Galant VR-4 Forums » Galant VR-4 » Newbies » Ground off spots for ECU to set BISS in galant GSX
James
Does lots of head
Galant VR-4 org Post #: 1068787 posted 05/26/12 09:06 PM     Remind Me!  Send Private Message   Edit Post
I found the under hood plug to ground... But can't find the under dash plug. It's not next to the fuse box like the turbo models?
1990 Summit White Galant GSX
Chipped EPROM ECU/2g maf/550cc injectors/3in exhaust /E316G/FMIC/Wally255/AeromotiveAFPR/lower shores MBC
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.234.140) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1068827 posted 05/27/12 10:30 AM     Remind Me!  Send Private Message   Edit Post
No help here?
kooter
Member +
148/2000
Galant VR-4 org Post #: 1068899 posted 05/28/12 01:13 PM     Remind Me!  Send Private Message   Edit Post
web page
1991 galant vr4 nile black
JDM Transplant. 16g 510 injecters
102,000 miles
Posts: 255 | From: carpentersville, IL | Member Since: 01/13/11 | IP: (24.13.19.11) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1068904 posted 05/28/12 02:00 PM     Remind Me!  Send Private Message   Edit Post
Thank to for that great page of information.
Sadly I asked for a galant GSX locations. I don't have a 1g eclipse 2g eclipse or a vr4. The plug is not in the normal turbo DSM location. Else I wouldn't be asking.
I think I've been in the DSM world longer than most. And I think I've read over Vfaq well over 500,000 times since its existence.
Edited by James (05/28/12 02:06 PM)
2000GTX
Galant VR-4 org Post #: 1068913 posted 05/28/12 04:41 PM     Remind Me!  Send Private Message   Edit Post
I'm looking for this information as well. Someone has got to know.
-Nick
Proud owner of a '91 Eagle 2000 GTX.
Fun Fact: GTX's are more rare than VR4's
Posts: 129 | From: Milwaukee, WI | Member Since: 01/03/12 | IP: (68.254.161.34) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1068925 posted 05/28/12 07:17 PM     Remind Me!  Send Private Message   Edit Post
then why come to a VR-4 specific forum and complain about not finding non VR-4 info?
I would have thought all that was required is grounding the plug on the firewall and then adjust timing.
Posts: 2132 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (58.87.13.2) | Report this post to a Moderator
James
Does lots of head
Galant VR-4 org Post #: 1068940 posted 05/28/12 09:20 PM     Remind Me!  Send Private Message   Edit Post
The same reason all the other galant GSX members come here. The same reason you have Evo and DSM members. Because we all share a common interest and would hope to help one another.
There are two parts to ground off when correctly setting the BISS in the turbo models. I would assume there is also 2 in the non turbo models since the motor is the same. One is on the passenger side near te fender, one in under the sash usually just right of the fuse box. Mine is not there. I'm to assume the location is different on a galant GSX. Thus me asking, as I'm sure in 23 years someone with a galant GSX has set their BISS correctly.
Galant VR-4 org Post #: 1068964 posted 05/28/12 10:43 PM     Remind Me!  Send Private Message   Edit Post
Are you positive there are two locations you need to ground on a turbo 1G or GVR-4? Of all the times I've set the timing it's been fine grounding the terminal on the firewall only. VFAQ lists for both the 1G turbo and 2.0 engines and only makes mention of the terminal on the firewall - where are you getting your info that two locations need to be grounded? The connector under the dash is the diagnostics port, though the N/A should still have it there present.
VFAQ articles - click and click
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1068965 posted 05/28/12 10:45 PM     Remind Me!  Send Private Message   Edit Post
If you're refering to "Basic Idle Speed Adjustment" and not using a scan tool (which would establish the required ground), you need to connect a meter to the one under the hood and ground the "diagnostic test mode control" terminal in the data link connector (which on my ggsx was right next to the fuse box)...
Edited by holeshotmoe (05/28/12 10:49 PM)
Posts: 1274 | From: MD | Member Since: 04/07/05 | IP: (174.54.95.64) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1068968 posted 05/28/12 11:25 PM     Remind Me!  Send Private Message   Edit Post
Quoting fuel:
When adjusting base timing, only the firewall connector is to be grounded. When adjusting the BISS, both the firewall connector and a pin on the diagnostic port under the dash require grounding.
-Mark
1051
Posts: 11930 | From: Yakima, WA | Member Since: 04/29/01 | IP: (68.185.43.218) | Report this post to a Moderator
Galant VR-4 org Post #: 1068978 posted 05/29/12 12:47 AM     Remind Me!  Send Private Message   Edit Post
Gotcha. Sounds like his diagnostic port has gone AWOL?
James
Does lots of head
Galant VR-4 org Post #: 1068999 posted 05/29/12 09:10 AM     Remind Me!  Send Private Message   Edit Post
I'll look for a third time after work today. But im 99% sure it's not near the fuse box as it should be! Thanks for the real answers
Posts: 1322 | From: Port richey Florida | Member Since: 04/08/12 | IP: (198.228.235.229) | Report this post to a Moderator
tightywhitee
Galant VR-4 org Post #: 1069020 posted 05/29/12 11:41 AM     Remind Me!  Send Private Message   Edit Post
Mine stock,was covered with a black plug cap. Making it hard to see. But it was there.
Edited by tightywhitee (05/29/12 11:42 AM)
| | | IP: (24.17.24.115) | Report this post to a Moderator
Generated in 0.059 seconds in which 0.027 seconds were spent on a total of 14 queries. Turbo powered.
