Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Install 264's, new lifters - can not get car to idle
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 849333 posted 11/13/09 09:12 AM     Remind Me!  Send Private Message   Edit Post
Idled fine prior to cam and lifter install - nothing else changed. simply can not get the car to hold idle. BISS out all the way, tried adding/subtracting fuel on safc, even screwed in closed throttle position switch to see 10% throttle and it simply mugs down and dies. Keydiver chip set to 1000rpm idle.
Any ideas appreciated -
Colin
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (24.101.86.160) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 849353 posted 11/13/09 10:06 AM     Remind Me!  Send Private Message   Edit Post
no boost leaks - ran test the other day.
Olson suggested advancing CAS a little - gonna try that in a min...
Assmilk Pearl
Galant VR-4 org Post #: 849357 posted 11/13/09 10:22 AM     Remind Me!  Send Private Message   Edit Post
Are you setting the BISS properly per VFAQ?
-mitsuturbo
Posts: 18893 | From: Flemington, NJ | Member Since: 09/11/03 | IP: (12.165.240.116) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 849361 posted 11/13/09 10:40 AM     Remind Me!  Send Private Message   Edit Post
well - if you back the thing out it will raise the idle, tighten it and you get the opposite effect. I HAVE IT BACKED OUT ALL THE WAY TO WHERE IT WILL STILL SEAL - this should result in a pretty high idle under normal circumstances. All fiac crap is gone.
Fact remains the thing idled fine and after cam install I can not get it to hold idle...
Assmilk Pearl
Galant VR-4 org Post #: 849362 posted 11/13/09 10:43 AM     Remind Me!  Send Private Message   Edit Post
Well - good thing you personally never asked or cared about driveability!
-mitsuturbo
Muskrat
665/2000
Galant VR-4 org Post #: 849368 posted 11/13/09 11:02 AM     Remind Me!  Send Private Message   Edit Post
Quoting steveGLS:
I think what he meant was, "Are you grounding the ignition timing plug and pin 10 on the diagnostic plug before you adjust the BISS?"
Brian L.
91 Galant VR-4 #665/2000
Posts: 2105 | From: Lexington, KY | Member Since: 06/13/04 | IP: (12.188.154.180) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 849370 posted 11/13/09 11:10 AM     Remind Me!  Send Private Message   Edit Post
Quoting steveGLS:
touche salesman - I too have an uncle...
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 849372 posted 11/13/09 11:13 AM     Remind Me!  Send Private Message   Edit Post
Oh now I see how you're keeping track of me Steve - you have over 16 THOUSAND posts. Jimminy Christmas...
nice admin duties son!
now do you have any ideas for me?!?
Edited by sleepyvr4 (11/13/09 11:15 AM)
Rock Star Status
Galant VR-4 org Post #: 849374 posted 11/13/09 11:24 AM     Remind Me!  Send Private Message   Edit Post
+ towardstjose
HOnestly- go back and reset following VFAQ- then start to rule things out- check timing again etc. Teh more you know is right, the less you'll have to look at
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (63.253.227.122) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 849377 posted 11/13/09 12:00 PM     Remind Me!  Send Private Message   Edit Post
Is your cam timing right?
Are you sure?
Are you positive?
**Edit: One tooth off on the intake manifold will kill the idle, one tooth off on the exhaust and the car will run, but not well and you won't have power. If the crank is off by one, it may barely start if at all. that's been my experience with timing the 4g63 and being off.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Edited by prove_it (11/13/09 03:19 PM)
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (24.220.12.198) | Report this post to a Moderator
rgeier11
sled driving mullet brain
Galant VR-4 org Post #: 849385 posted 11/13/09 12:18 PM     Remind Me!  Send Private Message   Edit Post
I agree with prove it. It sounds like you did the timing belt job wrong.
1992 GVR-4 #649/1000 SOLD
1998 3000GT VR4 1of19 in New Zealand Green
1992 TSI AWD
Posts: 726 | From: Chicago Suburbs, IL | Member Since: 09/26/04 | IP: (209.7.13.194) | Report this post to a Moderator
Garage_Defeat
Fastest Member
Galant VR-4 org Post #: 849580 posted 11/14/09 12:01 PM     Remind Me!  Send Private Message   Edit Post
Did you check ign timing with a timing light?
www.RaceTuned.com
'92 "Heavystrike" Nile Black / (FP HTA 3794 T3) 9.4 / 153mph
'91 "Street/HPDE" Summit White / FP Green XL
'92 "Time Attack" Kensington Grey
'91 "Hawaii Car" Nile Black
Posts: 566 | From: Ohio, USA | Member Since: 02/02/03 | IP: (71.54.70.107) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 849586 posted 11/14/09 12:09 PM     Remind Me!  Send Private Message   Edit Post
You suck at mechanics
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (216.211.253.147) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 852153 posted 11/24/09 08:19 AM     Remind Me!  Send Private Message   Edit Post
lmfao - you all suck.
the timing is dead on. fuck a timing light - there is no cover. it takes .5 seconds to take off the crank pulley and
WAMMO!
