Espelir Springs on Evo8 suspension
PlatypusOfFury
Bellingham, WA
Curious on these...
Read in some of the "How-To" that some people use them, and love them.
Do they require cutting down for the VR4? or are they good to pop on and go?
I've got cut Tein's, they look like crap and would rather put something in uncut if possible.
also, ASD or GT version?
thanks!
asmo
SLC, Ut
They should be good, I deff would'nt cut them, the espelir gt look to be 1.8" drop that should be good, about an 1" higher than cut tein's I would bet, I had the evo swifts at 1.6", uncut they were almost perfect height espelir should be close to the same.
I now have evo 2" tein s-tech's on mine, uncut they are pretty low. I bet the cut tein's must suck and ride on the bump stops constantly.
My uncut teins actually seem a little lower than 2" and only have about 2 inches of travel left in front.
Remember the evo stock suspension raise our front about 3/4 an inch and lowers back about 1 inch.
Armitage
Herndon, VA
I use the ASD springs on my Evo8 struts in the front only. Since the stock Evo springs in the back were already stiffer than the front and sit pretty low I left them alone. I can grab a pic later if you want to see what the ride height looks like with this configuration.
Gmoney1983
SLC, UT
That's good news on the swifts. I've got some evo 8 with some hotchkis springs waiting to go on. They seem to have close to the same specs as the swifts. Now if I could just find someone in the slc area to get the rears welded up for me so I can finally install em.
Armitage
Herndon, VA
Quoting PlatypusOfFury:
Yeah, would be nice to see that height and how the rake is on different setups.
Just took this pic. Car is filthy due to snow from last week but you get the idea. I wouldn't want the back any lower than the stock Evo8 springs already make it.
asmo
SLC, Ut
pm sent
Gmoney1983
SLC, UT
Anybody think it would be a bad idea to throw the evo springs on the stock galant struts. Just until I can get the rears welded.
