Galant VR-4 Forums » Galant VR-4 » Newbies » I'm a n00b
I'm a n00b
hk20000
Galant VR-4 org Post #: 862203 posted 01/03/10 06:16 PM     Remind Me!  Send Private Message   Edit Post
With a n00b car.
It's not a E39A to begin with.
I brought in a JDM Mitsubishi Galant VR4 (The uber rare gap filler/marketing failure between the E39A and the EC5A). I will be posting here for random questions about this car when they show up. So far the common things between this and a E39A is:
1. the 4WS system - Valves driving the rear rack controlled by a computer thingy
2. the front brakes - same setup. Same 4x114.3 as well
That's all that is common between a E39A and a E84A I would think?
I'm located just 30min away from the US border in Canada where 15 y/o JDM imports are easily registered and used on the roads. Nice to meet you.
Edited by hk20000 (01/03/10 06:18 PM)
| | | IP: (24.86.182.100) | Report this post to a Moderator
CSMShaun
981/2000
Galant VR-4 org Post #: 862207 posted 01/03/10 06:45 PM     Remind Me!  Send Private Message   Edit Post
That is a nice looking car. Good luck!
Posts: 129 | From: Cincinnati, OH | Member Since: 01/02/10 | IP: (65.27.144.103) | Report this post to a Moderator
dmj
Rod Stewart
998/1000
Galant VR-4 org Post #: 862210 posted 01/03/10 06:47 PM     Remind Me!  Send Private Message   Edit Post
Welcome to the board .please post some pics of the engine.
Posts: 673 | From: orlando FL | Member Since: 02/02/08 | IP: (71.55.188.244) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 862284 posted 01/04/10 02:08 AM     Remind Me!  Send Private Message   Edit Post
You are right, not alot is the same between the two. The front brakes are the same 276mm twin pots but the rears are 284mm vented with internal drum handbrake rather than handbrake on the caliper of the E39A.
Gearbox and rear diff is the same or similar to Lancer Evo 1-3. The 6A12 V6 motor makes same power and torque stock as the Evo VR-4 4G63, but it just seems to be more livelier and sounds fantastic through the rev range. Unfortunately there isn't a great scope of performance for the motor, its main limitations are the two tiny turbos and the small lightweight rods the 6A12 uses. If you push the engine over 300hp or so they start to bend or snap rods and chuck a leg out of bed.
The multi link suspension all round is an improvement over the E39A however they are a bit more complex and the front suspension is prone to both bottom lower ball joints failing on each side.
The E84A isn't that rare at all, a great deal were produced between 1992 and 1996 in both sedan or sports hatch. You can even get them in E74A which is without 4WS.
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.61.59) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 862285 posted 01/04/10 02:31 AM     Remind Me!  Send Private Message   Edit Post
^ Maybe Canada was like the US and got denied the 7G VR-4s? So may very well be pretty rare for this side of the world.
Anyway, Welcome, I'm about 2hrs south of the border to Canada, though I see Canadian plates everyday it might as well be Canada down here.
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Edited by raptorreed (01/04/10 02:31 AM)
Posts: 2721 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (98.203.132.229) | Report this post to a Moderator
conquesttsi
1933/2000
Galant VR-4 org Post #: 862352 posted 01/04/10 12:28 PM     Remind Me!  Send Private Message   Edit Post
Welcome. Nice car. This site is really geared twards the 6th gen e39a platform. I would reccommend also checking out the thegalantcenter.net which is based on the 7g platform. Best of luck with her, she's a beaut.
1933/2000
91 Eclipse GSX
93 Mirage
Posts: 209 | From: Northern Connecticut | Member Since: 02/04/09 | IP: (12.111.74.5) | Report this post to a Moderator
hk20000
Galant VR-4 org Post #: 862478 posted 01/04/10 09:03 PM     Remind Me!  Send Private Message   Edit Post
Quoting fuel:
Canada and US shared the same MMNA cars which means we never had one of these here (Over the whole continent only Mexico was somehow granted this model)In Canada it's rare to get this bodystyle at ANY trim at all because Mitsubishi was not present in Canada until this century. (They entered the Canadian Market only in 2001)
so it's rare as can be. In fact, if you have accessed Mitsubishi ASA Japan for the total number of cars made in this specification (2000DOHCMPI/4WD/4WS+SEDAN) there are less than 2000 absolutely. Which means it's actually more rare than a E39A worldwide. E74A is sort of a VR4 without 4WS and it's a Galant Sport with a hatchback chassis. E84A itself is quite rare.
