Is the pressure plate actually chewed up or is it just the clutch disc worn out? That's awful fast to wear out a clutch unless you were slipping it a lot (like driving in traffic), or something is wrong. With a properly installed and worn clutch, only the disc should wear out, not the PP surface.
If it's just the disc, you can easily just replace it with a new disc, or even a sprung puck disc if you want to upgrade the capacity slightly. (single plate clutch parts are pretty much all interchangeable, even between brands, despite what they want you to think)
If it actually chewed up the pressure plate, did the disc wear more on the PP side than the flywheel side? If so, make absolutely sure you get the flywheel resurfaced and re-stepped. If you have an aluminum FW, consider replacing the friction plate.
If the flywheel is gets glazed from slipping to much and overheating, (glassy smooth, heat marks, etc), it won't grip properly on that side, and the PP, which is taking all the load, will get extremely overloaded and eventually destroyed. If you've got this problem, the root cause is the flywheel, not just the clutch dying, and it will likely happen again unless you fix the flywheel. If it was a brand new flywheel and the above happened, you probably got stuck in traffic a lot /ubbthreads/images/graemlins/bawling.gif
This is one of the reasons I really dislike the asymmetrical clutch discs (different friction material on each side) that some manufacturers use, since they are more prone to this problem.
