Using 1.8L 4g67 block
pmp285
manila,philippines
Im having a hard time looking for a unmolested 63 block and crank here in the philippines. Will a 1.8L 4g67 block work if i just machine it to 85.5 bore? I know crank is the same. Im just worried about machining the bore that much. 67 bore measures 78mm
Probably too much. I would doubt the walls are that thick.
That is likely a better option. If the heads interchange, and you skip the oil squirters, you should only need the knock sensor hole drilled.
AllanL
NV
possible...but i doubt your 78mm 67 bore diameter...
read through this: click
hth /ubbthreads/images/graemlins/wink.gif
pmp285
manila,philippines
Thanks. Will measure again when i get the time. But he just bored out to 85mm though. I doing 85.5mm since im upgrading my pistons and rods
AllanL
NV
Read the zerotohundred thread linked.
85.5mm is doable
It is just the common 63 OS... /ubbthreads/images/graemlins/ooo.gif
James
Port richey Florida
Why are you upgrading the rods and pistons for only 300hp? Seems like a lotta hassle for 300hp
pmp285
manila,philippines
Coz i got the bnew wiseco pistons and scat rods for only $500 and its more than 300hp. Well atleast what the evo3 16g can push. Then save up for a bigger turbo. And i dont trust the old pistons that came with the old engine i got
Near Seattle, Washington
I'd like to speculate here...
Because, a goal of 300whp can easily develop into a goal of 450whp or more. It's peace of mind to know you have more "durable" parts in there. Then you won't be afraid of more "bolt-ons".
