Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Weight savings
Weight savings
bluzvr4
Galant VR-4 org Post #: 1193309 posted 11/06/14 10:24 AM     Remind Me!  Send Private Message   Edit Post
Get I know this has been beat 1000 times and I've read a bunch but alot of them go for straight out race cars. A couple things I was wondering.
1. Is our front crossmember different then a 1g is so does anyone make a chromoly 3 peice like they do for dsms.
2. How heavy is our crash bars? Is it easier to make my own replacement of does someone else make then?
3. What little things have you die to shed some weight while emaining a complete street car with mostly stock aprearance.
I've allready deleted ac and a few things under the hood that didn't need to be there. I'm not good rl for lightest alot by any means but would like to be around 3000 pounds
73 Opel gt (race car)
51/2000 (being built now)
94 vr4 (the pretty one)
Posts: 57 | From: san jose IL | Member Since: 02/21/11 | IP: (174.238.229.167) | Report this post to a Moderator
BENE38A
Slanging Kiwi parts
Galant VR-4 org Post #: 1193316 posted 11/06/14 11:29 AM     Remind Me!  Send Private Message   Edit Post
they do make a 3 piece chromoly crossmembers but the full 3 piece doesnt save much weight
1991 Mitsubishi Galant vr4 RS
Posts: 261 | From: New Zealand | Member Since: 09/02/13 | IP: (116.251.133.5) | Report this post to a Moderator
bluzvr4
Galant VR-4 org Post #: 1193319 posted 11/06/14 11:40 AM     Remind Me!  Send Private Message   Edit Post
Any idea on how much? I thought they were quite a bit on dsms
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1193323 posted 11/06/14 12:39 PM     Remind Me!  Send Private Message   Edit Post
3 piece crossmember cost around $265. The NS bars are different, but everyone that makes them for the DSM makes them for the VR4.
Here is my weight reduction so far:
-1 piece chromoly cross member
-chromoly mustache bar
-DSS aluminum driveshaft
-removed F&R crash bars
-removed AC
-removed cruise control
-removed 4WS
-removed ABS
-removed spare tire and jack
-removed trunk carpet and plastics
-removed firewalls insulation
-removed windshield fluid
-removed sound deadening under dash
-89 under dash and glove box
-removed carpet padding
-lighter battery
-CF hood with hood latches
-removed all emissions
-manual steering rack
-trimmed wiring harnesses
-removed heater box, blower motor
-deleted coolant to TB and turbo, NA OFH
Next up is a harness bar and manual windows
-Craig
1501 Build Thread
Edited by LIV4PSI (11/06/14 02:07 PM)
Posts: 1761 | From: O-H-I-O | Member Since: 11/24/11 | IP: (66.87.115.134) | Report this post to a Moderator
bluzvr4
Galant VR-4 org Post #: 1193328 posted 11/06/14 01:03 PM     Remind Me!  Send Private Message   Edit Post
Any idea what urs weighs.
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1193330 posted 11/06/14 01:06 PM     Remind Me!  Send Private Message   Edit Post
None at all, I'll find out once it's finished this spring. If it's above 3,000lbs I'll be pissed. I keep think of things I forgot from that list too haha
-Craig
1501 Build Thread
Posts: 1761 | From: O-H-I-O | Member Since: 11/24/11 | IP: (98.31.3.95) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1193331 posted 11/06/14 01:15 PM     Remind Me!  Send Private Message   Edit Post
Good lightweight rims can help shed up to 30 lbs, plus it's rotating weight. Seats are another way to shed 50lbs.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
bluzvr4
Galant VR-4 org Post #: 1193332 posted 11/06/14 01:16 PM     Remind Me!  Send Private Message   Edit Post
What do this cars weigh in at factory? I've heard all over the place.
715/1000
1284/2000
Galant VR-4 org Post #: 1193333 posted 11/06/14 01:18 PM     Remind Me!  Send Private Message   Edit Post
I always figured 3400 with all fluids full... Not sure how close I am.
12yr+ Vr4 owner.
Family Guy
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1193337 posted 11/06/14 01:32 PM     Remind Me!  Send Private Message   Edit Post
It's closer to 3,300lbs I believe, less if you don't have a sunroof
-Craig
1501 Build Thread
bluzvr4
Galant VR-4 org Post #: 1193338 posted 11/06/14 01:35 PM     Remind Me!  Send Private Message   Edit Post
Mine does have a sunroof. I planned on removing the sound deadener, the ac? The f&r bumper supports and all the emission stuff. Was going to remove the power steering my my wife enjoys the car with it. Also haven't decided if the 4ws is staying or be. I guess a big part will depend on if it works
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1193339 posted 11/06/14 01:40 PM     Remind Me!  Send Private Message   Edit Post
ABS is pretty heavy, basically worthless, and easy to remove. I would do that one for sure
-Craig
1501 Build Thread
bluzvr4
Galant VR-4 org Post #: 1193340 posted 11/06/14 01:45 PM     Remind Me!  Send Private Message   Edit Post
Do u just use a Dsm kit for that?
