Buscher Balancer belt size?
fivestardsm
Middle, Michigan
Any one running the buscher 2 piece balancer?
I need to get a belt, and know that the stock diameter is roughly 18 1/2" and the buscher is 17", so I should take the 1 1/2 difference, and divide it by 2 to come up with 3/4" shorter belt, but not positive. Maybe my brains not working because of all the carb cleaner fumes, so I figured I'd ask.
Also, if any one does run it, or has, what are the pros/cons with it?
Call buscher and find out. Otherwise you can always buy a belt test fit it and return it.
