Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Water pump problem?
Water pump problem?
Galant VR-4 org Post #: 1049538 posted 02/02/12 10:51 AM     Remind Me!  Send Private Message   Edit Post
OK, I rebuilt the engine in 828/1k in 2010, has about 9000 on it now. This last weekend I noticed some coolant drips under the car (though I had never smelled it before that) in a weird place, driver's side not near any hoses or connections. Coolant was low, so I topped it up. The next day, I smell it after driving. I can see a small drip on the bottom of the timing cover. It was a pump from Parts Dinosaur. I plan to take the top belt cover off the weekend in the light and what is visible. It's the only place I can see it may be coming from. I am ticked off, as I hate this job in the car (in the midwest, in the cold, etc.).
Anyone with other thoughts as to source?
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10688 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.228) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1049539 posted 02/02/12 11:03 AM     Remind Me!  Send Private Message   Edit Post
Only other hoses I know about on that side of the car are the two hoses going to and from the oil cooler. When my bottom one went, my car pee'ed. No little drips.
1992 Nile black w/sunroof
Posts: 5867 | From: central Indiana | Member Since: 08/06/02 | IP: (68.58.11.188) | Report this post to a Moderator
Vman911
Member +
1667/2000
Galant VR-4 org Post #: 1049549 posted 02/02/12 11:55 AM     Remind Me!  Send Private Message   Edit Post
did you put some RTV around the water pipe where it goes into the WP?
Posts: 358 | From: Douglas county, Ga | Member Since: 09/18/05 | IP: (75.150.10.29) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 1049553 posted 02/02/12 12:10 PM     Remind Me!  Send Private Message   Edit Post
I would try to look at the weep hole on the water pump. Mitsuturbo says you can see the weep holes with a mirror and a flashlight.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (160.84.254.241) | Report this post to a Moderator
Wizardawd
598/1000
Galant VR-4 org Post #: 1049558 posted 02/02/12 12:48 PM     Remind Me!  Send Private Message   Edit Post
^^ that. That will tell you at least if the seal is bad in the pump. It could also be the water pipe-pump oring (doubtful since it didn't leak at the beginning), 1 or 2 of the water pump bolts go thru into the coolant jackets in the block and coolant can slip past the threads (again, should've leaked at the start), oil cooler lines (if you still have a 91+ cooler), head gasket (not a usual spot to leak) and water pump gasket. Given the fact it just started, i'm going with the pump going bad prematurely.
The leak (if out of the weep hole) typically only leaks once the car is warm and has been shutoff.
Wiz
598/1000 Nile Black
12/2000 Nile Black
1995 Montero SR
1997 Talon Tsi AWD Auto
Posts: 1315 | From: Aberdeen, SD | Member Since: 08/08/07 | IP: (24.220.212.212) | Report this post to a Moderator
grocery_getter
Senior Crab
836/2000
Galant VR-4 org Post #: 1049572 posted 02/02/12 01:48 PM     Remind Me!  Send Private Message   Edit Post
Over the years I've seen leak from where the water pump mounts to the block. In the old days when we all have perfectly smooth surface on the block, you can depend on the gasket to seal the water pump housing to the block surface. Nowadays I work with some blocks that show some pitting on the block surface where the water pump mounts. Because of that pitting, gasket alone is not enough to seal. I always put very thin layer of rtv on both side of the water pump gasket to help seal the waterpump to the block.
You can see the weep holes (2 of them) externally without even using any tools except maybe a strong flashlight. Look for tell tale coolant sign. If nothing is visible externally from any hose or connection points, then you might have a gasket that finally gets bad enough from coolant seeping thru the surface pits of the block and leaks.
That one you can only see after you pull the timing belt cover unfortunately.
Andre
836/2000
PINA MOTORSPORTS
Facebook page
Edited by grocery_getter (02/02/12 01:53 PM)
Posts: 1225 | From: Kent - industrial suburbs of S... | Member Since: 06/20/04 | IP: (76.121.219.143) | Report this post to a Moderator
Galant VR-4 org Post #: 1049648 posted 02/02/12 08:29 PM     Remind Me!  Send Private Message   Edit Post
Excellent info, all. I will try and get it checked out tomorrow during our unseasonable warm spell here.
Posts: 10688 | From: Michigan | Member Since: 03/05/01 | IP: (50.45.66.209) | Report this post to a Moderator
Galant VR-4 org Post #: 1049858 posted 02/03/12 09:28 PM     Remind Me!  Send Private Message   Edit Post
Nothing evident from the weep hole on top, or the pipe to pump connection. I couldn't seem to see another weep hole on the pump. I will have to look some more later, as I had a couple other things going this pm as well. Only place I see fluid on the engine is at the bottom of the timing cover, so it looks like I will have to go in there.
grocery_getter
Senior Crab
836/2000
Galant VR-4 org Post #: 1049865 posted 02/03/12 10:45 PM     Remind Me!  Send Private Message   Edit Post
if you look at the water pump, the second weep hole is at 7-8 o'clock position.
Andre
836/2000
PINA MOTORSPORTS
Facebook page
thedsmguy
Galant VR-4 org Post #: 1050203 posted 02/06/12 01:23 AM     Remind Me!  Send Private Message   Edit Post
I just did my WP along with Gates racing belts and 272 cams. Damn lower weep was leaking on mine.
Posts: 1785 | From: Vancouver Washington | Member Since: 03/20/09 | IP: (24.20.91.222) | Report this post to a Moderator
Galant VR-4 org Post #: 1052463 posted 02/19/12 03:13 PM     Remind Me!  Send Private Message   Edit Post
I may have found the likely problem this weekend. The bolt that holds the alternator bracket and goes through the waterpump seems to be broken. Head spins freely. No idea why that has happened. Looks like I will be doing some teardown.
Posts: 10688 | From: Michigan | Member Since: 03/05/01 | IP: (50.45.67.87) | Report this post to a Moderator
2 registered and 7 anonymous users are browsing this forum.
Generated in 0.113 seconds in which 0.081 seconds were spent on a total of 14 queries. Turbo powered.
