Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Evolution X suspension
johnnyRacer
Member +++
50/2000
Galant VR-4 org Post #: 845921 posted 11/03/09 02:31 AM     Remind Me!  Send Private Message   Edit Post
I was looking at the Evo X suspension. The front seem the same as the VIII and IX. The rear shocks however look like ours without the lower fork, but with a regular lower mount that you slide onto the stud and bolt it to the car. It seems to me this would make the Evo X a simple bolt on affair. Or Evo 8-9 front and Evo 10 rear suspension set up.
91 GVR4 SW 0050/2000 -sold
-3gMAS/K&N,680cc,BSE,chip,255lph,3"Exh(no cat),H.MBC,evo8/tein-S
87 Conquest TSI
92 Mustang LX Convt-sold
95 BMW E36 Convt-sold
13 F-150 Coyo
Posts: 776 | From: Chicago | Member Since: 01/09/05 | IP: (99.23.129.208) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 845922 posted 11/03/09 03:01 AM     Remind Me!  Send Private Message   Edit Post
it's been discussed before and it would be one of those things you would have to try out yourself, however the Evo X does look to have a higher stance than a Evo 8/9 and thus might make our cars just look the same or maybe even more of a monster truck. click
And reference to this thread of the various spring sizes
Spring comparison
I had a 1g dsm friend ask me the same thing as he had acquired a set of Evo X stockers.
Here's a pic of them, now I know for sure those rear springs are definitely much taller than the Evo 8s I have on my car. Let's see what the Veterans say. My friend said the rear springs are within a inch of the same height as his stock springs, to me that would mean there wouldn't be any difference in height then, correct?
92 Galant VR-4 362/1000
76 Galant Coupe
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Edited by raptorreed (11/03/09 03:09 AM)
Posts: 2718 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (98.203.132.229) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 845933 posted 11/03/09 07:04 AM     Remind Me!  Send Private Message   Edit Post
I had someone send me some measurements & the Evo X rears were ~2" taller than the Evo 8-9. If memory serves me right, the fronts were ~ the same. I can't gurantee these measurements though as I didn't measure the evo X's myself. However looking @ the X, you can see the car has a higher stance.
| | | IP: (174.48.48.131) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 845939 posted 11/03/09 07:46 AM     Remind Me!  Send Private Message   Edit Post
So if the evo X rear suspension is 2" taller than the evo 8-9, then wouldn't work a bit better? I say this becuase when you install evo8-9 suspension you need to cut the front spring to level the car out. I always hate cutting springs so if the evo X suspension is taller in the rear, wouldn't it sit a bit more level without cutting the front springs? I think it may sit taller all around, but a set of lowering springs would fix that, or a set of coilovers for the evo X.
Is my logic correct, or is the 2" too tall?
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (24.220.12.198) | Report this post to a Moderator
Garfield Wright
Galant VR-4 org Post #: 845994 posted 11/03/09 10:14 AM     Remind Me!  Send Private Message   Edit Post
It depends on what you want for your car. If the 4x4 look is what you want then you could bolt-on the Evo X setup & go offroading or have a nice winter setup. Keep in mind that the springs also have a stiffer rate than gvr4 springs so the car will sit really high.
715/1000
1284/2000
Galant VR-4 org Post #: 846005 posted 11/03/09 10:28 AM     Remind Me!  Send Private Message   Edit Post
Even with lowering springs or coilovers?
12yr+ Vr4 owner.
Family Guy
belize1334
1334/2000
Galant VR-4 org Post #: 846006 posted 11/03/09 10:33 AM     Remind Me!  Send Private Message   Edit Post
But at that point you'll be running an effective 2" drop on the suspension just to accomplish a stock-looking ride height. If you wanted to go any lower you'd have to worry about the struts bottoming out. Seems sketchy but if you can find a set cheep then I say go for it.
Roger B. Scott
'91 Belize Green
Posts: 3312 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (72.175.127.40) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 846042 posted 11/03/09 12:10 PM     Remind Me!  Send Private Message   Edit Post
Ah, good point.
12yr+ Vr4 owner.
Family Guy
johnnyRacer
Member +++
50/2000
Galant VR-4 org Post #: 846046 posted 11/03/09 12:30 PM     Remind Me!  Send Private Message   Edit Post
What about using 8-9 rear springs on the 10 shock. If the shocks are the same length then couldn't we just use 8-9 rear springs?
87 Conquest TSI
13 F-150 Coyo
Posts: 776 | From: Chicago | Member Since: 01/09/05 | IP: (206.53.153.120) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 846304 posted 11/04/09 09:25 AM     Remind Me!  Send Private Message   Edit Post
I would say the springs are longer because the lower perches are lower, so if lowering springs on evo X struts would cause bottoming out issues, then I would assume that evo 8-9 springs would do the same thing.
12yr+ Vr4 owner.
Family Guy
Generated in 0.105 seconds in which 0.081 seconds were spent on a total of 14 queries. Turbo powered.
