ecu wiring diagram
Hey what's going on everyone. I need a diagram for the ecu because im trying to install a shift light and need to know what pin is the tach wire. Please any help would be nice
Andy_S
Shithole Wisconsin
Vfaq under electrical. All the pinouts are there. Should be pin 21.
But, pin 21 is only a 5 volt signal from the CAS, so it may not be enough to drive the tach. You should probably try pin #109 first, which is the one the dash tach works from.
Muskrat
Lexington, KY
look in the how-to section. There's a nice color coded diagram I put together.
