Galant VR-4 Forums » Galant VR-4 » Newbies » Transmissions interchangeable
Fish
392/2000
Galant VR-4 org Post #: 1201115 posted 02/08/15 01:38 PM     Remind Me!  Send Private Message   Edit Post
Hey guys
Stupid noob question but I've got a 91 base model galant with the 2.0 SOHC that the transmission has been making noise in for the past few years. Somebody recently gave me a transmission out of a 94 eclipse fwd turbo.
Does anyone know if it will work in my car? Will the gear ratios be about the same as what I have now? Anything need to be changed to make it work?
Thanks for the advice
Branden
Posts: 206 | From: Idaho Falls, ID | Member Since: 11/13/12 | IP: (159.118.221.240) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1201118 posted 02/08/15 02:00 PM     Remind Me!  Send Private Message   Edit Post
I'm not familiar with a 2.0 SOHC but I believe that all the FWD 4gxx transmissions are interchangeable, at least in the proper generation.
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3647 | From: Bremerton, WA | Member Since: 10/16/03 | IP: (65.102.182.159) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1201129 posted 02/08/15 03:25 PM     Remind Me!  Send Private Message   Edit Post
FWD turbo and non turbo use different inner axle splines/joints if I remember right. The differential is bigger/stronger.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.15.96) | Report this post to a Moderator
Fish
392/2000
Galant VR-4 org Post #: 1201133 posted 02/08/15 03:42 PM     Remind Me!  Send Private Message   Edit Post
So could I just get new cv axles for it and bolt everything else in? Do you know if the input shafts are the same size and spline count? Is there anything else that I would need?
Branden
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1201135 posted 02/08/15 03:50 PM     Remind Me!  Send Private Message   Edit Post
Oh yea, I forgot. I think the clutch disk is different between turbo/non. But the trans itself will bolt in yes. Just make sure the trans mount bracket is the same (I can't remember).
91 #108/2000- link
09 Hummer H3T
Fish
392/2000
Galant VR-4 org Post #: 1223725 posted 02/04/16 11:57 PM     Remind Me!  Send Private Message   Edit Post
So I finally got around to swapping this out. My original transmission (f5m22) dumped about a half quart of oil on the shop floor this new years day. I had also lost 4th gear completely, 3rd was on its way out and the input bearing was extremely noisy. I had the new transmission sitting around for quite some time now (f5m33).
I ended up needing to replace the cv axles as stated. The turbo ones do indeed have a much larger inner joint. I also had to change the transmission mounting bracket, starter plate, flywheel, and clutch. I discovered that the non turbo models have a smaller flywheel (same diameter as the turbo awd flywheel) compared to the turbo fwd cars and would not work with the new transmission as the starter is spaced further away on fwd turbo models. I ended up using a turbo fwd fidanza flywheel and it works perfectly. The original transmission mounting bracket was also different but I had a spare gvr4 bracket that ended up working.
Clearance was also an issue. After installing the new transmission it was slightly touching the subframe by the front diff. I removed the transmission and gently massaged (beat the shit out of with a large hammer) the subframe until I had the needed clearance. Everything now fit perfectly.
After the install was done I took the car for a drive only to notice that the second gear syncro is pretty much gone. The fun never ends
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.096 seconds in which 0.079 seconds were spent on a total of 14 queries. Turbo powered.
