Galant VR-4 Forums » Galant VR-4 » Newbies » What spools faster?? small 16g or Evo 3 16g
OneFastVR4
Galant VR-4 org Post #: 800376 posted 06/09/09 03:22 PM     Remind Me!  Send Private Message   Edit Post
I'm not a newbie but this seems like a newbie question. i know that the internals on a Evo are lighter...Thats why i ask...
| | | IP: (70.208.28.82) | Report this post to a Moderator
RvlutionMtrsport
Galant VR-4 org Post #: 800387 posted 06/09/09 03:51 PM     Remind Me!  Send Private Message   Edit Post
I never logged and recorded the difference but I can tell you it's negligible. The power difference is very noticeable though, so I'd go Evo 3 16g all day long.
| | | IP: (24.20.201.167) | Report this post to a Moderator
OneFastVR4
Galant VR-4 org Post #: 800391 posted 06/09/09 03:59 PM     Remind Me!  Send Private Message   Edit Post
Thanx
chris
Galant VR-4 org Post #: 800397 posted 06/09/09 04:22 PM     Remind Me!  Send Private Message   Edit Post
Quoting RvlutionMtrsport:
never had a small 16g so i wouldnt know. I just know that i can make a soild 20psi at 3k and soild 25 at 3300 all the way to redline.
| | | IP: (72.200.148.16) | Report this post to a Moderator
BKatter
Galant VR-4 org Post #: 800404 posted 06/09/09 04:37 PM     Remind Me!  Send Private Message   Edit Post
I just replcaed my small 16g with an evo 3 and I can't tell a difference in spool up. The evo 3 definately pulls harder though.
| | | IP: (63.225.232.196) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 800451 posted 06/09/09 07:17 PM     Remind Me!  Send Private Message   Edit Post
^^ +1, for the setup I am running ( 2.5" TB, non-RS FMIC, switch to FP Race mani at same time ) the E3 spools 500rpm sooner and has no boost dropoff at higher RPM's compared to the S16g. This was with both at 17psi.
Mike O.
#464/1000 - Sold
05 Legacy GT - slush box
#86/2000 - Sold ( again )
Posts: 3114 | From: Portland, OR | Member Since: 09/10/07 | IP: (63.192.50.82) | Report this post to a Moderator
Armitage
VR4CED
960/1000
Galant VR-4 org Post #: 800656 posted 06/10/09 12:21 PM     Remind Me!  Send Private Message   Edit Post
What am I doing wrong? I only see 10 psi by 3000rpm on my Evo3!
Maybe the gianormous intercooler is working against me here? Turbo is new, motor is healthy/rebuilt recently.
'92 Galant VR-4 #960
'93 RX-7 Twin Turbo
Posts: 715 | From: Herndon, VA | Member Since: 10/16/03 | IP: (71.178.19.18) | Report this post to a Moderator
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 800972 posted 06/11/09 02:50 PM     Remind Me!  Send Private Message   Edit Post
Sounds like you've got a massive boost leak somewhere bro. Have you tried searching for leaks? Couplers, TB gasket, etc..?
SteveW
484/1000 Kensington Grey - Running VERY well :-)
564/2000 Belize Green ~ SOLD
749/2000 Summit White ~ SOLD
1989 Chrysler Conquest TSi SHP ~ SOLD
2004 Saab 9-5 ARC ~ Daily Driver
Posts: 4768 | From: Boulder, CO | Member Since: 12/16/03 | IP: (98.245.80.194) | Report this post to a Moderator
Armitage
VR4CED
960/1000
Galant VR-4 org Post #: 800973 posted 06/11/09 02:53 PM     Remind Me!  Send Private Message   Edit Post
Quoting mistaVR4:
Pressure tested the whole system to 20 psi. No leaks except the usual little one at the throttlebody shaft o-rings.
'93 RX-7 Twin Turbo
Rock Star Status
Galant VR-4 org Post #: 801101 posted 06/11/09 09:25 PM     Remind Me!  Send Private Message   Edit Post
^ Car running rich or something maybe? Timing good?
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (76.189.146.118) | Report this post to a Moderator
ktmrider
Cool Guy Crowd
Galant VR-4 org Post #: 801129 posted 06/11/09 11:00 PM     Remind Me!  Send Private Message   Edit Post
Quoting Armitage:
Possibly, I don't recognize the IC brand listed in your link. Any idea on the pressure drop?
Bar and plate designs are usually better on pressure drop, ie less than tube/fin, but have lower efficiency.
Also the size of your IC piping can impact things, I am still running stock diameter ( 1 7/8" or 2" ).
Mike O.
#464/1000 - Sold
Edited by ktmrider (06/11/09 11:01 PM)
Posts: 3114 | From: Portland, OR | Member Since: 09/10/07 | IP: (72.254.116.249) | Report this post to a Moderator
gsxboost
Galant VR-4 org Post #: 801165 posted 06/12/09 12:27 AM     Remind Me!  Send Private Message   Edit Post
The small 16g does spool quicker. I currently have a small 16g on my talon, a big 16g on my Tsi, and i had a evo3 16g on my GSX. The differences in spool times are very very small. A big 16g spools just about as quick as an evo3 16g, but a small 16g spools a little faster. Overall though, like it was already said, the evo3 16g hits and pulls a lot harder. Its much more worth it
| | | IP: (76.23.52.30) | Report this post to a Moderator
464/2K
<3s Rance and self distrusts
464/2000
1025/2000
553/1000
788/1000
Galant VR-4 org Post #: 801169 posted 06/12/09 12:49 AM     Remind Me!  Send Private Message   Edit Post
Switch to a smaller core, there was a link floating around about ic's affecting spool time some time ago. Iirc top to bottom flow was the best for spool time.
_Ricky-
464/2000
788/1000
'95 Lancer Evolution III
2005 Mitsubishi Lancer Evolution VIII
"Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime"
Posts: 4671 | From: Denver,Co | Member Since: 10/21/03 | IP: (32.172.232.74) | Report this post to a Moderator
Armitage
VR4CED
960/1000
Galant VR-4 org Post #: 801191 posted 06/12/09 07:13 AM     Remind Me!  Send Private Message   Edit Post
Quoting VRausch4:
Probably running a little rich. I've tuned the partial throttle curves to get the fuel trims as close to 100 as possible. I haven't tuned for WOT yet since replacing the motor/turbo, but have all of the compensations in Jeff's chip for my setup.
Quoting ktmrider:
It's the I/C that was made by AWDNOT2 and later sold as a package a while back with the Dave Brode pipes. I'm using custom hot side pipes (2") and have fitted ETS cold side pipes (2.5") on there now.
'93 RX-7 Twin Turbo
2 registered and 15 anonymous users are browsing this forum.
Generated in 0.079 seconds in which 0.031 seconds were spent on a total of 14 queries. Turbo powered.