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1193345 posted 11/06/14 02:07 PM     Remind Me!  Send Private Message   Edit Post
Yep
-Craig
1501 Build Thread
Fiascoxl
Member +
740/1000
Galant VR-4 org Post #: 1193346 posted 11/06/14 02:28 PM     Remind Me!  Send Private Message   Edit Post
I am using a three piece cross member, it weighs a shit ton less than the heavy stamped steel oem pieces.
92 VR4 #740 Nile Black
Posts: 320 | From: Stuarts Draft, Va | Member Since: 01/26/13 | IP: (75.146.21.209) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1193348 posted 11/06/14 02:31 PM     Remind Me!  Send Private Message   Edit Post
I got my crossmember kit from www.bulfab.com . Mine was mainly done to create more room in the engine bay. It's lighter than stock. I heard about 10lbs savings.
1990 GSX: New project..
1991 Belize Green GVR4 #476/2000: 710WHP/501TQ (dynojet)in 2014, Street trim, 3400lbs! [email protected] (wastegate)
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (68.12.100.165) | Report this post to a Moderator
Wookalar
ignore this pathetic weasel he's just not worth the time
3/1000
Galant VR-4 org Post #: 1193365 posted 11/06/14 06:23 PM     Remind Me!  Send Private Message   Edit Post
Please correct me if I'm wrong but I believe I've read that one of the bars (in the bullfab kit) needs to be removed in order to do an oil change with the stock oil pan. Something how the bar runs right up against the drain plug.
</font><blockquote><font class="small">Quoting 89Patches:</font><hr />
Brett gstwithpsi is the nut rider!
<hr /></blockquote><font class="pos
Posts: 458 | From: Arizona USSA | Member Since: 11/27/13 | IP: (24.251.4.211) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1193367 posted 11/06/14 06:33 PM     Remind Me!  Send Private Message   Edit Post
That is absolutely correct Wookalar
-Craig
1501 Build Thread
diambo4life
476/2000
Galant VR-4 org Post #: 1193372 posted 11/06/14 07:14 PM     Remind Me!  Send Private Message   Edit Post
Yeah...but it's not really much to do. You remove that one bolt and it (the bar) swivels out of the way. It takes me more time removing the turbo oil feed from the oil filter housing than getting that N-S bar out of the way.
Edited by diambo4life (11/06/14 07:15 PM)
Posts: 236 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (12.130.175.148) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1193390 posted 11/06/14 09:43 PM     Remind Me!  Send Private Message   Edit Post
go on a diet, ya fat fuck
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (67.168.54.49) | Report this post to a Moderator
BENE38A
Slanging Kiwi parts
Galant VR-4 org Post #: 1193397 posted 11/06/14 11:32 PM     Remind Me!  Send Private Message   Edit Post
I bought the 3 piece chromoly crossmember from Paul Volk, you are right I just assumed its not much lighter but its quite alot lighter, you dont need to remove the north south bar to do an oil change on this set.
vr4play
handles best on 3 tires
816/1000
Galant VR-4 org Post #: 1193415 posted 11/07/14 08:37 AM     Remind Me!  Send Private Message   Edit Post
Stock weight on my car was 3456lbs. Current weight is 2860lbs. I have removed all interior insulation and sound deadening, carpet ect., fiberglass aftermarket seats, carbon hood, carbon sunroof delete, all a/c and heat removed. Still have power windows, abs brake system, and front bumper support. Rear bumper support is now aluminum. I added subframe connectors that weighed in at 25lbs before I welded them on. I have most of the stuff to remove the power windows and locks, I have plans to update the abs to something that works so I'm leaving the stock system on till then. I would think that the lightweight underdash, some lighter yet comfortable seats, and lightening the rear bumper support would be places to start.
816 of 1000
[email protected]
??? of 2000
[email protected] on 93oct
[email protected] on C16
[email protected] on E90
ASE Certified Master Technician
www.Performance-Alignment.com
Posts: 396 | From: Cincinnati, Ohio | Member Since: 02/07/08 | IP: (50.5.121.151) | Report this post to a Moderator
bluzvr4
Galant VR-4 org Post #: 1193432 posted 11/07/14 10:01 AM     Remind Me!  Send Private Message   Edit Post
I've seen alot of people say a aluminum rear bar. Is that something custom or is there one u can find?
Posts: 57 | From: san jose IL | Member Since: 02/21/11 | IP: (98.214.118.86) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1193448 posted 11/07/14 12:16 PM     Remind Me!  Send Private Message   Edit Post
Quoting vr4play:
Interested in the sunroof delete. I have a non sunroof headliner to put in and would love to lose 50 lbs of the highest point of the car.
I love my crazy mother!!!
Posts: 1542 | From: Manchester, NH | Member Since: 07/17/06 | IP: (74.94.142.161) | Report this post to a Moderator
Wookalar
3/1000
Galant VR-4 org Post #: 1193450 posted 11/07/14 12:28 PM     Remind Me!  Send Private Message   Edit Post
Quoting BENE38A:
I'm interested in seeing pics of the "Paul Volk" bars if you feel like posting some. We've seen the bullfab kit. I suppose they are just bars but I would like to see how one kit differs from the other in terms of the oil drain plug blockage vs not.
Pages: 1 | 2
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.293 seconds in which 0.255 seconds were spent on a total of 15 queries. Turbo powered.
