25mm offset
G
zompton
Is anyone running a 25mm offset? If so what diameter wheel and do you have any pics?
Yao
Denver, CO
I think 25mm is too much, no? I am running evo8 which is 38mm and with 245 tires, it would sometimes rub the front struts. On my eclipse I ran racing hart with 32mm offset and no rub, but does stick out a little.
G
zompton
That's what I was thinking.
You'll need a bit of stretch and negative camber to tuck it under the fender. Although I'm not a fan of tire stretch, minimal amounts to fit a deeper lipped wheel can look good. I think BobDole's car runs a 25 offset and looks pretty sweet.