The engine won't do any good boosted over 300HP (which I think I'm doing now with a boost up and big intercooler, IHE, custom map and tuning) So I'll keep it like this for a while until I can afford to build a 4G63/4 for this. I think a 4G64 is more suited for this car because of its size and weight (a whopping 1540kg compared to E39A's scant 1340kg) the low end torque characteristics feel more at home with it. It's not a white knuckled street racer/rally thoroughbred this is more about like highway cruise missile. A little lazier engine that gets the going early would be my kind of ride.
That's why I think later down the road I'll have more questions which you guys can answer me, when I pop in a E39A-like engine in there.
Yes I've been to thegalantcenter but those guys with the 7G are always playing that one trick game like boosting the SOHC 4G64, swapping heads, etc. recently someone's been trying to do a self-VR4 conversion but very little information comes out of it because most of it was custom fab anyway. Then the rest of the 7G crowd is still living in the 90s putting on bodykits and lowering the car with cut springs or whatever.....that's not my scene.
I'm well aware of the lower ball joint situation and a quick inspection of the undercarriage shows that the lower arm had been replaced recently with a fresh Mitsubishi Genuine parts sticker still wrapped around it so I'm not worried.
Thanks for the information.
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 862480 posted 01/04/10 09:11 PM     Remind Me!  Send Private Message   Edit Post
Welcome to the board. Got any vids/more pics of this thing? I bet it sounds cool. Nice car man.
2003 Evo
2001 Prelude
2018 JK Wrangler
2002 Honda Odyssey
Posts: 1942 | From: Oceanside, CA | Member Since: 04/25/07 | IP: (98.164.232.199) | Report this post to a Moderator
Galant VR-4 org Post #: 862577 posted 01/05/10 05:55 AM     Remind Me!  Send Private Message   Edit Post
Quoting hk20000:
Rubbish there is only 2000 of them made, if thats the case then all 2000 made their way to New Zealand - there are a large amount of them here!
E74A is not specific to the Hatch, it just so happens the Hatch doesn't come in 4WS so it is an E74A. There are almost as many E74A non-4WS sedans as there are E84A 4WS sedans.
Also the weight difference between E39A and E84A isn't as great as you've made it out. My j-spec VR-4 Evolution in 5spd is 1410kgs, while a j-spec 7G E84A VR-4 5spd is 1430kgs. The E74A sedan is 1410kgs. The heaviest model is the automatic Hatch, which even that is only 1480kgs.
Galant VR-4 org Post #: 862578 posted 01/05/10 06:03 AM     Remind Me!  Send Private Message   Edit Post
If you want rare, then try finding a 7th gen Eterna XX-4. Basically an automatic E84A Galant wearing different clothing.
Dbossman
Galant VR-4 org Post #: 862610 posted 01/05/10 11:27 AM     Remind Me!  Send Private Message   Edit Post
Do you have a 7th gen. pic of that eterna xx-4? I would love to see that.
Welcome to the board.......I think it's sexy
| | | IP: (32.169.86.140) | Report this post to a Moderator
Galant VR-4 org Post #: 862749 posted 01/05/10 10:45 PM     Remind Me!  Send Private Message   Edit Post
Here's a couple pics from one which is for sale at the moment - click
They are all automatic and usually have a brown interior
And here's a facelifted Eterna Visage (not turbo) which looks slightly better
Annnnndd.. before I go there was also another variant of the 7G which like the Eterna was released in the Japanese market only, called the Emeraude. The Emeraude had pillarless windows and more of a coupe body style.
The interior is different too, while it retains the same dashboard the door cards and the rear seats are totally different
The facelift version of the Emeraude has cool tail lights too
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.39.88) | Report this post to a Moderator
Dbossman
Galant VR-4 org Post #: 862815 posted 01/06/10 10:16 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the pics. I definitely like the face lifted front, and the emeraude tails. Is that the same power plant as the gvr4(twin turbo'd v6)?
| | | IP: (166.132.207.238) | Report this post to a Moderator
Galant VR-4 org Post #: 862851 posted 01/06/10 12:37 PM     Remind Me!  Send Private Message   Edit Post
yep the same 6A12 twin turbo V6, the autos only make 215hp instead of the 240hp the manual models make.
hk20000
Galant VR-4 org Post #: 863139 posted 01/07/10 05:25 AM     Remind Me!  Send Private Message   Edit Post
heh I mean rare but those XX-4 Emeraude Eterna things are just unicorns LOL.
Anyway here to post some videos I just put on a Eclipse D33A catback exhaust into it. It's almost bolt on except the fact that E84A is a little longer than the D33A so I had to have that extended.
the more interesting version of this is the Proton Perdana I don't know if they came with the 6A12 but this seems fun
enjoy.
hk20000
Galant VR-4 org Post #: 867524 posted 01/22/10 11:20 AM     Remind Me!  Send Private Message   Edit Post
I took some pics of my engine bay and interior (actually I have been trying to sell this damn car for like over half a year now) so i thought I'd share with you here too.
