bigger alternator wire and dump tube
howard Unregistered
posted 05/09/03 03:44 PM
Well, a week ago I broke one of the O2 housing-to-turbo bolts, so I ripped the turbo off and pulled the alternator while I was in there. I had been going through alternators like twice a year, so I gave everything a thorough once over. I found that the stock alternator feed wire was frayed and burnt, and kinda small. I also replaced the 6 month old AutoZone reman alternator with a new (reman) Mitsu piece. I also spliced in a fresh alternator harness (the upper smaller wires with the connector). I ran 4 gauge high-strand-count copper cable from the fuse-box to the alternator, and routed it behind the radiator and shorter than stock by a foot or two. I also added a 2.5" tubular O2 housing from Andy @ 122performance. It fits so damn nice that the stock heat shield works with it just fine and hides it. Nice work, Andy!  crappy stock wire  good condition oem wire vs 4 gauge  new wire attached  new wire crimped  new wire routed  new wire routed 2  back together
| | | IP: (129.120.56.72) |
howard Unregistered
posted 05/10/03 01:59 PM
quote: Originally posted by DongeR615: when i go to the hardware store and I want to crimp 4 guage or 2 or 1 or 0 guage wire. do i ask for any crimper or do i ask for a special kind? the crimpers i've seen/used don't really do the job. got a pic of it? thanks DongeR
DongeR, I don't have a big crimper or anything, I used 6" linesman pliers (half pliers, half wire cutters). I got like 9 feet of this nice high strand 4 gauge power wire from a local stereo shop for about $10, including gold terminals. Just find one in your area and ask. They'll usually crimp one end on for free if you want.
Paul, I ordered the Spal fan from Indy Race Cores, for a little over $100, but it took forever to receive.
| | | IP: (4.3.175.124) |
howard Unregistered
posted 05/11/03 12:31 PM
quote: Originally posted by atsiauto: dumb question but does this wire go right to the battery +? why did you get 9 feet ? I like that dump setup and where did that dipstick come from might save a few fingetips (heat)
Sort of... the alternator wire goes to the fuse box that's mounted to the battery. I popped the fuse box back off (clips on), removed the 10mm bolt that holds the stock wire on, and the 4 gauge terminal fit up in there pretty nicely.
For more info on the tubular O2 housing, see http://www.usionline.net/122.htm or talk to Andy on this message board.
The dipstick is a new 2G DSM part that I installed, which does keep my fingers from getting burned now when I check the oil.
| | | IP: (4.3.175.124) |
DongeR Unregistered
posted 05/16/08 09:02 PM
not to bring up a old thread b/c thats what you guys would do... Anywho my question is that his has a red cover to tell him its the "B" post now the one I have on my car looks like this.  Which when I check for continuity for both of the spade connectors, it goes to this on the positive battery post where the fuses are located (100 amp fuse)  My question is.. how do I know which one is which? or it doesn't matter? I know we have a "B" terminal and a L and IG for the connector on the link below. shouldn't there be one more? clickIf I'm reading correctly, are you still using the old connectors or just letting them hang? Do i just attach a 4gauge wire with a fuse to the + battery fuse location? or do I attach the old wires with the new ones?
| | | IP: (76.205.251.20) |
DongeR Unregistered
posted 05/17/08 03:03 AM
Quoting iceman69510:
Did both wires go to the same place or different places on the fuse holder? Moot point really, as it doesn't matter. They are alternator voltage output.
Both wires in the first picture went to the positive power wire on the battery on the same place 100 amp location
I thought we had a noise filtering wire?
