Need help quick please!
James
Port richey Florida
Can someone tell me what year coolant temp sensor this is?
JNR
ca
[edit - oh, you were looking to see what year it goes to...don't know, but it looks just like the 92]
Looks like the one that goes one top of the housing, since the one that goes on the bottom has one terminal at a 90 deg...however, want to say there is a connector that looks just like that in the radiator (bottom), but could be mistaken.
[edit - I just posted this pic in another thread, but gives a good view of the one I am referring to at the top of the housing]:
James
Port richey Florida
It came out of the top of the thermostat. My question is what year is it from to order a new one??? The 90-94 is different, the one I bought is from a 2g because the prongs look the same, but the plug is different.
James
Port richey Florida
Here's some pics of the setup itself..
JNR
ca
this is for the galant?
According to Rock Auto (the one for galant, which looks just like the pic you posted; you need to get one from a 1G or 89-93 galant, as 2g has diff p/n):
that one on the right of your pic (with the longer probe) does not look right, as you are probably aware now.
James
Port richey Florida
When I went to order the one for a 1g the prongs were different. One prong was up and down, the other was left and right.
This is for my galant, Dsm motor was swapped in.
JNR
ca
You sure it was the correct sensor you went to order? Reason being is a 1G should be same as Galant and your housing looks just like mine, so should be the same (that old sensor you posted is identical). Where are you ordering this from? If a local chain, bring your piece with you, as those guys aren't the brightest stars in the sky and especially on older cars.
Remember the BOTTOM sensor has the two terminals that are in different orientations, as you described, so it's possible you have that sensor and not the one on the top. One is for the A/C, iirc, fwiw...BUT, also that one (bottom) has the terminals exposed and no shroud around them...look at the pic I posted for what I'm talking about.
James
Port richey Florida
Here's pics of the plug side
James
Port richey Florida
Well which one is the "coolant temp sensor" that tells the ECU how much fuel ect depending on the temp?
James
Port richey Florida
Ok so the top sensor is a fan relay? Bottom one is the coolant temp sensor
My fans come on just fine so ill assume even though that top sensor looks best to sh*t my fans still work.
James
Port richey Florida
Well replacing the sensor didn't fix my idle problem. But hey it's one more new part!
Thanks for the quick help.
Near Seattle, Washington
Off topic, but what sort of intercooler setup are you running? That looks like a DSM turbo outlet.
Also, here is why replacing that sensor did not help with your problem...
It's for the A/C.
thermostat housing sensors plugs sensor plug coolant temp sender senders pigtail wire wires
(Keywords for future searches, since it took me a while to find this pic again, and it's been posted repeatedly.)
I thought the vertical switch in the top of the thermostat housing water neck was just a switch to turn on the AC pusher fan when coolant temps get REALLY hot, like around 233F or so. If you turn on the AC, that fan comes on, but if you're coolant starts to overheat, even with the AC off, that switch will turn on that fan as a last resort to cool things down.
James
Port richey Florida
ThE one I replace was number2. On that picture
And when I said the motor was swapped from a Dsm I mean the entire setup, SMIC and all. So yea that's a Dsm outlet Off a 14b
Boos929
Active member
Mass
My radiator fan stopped working recently an I noticed today that the wires are broke coming from the plug ontop of the thermostat this wouldn't cause my fan to stop working ? I don't have Ac in my car
Quoting turbowop:
That's right, as far as i understand.
Quoting James:
I'm confused. You posted a photo of #3, which is A/C related. Yet you state you replaced #2. Did i miss something, or were you asking about two different sensors here?
ktmrider
Tempe, AZ
Quoting turbowop:
No, the vertical sensor ( #3 in pic ) controls the AC compressor clutch, disengages/cuts off the compressor if the coolant temp is too high.
The horizontal sensor facing the firewall, #4 in pic, is the secondary/AC fan sensor.
Oh yeah. that's right.
I wonder what DSMs do. They don't have that other A/C fan switch like we do.
ktmrider
Tempe, AZ
^^ Correct, #4 does is not in the water neck on TEL's. Another reason to only use the top half if a fill cap is needed.
Not sure where the second cooling fan control comes from, maybe the ECU?
