1st time at the drag strip need advice
yeti
san diego california
Ok so the galant probly hasn't raced in over a year so what should I replace and lookover before going to the track
Any leaks, tire pressure, might wanna try to run your empty so u can add race gas for the track then turn up the boost a lil more. My 2 cents..
Brunoboy
San Bruno,CA Home of SFO
all maintenance...... make sure your car isnt leaking or anything, boost leak check, tire pressure ect..
boostedinaz
Scottsdale, AZ
Have you fixed an of your previous issues? If not then fix those first.
yeti
im replacing whats left to do as soon as my afpr and fuel pump get here.
my only other leak is from injector seal and BISS screw.
(everything else i know is fine)
and should i go get new differential fluid and new gear oil?
Unless they are passed due or empty, than no
RedTwo
New Zealand
Check the accelerator initiation device. Ensure the base plate fully extends and connects the pedal with the floor /ubbthreads/images/graemlins/grin.gif
cheekychimp
East Sussex, U.K.
Yeah ... I actually don't do that anymore, I think there is something wrong with my car. The closer that pedal gets to the carpet the more the cabin gets filled with a noxious odour ... and screams, lots of screams!
yeti
should probably clean the HAIR OUT OF MY TURBO, /ubbthreads/images/graemlins/tongue.gif you know like a vacuum??!?!?!?!?!?!?!?! /ubbthreads/images/graemlins/tongue.gif
