Reassembly Wiring Issues...Advice Sought
Chad989of2000
Livermore, CA
I've been working at this project for some time now and finally getting near the finish line. I'm just having some issues with wiring after putting the engine/trany back in. Here are some of the issues with supporting pics.
Here is a random green wire that I can not for the life of me find out where it goes. It branches off the wiring group that connect to the t-stat housing.
Here is a wire that branches from the alternator wire group. Yet again have no idea where it connects.
Yet another wire from the alternator wire group. This one has a connector (small), just not seeing where it goes.
This is the connector along the o2 sensor wire. The black wire has come free of the connector. I'm just wondering what the best way to repair this is...I'm leaning towards solder.
I also cannot find where the nut that goes on top of the power steering pump is. Anyone have a reference pic I can see?
Like I said, after these final issues are resolved I will be good to go to get this baby up and running again. I would greatly appreciate any input on any of these issues. Thanks in advance guys.
omertaitalia
Downtown Los Angeles CA/Lake Tahoe,CA
i just had the same problem with the o2 plug, went to the junk yard and cut another one and bought a solder gun, have yet to do it but im sure this is the best option, id like to get a nice wrap for the wires so it doesnt happen again.
broxma
San Antonio Tx
If the wire on the harness is a silver wire you have to use a butt connector. I know that on the O2 sensor itself you do or have it silver soldered. I think the harness side may just be shielded copper however.
/brox
Toronto, ON, Canada
Quoting Chad989of2000:
Power steering pump, it grounds that wire when the pressure is high (ie on full steering lock) which tells the ECU to increase the idle speed
Oil pressure sensor
Chad989of2000
Livermore, CA
^^^Fuel...So with that first wire...I just need to attach a connector and find a suitable ground for it? And I'll look at the oil pressure sensor sandwich piece to find where that plug goes. Also thanks for the wire id. With the o2 sensor connector, can we use any 4G63T model's? Or do the non-turbo 4G63s have the same setup, also how much did the connector cost? Thanks guys.
Toronto, ON, Canada
on the power steering pump on the side nearing the radiator there will be a pin sticking out which that single wire slips over. Basically the switch inside the pump just grounds that pin when the pressure is high. To be honest it's not even vital to have it plugged in.
Oil pressure sensor is on the oil filter housing near where the oil cooler lines attach to it, or if your model has the water cooled filter housing then it will be near the blanking plugs on the chassis rail side of the engine.
Unsure about the O2 sensor wiring - my VR-4 had a 2 wire O2 sensor rather than a heated 4 wire. I would say just find another Mitsu in a junk yard with the same plug/socket and pull it or just go to an electronics store and buy a generic 4 pin plug/socket set and re-wire it.
omertaitalia
Quoting broxma:
/brox
what?, the o2 sensor is copper wire what are you saying
