Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Too much play in my shifter/linkage
GalantGSX
Galant VR-4 org Post #: 823955 posted 08/25/09 09:18 PM     Remind Me!  Send Private Message   Edit Post
Does anyone have a nice picture, maybe a nice macro picture of their shifter assembly, mine seems to have alot of play to where Im trying to find the gear, and I can see some places I think there needs to be a washer, and other places that sag and rub on the shift plate, but I think everything is there. Thanks
| | | IP: (72.40.28.240) | Report this post to a Moderator
blue642
Galant VR-4 org Post #: 824046 posted 08/26/09 06:57 AM     Remind Me!  Send Private Message   Edit Post
Hope this helps. I have mine right next to me, but it has no bushings in it right now. Check the bushings where the shifter cables bolt up to the trams linkage. Those seem to be the worst ones on most cars I've messed with. The one on the galant looked new, but the other fell apart when I went to disconnect it.
| | | IP: (147.185.160.242) | Report this post to a Moderator
solidviper89
Patty Purex
0425/2000
Galant VR-4 org Post #: 824050 posted 08/26/09 07:39 AM     Remind Me!  Send Private Message   Edit Post
I had tons of side to side play, not in the actual linkage but just the shifter. I replaced the bushing in the shifter shaft(#2 in that diagram) and it made most of the play go away. The only other bushing I want to replace is #11 in that diagram, IDK what its called but there is still some play in it.
Posts: 759 | From: Mission/ San Antonio, Texas | Member Since: 08/19/04 | IP: (24.173.95.114) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 824051 posted 08/26/09 07:41 AM     Remind Me!  Send Private Message   Edit Post
Im missing number 2, and number 6 and I imagine a few others, wow!
GalantGSX
Galant VR-4 org Post #: 824052 posted 08/26/09 07:43 AM     Remind Me!  Send Private Message   Edit Post
Where did you pick up your new bushings, and what was the price like for them?
blue642
Galant VR-4 org Post #: 824062 posted 08/26/09 08:28 AM     Remind Me!  Send Private Message   Edit Post
Should be able to pick them up from dealer I'd think. Look up the part # in CAPS.
I'm personally just going to machining some new ones out of delrin later this week. Might be willing to make some extras if there is interest.
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 824259 posted 08/26/09 06:43 PM     Remind Me!  Send Private Message   Edit Post
I'd be totally in for a set of deleon shifter assembly bushings. Keep me posted.
GVR4 #418/2000: [email protected] - pump/alky -
GVR4 #431/1000: [email protected]+
GVR4 #139/1000: T3T4: [email protected] - 14B: [email protected] (sold)
www.PerformancePartout.com
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (166.137.4.29) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 824561 posted 08/27/09 07:21 PM     Remind Me!  Send Private Message   Edit Post
count me in
blue642
Galant VR-4 org Post #: 824644 posted 08/28/09 07:04 AM     Remind Me!  Send Private Message   Edit Post
Its raining so I'll probably be making up a set this weekend. I'll post some pics when there done. Both looking for full sets?
AutoX_VR4
Galant VR-4 org Post #: 824736 posted 08/28/09 11:57 AM     Remind Me!  Send Private Message   Edit Post
i am interested as well. Post some pictures. If they look nice and work well i would buy a set from you. Paypal ready! i am used to honda shifters.... So i find the gvr4 needs some help.
| | | IP: (216.25.247.246) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 825881 posted 09/01/09 09:52 PM     Remind Me!  Send Private Message   Edit Post
I've been driving without the shifter boot the past few days so I can observe and I don't know how I have been driving the car like this for over 2 yrs. Talk about slop I got at least .1" of play in every direction. This is the first manual car I owned but wondered why I have only felt one other car with so much slop and that was an old beat up 1984 toyota pickup.
What's good with the bushing kit?
