Factory Valve Cover Color
Spyke169
Greenfield, Wi
I want to clean up my valve cover and apply a fresh coat of paint however I'm having a hard time finding paint that matches the factory valve cover color. Does anybody know where I could get paint that matches?
Wizardawd
Franklin, NC
I'd just pick any color or a red that you think looks close. It's not like there is anything you are matching it too anyways. It was the only thing red under the hood unless you have the JDM intake. And even then, they have faded over time.
I painted one in the satin wrinkle red that the hondas used on the type r motors, looked better than the factory red anyways.
Look at it in this pic.
Wiz
Spyke169
Greenfield, Wi
I was a bit confused at first, until I remembered... Galant VR4 valve cover is red, what I am asking about is for my Galant GSX. So I guess my next question is, because I want under the hood to be how it rolled of the production line, does anyone know if the Galant GSX had a valve cover like that of a VR4 or like a DSM? Currently it has a DSM style valve cover...
maroonmetallic
central WI
If I'm not mistaken, the GGSX had a similar vc to my old 92 GGSR.
Its a silver cover with "Mitsubishi" but no diamonds.
The lettering is red similar to the original 1G DSM vc's.
-Shawn
Spyke169
Greenfield, Wi
Well in that case I will have to keep my eyes open for one. In the mean time, I have a spare "Mitsubishi" cover with the diamonds, has anyone found a silver paint that matches factory color?
89Mirageman
Stantonsburg, NC
All the valve covers that I've pulled from early galant gs' and gsx's had Mitsubishi and the diamond logo on top. The ones from the 1.6 engines had Mitsubishi only. I believe JNZ has a powder coat color that's very close to the original silver color.
Spyke169
Greenfield, Wi
Excellent, Thanks.
Coltsfan
Tonawanda
I think duplicolor engine enamel matches pretty well if you use the Aluminum color followed by the clear.
Justin at Detective Coating powdercoat's them to a very close red called "Mirror Red" I love it.
Looks great in the bay, And lasts way longer than paint.
G
zompton
CSM vc.
Wizardawd
Franklin, NC
The silver is probably the same color used on most rims of the period. I believe the name used was Argent Silver.
Wiz
BoostedAWD91
Danville,Pa
Ive tried to paint my valve cover the factory red color and i tried 2-3 different red high temp paints you get at all the parts store and all of them turned out more of a orange than a red so im gonna have to strip it all back down again and go with a different color since i can't find a red paint thats acutally red
EHmotorsports
Beaverton
try a red or black primer then use a red you like. it helps make the shade slightly darker.
89Mirageman
Stantonsburg, NC
Quoting BoostedAWD91:
Find a Hobby Shop that sells RC cars and buy some paint made by Pactra for the clear Lexan bodies. The color you want is Racing Red. The cans are tiny and pretty expensive (about $6-$7) but one can will paint a VC. This paint is very strong and fuel/heat resistant for the gas powered RC cars. I've been using this stuff for a while with no issues.
Spyke169
Greenfield, Wi
I should have been more specific, this is on my GGSX. The valve cover that is on there now is the same as G posted. Mitsubishi without the diamonds. The valve cover color (as well as the DSMs I've owned) has always looked to me like a slightly different silver than most rattle can silver colors. Maybe it is from all the oil that gets spilled, and puked from the oil fill cap, on it over the course of 20 years /ubbthreads/images/graemlins/dunno.gif
BoostedAWD91
Danville,Pa
Anyone tried the duplicolor perfect match? It matches pretty well I'm just curious how well to heat it will hold up.
Also how does everyone paint the lettering a different color and get that nice crisp line. I tried masking off the lettering and it didn't turn out as nice as I hoped
Wizardawd
Franklin, NC
I sand my letters clean, then put vaseline on them. Paint the VC, once it dries, wipe the vaseline off. Something silimar can be done if you paint the letters, etc. Just do the letters first since you usually don't want to try to detail them after the rest is painted or you risk damaging it. Also can try wax. Basically something harmless that wipes off easily.
Wiz
Coltsfan
Tonawanda
You can use the plastic "fine line" masking tape, or just mask over the whole lettering area, then cut the tape around the letters with a razor blade.
This is duplicolor engine enamel with clearcoat of the same type. After you run it for a while, it looks just like the original stuff.
See the change?
Spyke169
Greenfield, Wi
Excellent, I will give that a shot, thanks.
