Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Trunk Cable not opening trunk
blkchr91
Galant VR-4 org Post #: 1033844 posted 11/15/11 05:03 PM     Remind Me!  Send Private Message   Edit Post
It just started one day. I can see that the red plastic bit that goes to the rear latch is broken, so I held it in place and had a helper pull. The cable still doesn't pull quite enough to open the trunk.
Seems like a simple but annoying problem.
Ideas?
| | | IP: (71.63.54.204) | Report this post to a Moderator
SouthCaliVR4
Gas Analyzer
825/2000
Galant VR-4 org Post #: 1033845 posted 11/15/11 05:26 PM     Remind Me!  Send Private Message   Edit Post
On mine the cable got stretched & needs to be replaced. check that it's still mounted to the clips on the hinge & the retention clips that run under the back seat.
How do you make a small fortune racing? Start with a very large one!!!
Posts: 984 | From: North county San Diego | Member Since: 07/31/10 | IP: (99.43.5.60) | Report this post to a Moderator
omertaitalia
Member +
435/2000
Galant VR-4 org Post #: 1033890 posted 11/15/11 08:09 PM     Remind Me!  Send Private Message   Edit Post
so you dont know why its not working still?, sounds like a future junk yard trip to me.
#616-1000-sold
#435-2000
1992 Mistubishi Expo AWD 7 pass. van (4g63 swapped)
2010 Ducati 848
Posts: 410 | From: Downtown Los Angeles CA/Lake T... | Member Since: 05/07/09 | IP: (24.205.97.181) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1033901 posted 11/15/11 08:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting SouthCaliVR4:
I guess I'll check all that stuff out...thanks.
blkchr91
Galant VR-4 org Post #: 1033902 posted 11/15/11 08:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting omertaitalia:
No idea, no Galants of these years appear in junk yards here even the big ones.
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1033937 posted 11/15/11 11:12 PM     Remind Me!  Send Private Message   Edit Post
On my car I know the lever is just weak and pulling bends the lever rather then pulling the cable.
Ryan W.
Posts: 454 | From: Granby, MA | Member Since: 09/27/06 | IP: (71.192.214.54) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 1033950 posted 11/16/11 12:40 AM     Remind Me!  Send Private Message   Edit Post
Take the cable off in the back and crimp on a steel or aluminum cable clamp piece available at any hardware store or just put a zip tie on it to take up the slack. Fixed without having to tread the cable from under the carpet etc.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (8.27.208.108) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1034037 posted 11/16/11 01:52 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the thoughts...tie wrap sounds good to me even if diagnostic.
| | | IP: (130.16.210.10) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1034070 posted 11/16/11 03:04 PM     Remind Me!  Send Private Message   Edit Post
I think I tied a knot in mine to take up some extra slack. If I recall...it's been awhile.
-Mark
1051
Posts: 11959 | From: Yakima, WA | Member Since: 04/29/01 | IP: (74.82.64.160) | Report this post to a Moderator
blkchr91
Galant VR-4 org Post #: 1035233 posted 11/21/11 10:24 AM     Remind Me!  Send Private Message   Edit Post
Appreciated
blkchr91
Galant VR-4 org Post #: 1035594 posted 11/23/11 07:50 AM     Remind Me!  Send Private Message   Edit Post
Tie wrap worked ok FYI...
| | | IP: (140.185.55.87) | Report this post to a Moderator
Generated in 0.164 seconds in which 0.151 seconds were spent on a total of 14 queries. Turbo powered.
