Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Cold start on cold morning ok. On warm morning, not so much...
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1227516 posted 05/03/16 07:18 AM     Remind Me!  Send Private Message   Edit Post
I'm sitting in my car this morning warming it up and unlike was previous few weeks of morning, no issues. The difference: it's fairly cold at the moment.
As the weather began to warm, I started getting hard starts. Car would fire up OK, then idle for 10-15 seconds, at which point it would go lean, start to surge with the idle dropping lower and lower, then die. It was possible for me to lightly press the gas and get through this. Now if I let it die, I could fire it right back up and it would be fine.
I've checked the ISC, ECU, BISS, and even bumped up the cold-start enrichment in link. FIAV? I just don't know...
RIP 543
Ded click
2006 Suzuki SV-650 (for sale)
2011 BMW 335d (~510'lb/tq and 36mpg. hwy. How can you go wrong?)
Edited by EfiniX (05/03/16 07:23 AM)
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (75.164.139.121) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1227517 posted 05/03/16 07:45 AM     Remind Me!  Send Private Message   Edit Post
coolant temp sensor.
138/2000
152/1000
Posts: 3534 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.25.198) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1227522 posted 05/03/16 09:30 AM     Remind Me!  Send Private Message   Edit Post
Looks fine in link.
Warm day cold start stall log
Or should I be looking at a different value somewhere?
RIP 543
Ded click
Banthony
555/1000
Galant VR-4 org Post #: 1227529 posted 05/03/16 10:16 AM     Remind Me!  Send Private Message   Edit Post
Quoting EfiniX:
My car does pretty much the same thing. If it's a fresh start after sitting overnight, it usually dies about 8 seconds after starting up. If i use my remote start, it fires up, runs for a few seconds, and dies. Then it automatically starts again, stumbles a little bit and starts idling like it should on a cold start. Weird.
I barely drive it so i haven't put much time into trying to figure it out. I honestly thought it may have something to do with my externally mounted ISC. I'm not sure. If the car has been run in the past couple hours, it doesn't do it. I'll dig more into it once i get my new goodies installed.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3530 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.86.77) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1227530 posted 05/03/16 10:25 AM     Remind Me!  Send Private Message   Edit Post
Well, mitsu, you are certainly describing exactly what's happening with me.
Are you running speed density?
RIP 543
Ded click
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1227531 posted 05/03/16 10:33 AM     Remind Me!  Send Private Message   Edit Post
Do you have the fiav deleted?
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1633 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (69.11.233.34) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1227537 posted 05/03/16 10:57 AM     Remind Me!  Send Private Message   Edit Post
Quoting EfiniX:
Looks fine in link.
cant view log, but if its reading correctly then its probably right.
138/2000
152/1000
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1227561 posted 05/03/16 02:59 PM     Remind Me!  Send Private Message   Edit Post
Your voltage is dropping almost to 9 volts at times.
Thom
Posts: 830 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (50.58.165.200) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1227565 posted 05/03/16 04:21 PM     Remind Me!  Send Private Message   Edit Post
Quoting EfiniX:
SD. Magnus cast. S90. FIAV delete.
97 CBR900RR
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1227566 posted 05/03/16 05:15 PM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
It is, but that correlates with the drop in RPM's. I think it's a symptom, not causal. I don't have any voltage issues after the motor warms up a bit.
RIP 543
Ded click
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1227567 posted 05/03/16 05:17 PM     Remind Me!  Send Private Message   Edit Post
Quoting MellowVR4:
I do not have my FIAV deleted. Is that really what could be going on here? I'm having problems on warm mornings, not cold ones.
RIP 543
Ded click
Edited by EfiniX (05/03/16 05:18 PM)
Galant VR-4 org Post #: 1227637 posted 05/04/16 03:11 PM     Remind Me!  Send Private Message   Edit Post
Still have a fps in use?
Posts: 1413 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (66.249.83.215) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1227640 posted 05/04/16 03:25 PM     Remind Me!  Send Private Message   Edit Post
I do have a FPS still in use.
RIP 543
Ded click
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (209.152.44.218) | Report this post to a Moderator
Galant VR-4 org Post #: 1227643 posted 05/04/16 05:39 PM     Remind Me!  Send Private Message   Edit Post
That's life without a maf sensor. I'd guess your iat comp needs to be tweaked. Maybe send Kim a pm, he's the authority on SD but then again he writes his SD software. Doesn't use ecm link.
Posts: 1413 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (66.249.83.223) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.121 seconds in which 0.095 seconds were spent on a total of 14 queries. Turbo powered.
