, hopefully the VR4 can do better once its out there.
The AMG power curve looks promising! It spools up very well and with more boost, it should easily pump out 300kw's at the wheels on about 20psi (fingers crossed).
What do you guys think?
link