Timing is dead on. I don't put timing belts on wrong. Especially on this dumpster chicken - there is nothing to it.
Everything is eliminated.
THE ONLY THING THAT I CHANGED WAS THE CAMS ,and now doesn't want to idle...
Why the F would changing to 264's affect the idle? People drop 272's w/o dealing with this...
Posts: 2359 | From: Key West | Member Since: 12/25/03 | IP: (24.144.224.147) | Report this post to a Moderator
solidviper89
Patty Purex
0425/2000
Galant VR-4 org Post #: 852156 posted 11/24/09 08:22 AM     Remind Me!  Send Private Message   Edit Post
Maybe the cams aren't what they appear to be...
Posts: 759 | From: Mission/ San Antonio, Texas | Member Since: 08/19/04 | IP: (129.115.146.12) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 852190 posted 11/24/09 10:42 AM     Remind Me!  Send Private Message   Edit Post
Quoting sleepyvr4:
WAMMO!
You had to have changed something. Even 272's won't completely kill an idle. Going off like this only makes it harder for you to see a simple mistake when you make one. If you believe your right at all costs you'll only miss something. I am an auto tech and I learned that lesson. Retrace your steps,
One other possiblity and in a long shot is that the lifters are not bleeding down which would hang the valves open just a tad. When you put in a bigger cam the lifters are set for the smaller cam and once installed the bigger cams can push the valves open a bit. Do a compression test and see what the results are. Check all four cylinders and post the results.
**edit: We are trying to help, and being rude will get you ignored. **
12yr+ Vr4 owner.
Family Guy
Edited by prove_it (11/24/09 10:45 AM)
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 852191 posted 11/24/09 10:43 AM     Remind Me!  Send Private Message   Edit Post
Hmmmm - HKS cams stamped with lift information from a reputable source (Curt Brown) - I imagine they are proper.
By the way - the timing belt was never removed when these cams were installed - one cam was installed at a time with the t belt zip tied to each cam gear.
Rock Star Status
Galant VR-4 org Post #: 852194 posted 11/24/09 10:54 AM     Remind Me!  Send Private Message   Edit Post
Intake and exhaust cams in the correct locations? (Just throwing that out there)
Rance lives here...
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 852221 posted 11/24/09 12:34 PM     Remind Me!  Send Private Message   Edit Post
wow. please tell me how the hell you install them incorrectly. please. somebody? rufs? there is a slot for the cas on the intake cam. I think even CP could get that one right...
Rock Star Status
Galant VR-4 org Post #: 852224 posted 11/24/09 12:36 PM     Remind Me!  Send Private Message   Edit Post
Ebo cams and regrinds were what was in my head. If you're sure they are what they are, then I gots nothing.
CarRacer
Giant Sack of Ginger
83/2000
Galant VR-4 org Post #: 852226 posted 11/24/09 12:38 PM     Remind Me!  Send Private Message   Edit Post
If it takes half a second to check the timing why did it take you ten days to figure it out?
James
83/2000
Missed Shift | Auto News
Posts: 4370 | From: Shakopee, MN | Member Since: 06/28/07 | IP: (166.137.139.3) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 852238 posted 11/24/09 01:07 PM     Remind Me!  Send Private Message   Edit Post
I never changed the timing. It idled fine, then it didn't. I've since had the head off and on twice lol. Been busy with other issues. Still won't idle.
Who know's what's up with the cams. they are used. maybe that's why I ended up with them for free lol...
charmcity
keeping yawll posted
357/1000
Galant VR-4 org Post #: 852248 posted 11/24/09 01:33 PM     Remind Me!  Send Private Message   Edit Post
My guess is wrong cam in car maybe its in right, just in the wrong car....
I wonder what 40psi feels like?
Official jackstand Baller!!!
Posts: 283 | From: baltimore | Member Since: 10/19/07 | IP: (12.13.141.101) | Report this post to a Moderator
sleepyvr4
I Hate Kitty Cats
Galant VR-4 org Post #: 852251 posted 11/24/09 01:42 PM     Remind Me!  Send Private Message   Edit Post
I know all setups are different but damn - it was fine prior, stock 92 cams are around 250ish.
I keep monkeying around with the fuel, biss, etc. and no matter what when it falls through the r's it chugs to stay alive a few times under 1000 rpm and dies. Almost like there isn't enough rotational mass or something (ACT fly)
RayH
561/1000
Galant VR-4 org Post #: 852257 posted 11/24/09 01:58 PM     Remind Me!  Send Private Message   Edit Post
Try swapping stock cams back one at a time?
Posts: 2697 | From: NJ | Member Since: 04/09/01 | IP: (68.196.154.179) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8
1 registered and 53 anonymous users are browsing this forum.
Generated in 0.241 seconds in which 0.202 seconds were spent on a total of 15 queries. Turbo powered.
