MAF comp on link. and running lean at WOT
yeti
san diego california
So I was told I have to adjust the sliders on the maf comp. To use a 2g maf on dsmlink .. I thought all you had to do was check 2g dsm for the maf your using.
Anyways there was no difference in install when I swapped from my working 1 g maf.( all I did was click on 2gmaf and no CEL the car ran fine)
And also how would I richen or lean out the system on link? Using the global fuel adj.? Or the sliders maybe.
I'm just trying to get a idea of how to tune.
(And my idle was at 11.0 now its usally at 13.6-14.5 it just happened out of no where I'm gonna go on link and read some more of their very usefull wiki.
I'm just posting questions to see if anyone can some it up for me
Cause when I read all the wiki's I usually forget the begining.
yeti
I already have the injectors dialed in. Correctly I'm just wondering how you would go about leaning or richening the system do I use the fuel trim?
Dark_Horse
Morrison, CO
Fuel trims and/or MAF Comp values depending on what your log files show.
Are you at around 0.26gm/rev in your logs?
What does your combined FT look like at idle? Combined FT should be very close to 0.
As long as you're around 0.26gm/rev and combined FT is close to 0, you're probably good to start driving the car around to get a cruise log.
yeti
My combined FT is at 0 constantly, I'll check if I'm at or around 0.26gm/rev.
I'm locked in open. Loop because my wb won't simulate the NBo2.
And I really appreciate your info now I'm grasping the concept..
Dark_Horse
Morrison, CO
IIRC, combined FT doesn't work in open loop...Only closed loop.
Watch the DSMlink vids that Thomas/Dave posted. Those will get you started.
AnotherNewb
Orlando, FL
I thought you said there was no way you were going to tune this yourself? Where is your dude that knows how to tune?
Not trying to discourage you but it doesn't sound like you full grasp the concept of link yet. Personally I would suggest you go to The ecmlink forums and post your questions up there. I know tinkering with the values is fun... blowing your engine up is not most of the time.
yeti
^Very much agreed I'm trying to learn the basics and have NOt touched anything yet.
I'm going to do the. Maf comp 1st and see where I go from there.
And my tuner is rebuilding my friends gsx so he's a bit busy.
