1991 Galant have acceleration issues
rr3209
New member
Chipley, Fl
Hi, newbie here.
I live in Florida and got a 1990 V4 single cam standard Mitsubishi Galant back in January of 2014 to drive back and forth to work. The master and slave cylinders were replaced in maybe July after some leakage and has pretty much been driving decently since that time. We have a lot of hills where we live and I noticed over the last few weeks that it has had a harder and harder time getting over them. Over the last The last few days I'v had to hit 3100 RPMs to get up a moderate incline @ 35MPH until last night when I literally had to push the back of the car to get it to go up the driveway. It's had some heavy oil leakage but hasn't really run all that hot. Could this be the clutch going out or the engine? The engine isn't making any weird noises or blowing smoke. Where should I start with this? /ubbthreads/images/graemlins/hsugh.gif
Does the engine rev up without a gain in speed?
rr3209
New member
Chipley, Fl
Yes, I step on the gas and the engine revs normally but doesn't move forward much. When I'm going up hills I normally drop it into a lower gear, like 3rd and that gives a little extra speed.
rr3209
New member
Chipley, Fl
It's like it doesn't accelerate no matter how the engine sounds. The shifter seems a little sloppy but doesnt hang up and shifts ok while the clutch petal is pressed down
Sounds like a slipping clutch, if speed doesn't increase but rpms do then it's slipping. You might also notice a burning smell.
idreamidrive
Murray, KY
Also, if you are having oil leaking issues, it might be also the rear main seal leaking onto the clutch and making everything worse.
Also, you don't have a V4 engine. It is an inline 4, but that is a pet peeve of mine.
