Fabed up a Lower turbo heat shield. take a look
ronkonkoma, ny
Its one piece of Stainless bent and cut with hand tools. The right tools for the job I have not, but I got the job done.
I know I know My welding sucks
Chad989of2000
Livermore, CA
Nice looking piece. I am sure that with the right equipment it could be "pretty'd" up a bit more too. Fitment looks great though.
92_talon_awd
Knoxville, TN
How much will you be charging? /ubbthreads/images/graemlins/laugh.gif I'd buy one
ronkonkoma, ny
Thanks Guys! Like I said I don't have the tools to make them the right way. I have the template and measurements though. Ill make a pdf or something.
MAP liked my post on instagram... I'm sure it wont be long before they start selling them. /ubbthreads/images/graemlins/frown.gif
Looks really good for a "amateur" with no "right" tools. If you don't like the welds you should be able to grind it down and have a clean 90* look.
I think it looks great. Better than a lot of what I've seen.
Is your turbo downfiring? It looks like over the manifold piping might get close to that corner.
ronkonkoma, ny
I'm rocking a stock body 16g with ets piping kit. I installed the shield in the car moments after welding. I just removed the one cuppler and the up pipe and was able to get it in. No fitment issues realized during the procedure. I swapped out my wga after it was installed and had no issues. Stock up pipe may be different. I never had one so I don't really know.
Very nice then.
You sir, just might be in business....
ade
Paumanok NY
when do i pick mine up?
ronkonkoma, ny
If you guys are really serious I will get my hands on a real brake. that's really all I need. I could probably make them 18 or 20 gauge brushed or mirror stainless for like $50-$60 each.
Which O2 housing is this bolted to? Also which bolt holes did you use?
ronkonkoma, ny
I had it on evo 3 and 2g o2 housings. I used two holes on the o2 housing. The top one on the front and upper hole on the right. Lastly the lower hole on turbine housing. Its not a full cover for the turbine. I designed it just as protection for the alternator and ps pump... And to look cool.
I found a descent brake and will hopefully pick one up today. I'm going to make an upper shield to match.
Fab up a cover for the FP manifold and you'll be rich.
coyotes
Seattle, WA
Looks nice. I was just gonna fab up a bracket for the stock lower heat shield to fit over my MR o2 housing.
ronkonkoma, ny
Quoting prove_it:
Ill give it a shot, but doesn't it not have threaded holes?
Yep, no where to mount anything too. That's why you'll be rich.
ronkonkoma, ny
If you all don't mind about bolts through the top, I have a pretty good idea how to make it.