Robb
Galant VR-4 org Post #: 825970 posted 09/02/09 08:42 AM     Remind Me!  Send Private Message   Edit Post
I did mine about a year ago and I am very happy with it. I went the custom route and rebuilt it with all metal bushings. I used a 1/2 copper pipe as the sleeve, it was a little loose, so I used some brass hobby sheets. The nice thing about them is you can get almost any thickness you want. Then I took my shifter into the hardware store and got brass washers. Some were a little thick, but a few minutes with a fine mill file got them just right. It took a little more time doing it this way, but its much better than my 92 Eclipse or my 97 GST. The cool thing is, you can "tune" your shifter exactly the way you want. I wanted just a touch of drag to feel smoother, and now it is great.
| | | IP: (24.59.162.211) | Report this post to a Moderator
blue642
Galant VR-4 org Post #: 825993 posted 09/02/09 10:44 AM     Remind Me!  Send Private Message   Edit Post
Sorry the the lack of update on the delrin set. Had issues with cars and lawn lower so didn't get around to it since they needed fixed first.
Planning on turning them once I'm done biking today aslong as I get back at a reasonable time. Should have pics this evening or tomorrow.
blue642
Galant VR-4 org Post #: 826434 posted 09/03/09 06:48 PM     Remind Me!  Send Private Message   Edit Post
Got them finished and installed today. Wanted to make sure they fit before I posted any pics. Made them from some spare delrin. Has 0 play, yet no bind after some minor sanding on the face to get the lengths right. What do you think?
If there is interest I might post a feeler thread over in the for sale section. Not really sure how much they would run yet, but I have enough material for atleast 2 more sets right now.
GVR4ZUM
734/2000
Galant VR-4 org Post #: 826455 posted 09/03/09 08:19 PM     Remind Me!  Send Private Message   Edit Post
I'm interested. Does the console need to be taken out in order to put them on? I did the number 2's and I didn't have to.
Aufrecht Melcher Grossaspach
734/2000
Posts: 1439 | From: SoCal, USA | Member Since: 07/08/02 | IP: (98.109.225.200) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 826463 posted 09/03/09 08:41 PM     Remind Me!  Send Private Message   Edit Post
I took mine apart last night and yes, I had to pull the center console up. For those interested, I think the factory part number for the bushings is MB580253 and shows at over $7 a piece from mitsubishiparts.net. I just turned up an aluminum sleeve for mine last night since my bushings were totally gone.
-Jeff
1881/2000
50/1000
Posts: 7871 | From: KC, Missouri | Member Since: 08/08/04 | IP: (75.87.128.187) | Report this post to a Moderator
GalantGSX
Galant VR-4 org Post #: 826508 posted 09/03/09 11:21 PM     Remind Me!  Send Private Message   Edit Post
Is what's pictured a set? What bushings do these replace in the pictures?
blue642
Galant VR-4 org Post #: 826537 posted 09/04/09 06:25 AM     Remind Me!  Send Private Message   Edit Post
Sets 2, 6, and 11 in the picture. Sets 2 and 11 are the same, and set 6 has a bigger bore.
Haven't gotten it back in the car yet because I didn't get home till almost 9, but between these, the solid mounts, and the solid front cable bushings, I'm expecting almost no play.
NateCrisman
Fisheye Hoodpins
418/2000
Galant VR-4 org Post #: 826555 posted 09/04/09 08:28 AM     Remind Me!  Send Private Message   Edit Post
I'd really like a set. let me know how much you want with shipping.
[email protected]
Posts: 2054 | From: Blairstown, NJ | Member Since: 11/22/08 | IP: (76.6.48.160) | Report this post to a Moderator
1990ggsxnj
Member ++
1578/2000
Galant VR-4 org Post #: 826601 posted 09/04/09 11:13 AM     Remind Me!  Send Private Message   Edit Post
I looked for the feeler thread and havn't seen it yet but am interested here as well. Let us know!
"Is that Spool Drool? EWW!"
90GGSX Blue-Chesapeake
91GVR4 Nile Black-Sidney (Sid)
Posts: 525 | From: Blackwood, NJ | Member Since: 11/21/08 | IP: (12.175.119.20) | Report this post to a Moderator
blue642
Galant VR-4 org Post #: 826674 posted 09/04/09 02:31 PM     Remind Me!  Send Private Message   Edit Post
Official feeler posted in for sale section
2 registered and 7 anonymous users are browsing this forum.
Generated in 0.175 seconds in which 0.125 seconds were spent on a total of 14 queries. Turbo powered.
