Galant VR-4 Forums » Galant VR-4 » Newbies » Idle hunting
Idle hunting
NickDromez
485/1000
Galant VR-4 org Post #: 1016864 posted 09/08/11 05:15 PM     Remind Me!  Send Private Message   Edit Post
so basically my car hunts for an idle. i turn my car on and idles ok, 1 minute of warming up passes and it hunts. goes to 1500rpm then down to 500rpm. 1 minute of this passes and it stops. idk what it is, i think maybe it could be the IAC or my MAF. I would rather not do an FIAV or EGR delete to get to work. any help would be appreciated. thanks
#485/1000
RIP 1998 VW Passat
AWD > RR > FR
"V-tech wins 1/4 time, everytime."
Posts: 165 | From: Berkeley, CA | Member Since: 07/02/10 | IP: (71.135.45.237) | Report this post to a Moderator
Diego
Mad Hatter Suite Touche Debackle Guage filled by Justin
1309/2000
Galant VR-4 org Post #: 1016874 posted 09/08/11 05:48 PM     Remind Me!  Send Private Message   Edit Post
That is what they call the " hall effect" click
Switch from the Green top CAS to a Black top and call it a day.
"I love blackjack. But I'm not addicted to gambling. I'm addicted to sitting in a semi circle."
91 nile black vr4, 1309/2000
Posts: 2132 | From: In a van down by the river, Io... | Member Since: 12/09/07 | IP: (76.25.120.127) | Report this post to a Moderator
MitsuDriver274
Member +
Galant VR-4 org Post #: 1016884 posted 09/08/11 06:26 PM     Remind Me!  Send Private Message   Edit Post
Adjust your idle properly, that includes grounding the timing terminal and then adjusting the idle airscrew until the car idles around 950 rpm, I believe you do it with the lights and a/c on. Most of the time I come across cars that hunt for idle have a bad iac motor or the idle air screw has been adjusted without grounding out the timing terminal.
I'm sure this had been covered, search before posting a new thread!
"Its not turbo lag, its foreplay" ~Michael Rodzinski
WWU Student, Major: Vehicle Design
2003 Evolution 8 #274 <= Sold to Seamus Burke
Posts: 319 | From: Bellingham, WA | Member Since: 01/20/04 | IP: (174.253.219.83) | Report this post to a Moderator
Andy_S
Overcomplicated
Galant VR-4 org Post #: 1016892 posted 09/08/11 06:31 PM     Remind Me!  Send Private Message   Edit Post
Quoting Diego:
I'm not sure I understand your suggestion. I feel his problem is unrelated to if the cas is optical or hall effect.
I found v8's...
Posts: 982 | From: Shithole Wisconsin | Member Since: 01/30/07 | IP: (174.253.6.69) | Report this post to a Moderator
Alainb7
Galant VR-4 org Post #: 1017010 posted 09/09/11 06:17 AM     Remind Me!  Send Private Message   Edit Post
The best way to adjust your idle is first to adjust the Biss srew to have the ISCPosition value logged in DSMLink/ECMLink hovers around 30 at normal warm-engine idle in neutral.
But you have to be shure that your ISC is working properly. (Check resistance of the 3 coil) and be shure you dont have any leak.
Most of the time idle problem result as a efective ISC.
92 Mitsubishi Galant VR-4,4g63 A/T AWD turbo [email protected] mph, 0-60 mph:3.40s, 50-75 mph:2.3s
Gone in 11 seconds GO FAST WITH CLASS, DON'T USE NOS!
Posts: 60 | From: Montreal, Quebec, Canada | Member Since: 03/24/11 | IP: (206.47.215.246) | Report this post to a Moderator
Xcelerate
Galant VR-4 org Post #: 1017036 posted 09/09/11 10:54 AM     Remind Me!  Send Private Message   Edit Post
First lets find out what set up you have first? If your injectors are not calibrated properly then no matter what you do you will always fight the ecu from controlling your idle. Aftermarket cams will screw up your idle as well. You wanna make this simple? Bypassed your IAC with a block off and adjust your idle manually till it settle. The only problem is cold start but once it warm up your idle will be stable. And don't mess with the biss screw, close it all the way down and just adjust it by the Idle control sensor or whatever you call that one wire sensor that stops your throttle plate:)
Posts: 43 | From: North jersey | Member Since: 06/17/11 | IP: (173.70.20.253) | Report this post to a Moderator
NickDromez
485/1000
Galant VR-4 org Post #: 1017103 posted 09/09/11 05:32 PM     Remind Me!  Send Private Message   Edit Post
engine and ecu are all stock except for a hallman boost controller. so i guess ill try to mess with the IAC. and im pretty sure its not a CAS problem as its stock and ive never heard of a CAS effecting idle hunt
#485/1000
RIP 1998 VW Passat
AWD > RR > FR
NickDromez
485/1000
Galant VR-4 org Post #: 1017105 posted 09/09/11 05:34 PM     Remind Me!  Send Private Message   Edit Post
Quoting MitsuDriver274:
where is the idle air screw and how do i ground the timing terminal?
#485/1000
RIP 1998 VW Passat
AWD > RR > FR
1uGlyGalaNt
im a troller on a budget
Galant VR-4 org Post #: 1017136 posted 09/09/11 07:56 PM     Remind Me!  Send Private Message   Edit Post
The idle screw is on top of the throttle body. It's underneath a black plug, if you still have the plug installed. RTFM or google for the timing terminal. You check for vacuum leaks yet?
Old electrical engineers don't die, they just light the way. RIP Chester Quantz, 1926-2009.
Posts: 2558 | From: Plano, TX | Member Since: 06/16/04 | IP: (70.253.230.103) | Report this post to a Moderator
tayschells13
Galant VR-4 org Post #: 1017609 posted 09/11/11 10:09 PM     Remind Me!  Send Private Message   Edit Post
You can ground it by checking a box on dsmlink or else here's a somewhat decent article I found on which plug you need to find to ground your timing.
Click
This might help you out, if not then oh well.. I tried lol
Posts: 54 | | Member Since: 01/31/10 | IP: (68.117.21.69) | Report this post to a Moderator
tayschells13
Galant VR-4 org Post #: 1017610 posted 09/11/11 10:12 PM     Remind Me!  Send Private Message   Edit Post
But make sure all your boost leaks are fixed, tps is adjusted correctly, and let the car warm up to operating temperature before you set it
NickDromez
485/1000
Galant VR-4 org Post #: 1017834 posted 09/12/11 07:21 PM     Remind Me!  Send Private Message   Edit Post
turned out to be my knock sensor, TPS, and idle screw. problem resolved
#485/1000
RIP 1998 VW Passat
AWD > RR > FR
Posts: 165 | From: Berkeley, CA | Member Since: 07/02/10 | IP: (71.135.48.232) | Report this post to a Moderator
1 registered and 14 anonymous users are browsing this forum.
Generated in 0.104 seconds in which 0.079 seconds were spent on a total of 14 queries. Turbo powered.