I run a GM MAF-T because it corrects the atmosphere BOV stalling problem with the factory MAF.
Previous owner had a tweeter in the door card and it was busted as fuck, so I replaced it with a Kenwood and covered the hole with cardboard LOL. I might go find someone who does upholstery to help me fix that eventually.
Even though I put the car on sale locally I am in no hurry the car puts out 230AWHP at the wheels after my boost up and fat 3" exhaust at 17psi so it is quicker than a lot of things on the road and after my tune up menu it's very reliable
Also recently I have installed an SR-S 3" catback exhaust to the car because the factory muffler has collapsed. here is a clip of the sound of it:
VR4 6A12 SR-S exhaust sound clip
Edited by hk20000 (01/22/10 11:32 AM)
| | | IP: (174.6.152.103) | Report this post to a Moderator
Rjukan
Galant VR-4 org Post #: 867525 posted 01/22/10 11:28 AM     Remind Me!  Send Private Message   Edit Post
Cool pics, what's up with the center vent tho?
OT but is weed legal there in BC? There has been a rumor that it's been decriminalized to such an extent that there are actually amsterdam-esque coffee shops there. Is that true?
Glws btw, nothing like owning a car you can't stand anymore.
| | | IP: (166.137.139.142) | Report this post to a Moderator
hk20000
Galant VR-4 org Post #: 867528 posted 01/22/10 11:36 AM     Remind Me!  Send Private Message   Edit Post
heh center vents are all broken Asians like to hang their cellphones and extra large slurpees with their add-on cupholders there...
so I improvised a cellphone stand on the right vent that will feed my MP3 into the HU
with the phone built in GPS and MP3 capability this adds a whole slew of functions to my car's ICE.
Weed? What? I don't know I got some from the guy down the street yesterday, it was some goooood shit.
I can stand it but I can't afford it LOL. I have to commute like 70-80km everyday I want something more economical now like a Yaris or Fit or something.
But while I can't afford it I should enjoy it to the fullest while it's still mine hehehe
Edited by hk20000 (01/22/10 11:39 AM)
dollaricd885
Galant VR-4 org Post #: 867782 posted 01/23/10 06:19 AM     Remind Me!  Send Private Message   Edit Post
i want to see pics of the AMG in the garage. nice galant also!
Edited by dollaricd885 (01/23/10 06:20 AM)
| | | IP: (66.109.162.90) | Report this post to a Moderator
Dbossman
Galant VR-4 org Post #: 867813 posted 01/23/10 11:19 AM     Remind Me!  Send Private Message   Edit Post
+1 on the coffee shop thing? You definitely should check it out. Probably were your boy down the street snags it up, and marks it up on you....lol!
| | | IP: (32.169.111.171) | Report this post to a Moderator
hk20000
Galant VR-4 org Post #: 867821 posted 01/23/10 11:36 AM     Remind Me!  Send Private Message   Edit Post
in downtown there's a smoke-up bar where you bring your own weed they can rent you bongs to smoke it....
Here's the AMG picture:
oh is that too dirty for you? Here let's have it washed up:
Dbossman
Galant VR-4 org Post #: 867838 posted 01/23/10 12:33 PM     Remind Me!  Send Private Message   Edit Post
I don't know what's sexier.... The big body......or the little sexy body!
| | | IP: (32.169.155.215) | Report this post to a Moderator
dollaricd885
Galant VR-4 org Post #: 868018 posted 01/24/10 09:10 AM     Remind Me!  Send Private Message   Edit Post
very nice!
Galant VR-4 org Post #: 868229 posted 01/24/10 11:42 PM     Remind Me!  Send Private Message   Edit Post
I have a 7G too, except mine is a VX-R rather than a VR-4, even more rarer with the 6A12 MIVEC-MD engine, in normally aspirated form it puts out 200hp and looks the same as a VR-4 and even has the same large vented brakes
I also had an 8G wagon too (called a Legnum) with 2.5L V6 and 4WD, but recently sold it
Posts: 2115 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (118.90.49.159) | Report this post to a Moderator
hk20000
Galant VR-4 org Post #: 868586 posted 01/26/10 02:50 AM     Remind Me!  Send Private Message   Edit Post
a VX-R is great MD = Modular Displacement = your car runs on 3 cylinders only when it's not under load (such as being on the highway and such)
is it AWD?
| | | IP: (72.25.192.4) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.384 seconds in which 0.292 seconds were spent on a total of 15 queries. Turbo powered.
