FS: 97 Eclipse GSX..6 bolt swapped..$5500 Mass
hosmer
taunton, ma
Selling my 97 Eclipse GSX.
135k on the chassis, unknown mileage on the motor but it has been rebuilt
5 speed
tan leather interior
rear LSD (not all GSX's have the rear LSD, it was an option)
all power with working factory alarm
keyless entry (OEM)
Gauge cluster surround pod with oil pressure and wideband o2 gauges
Boost gauge
Motor...was swapped last summer, most parts have 3k or less on them:
6 bolt swap (NO CRANK WALK)
ARP headstuds
Real EVO III 16g turbo
EVO IX 560cc injectors
BC 280 cams (go to the youtube link to hear it idle)
Buchur SX AFPR with gauge
Apexi N1 3" turboback exhaust
Balance shaft delete kit
New timing belt
New water pump
New alternator
New OEM headgasket
All new OEM upper seals/gaskets (from the headgasket up)
Blacktop CAS
Front mount intercooler
ACT 2600 pressure plate with ACT full disc
Runs on a 98/99 (faster processor) reflashed ECU for the motor setup from keydiver/dsmchips.com
7500 redline
4500 2 step stutter box
Emissions check removed
Rear o2 check removed
Random misfire check removed (for the 6 bolt swap)
560cc injector compensation
Deadtime compensation
Octane value reset (93)
Knock sum gauge
NO CHECK ENGINE LIGHT...passes inspection (just did in Dec. as a matter of fact) with no issues using the OBD port
$5500 CASH or for $6500 I'll throw in a set of EVO MR BBS wheels (they need 1 tire) and a set of EVO blue and black Recaros WITH the rails to bolt them into this car....will consider trades as well
Clean Mass title in hand (with MY NAME on it...you know how some of these things go)
Exterior of the car looks OEM except for the front mount...should be a solid 325-350whp car, gets to 60 in 5.56 seconds /ubbthreads/images/graemlins/smile.gif
Car idling in the driveway:
NEW INTERIOR/ENGINE PICS
THE CAR WILL COME WITH AN OEM STEERING WHEEL AND SHIFT KNOB...also, I do have the side plastic trim for the center console, pic was taken when I swapped in the new ECU
4G63_GSR
wis
can't view YT or your pics at work but seems like a great car. wish you were closer. good luck with the sale.
sixsixtwo
St. Paul, MN
Good luck with the sale, looks like a clean and well put together GSX. Definitely a bargain at that price.
