oil filter mount
you can also choose one that is 3/4-16 thread, which will use a ford style filter. I started my car life in chevys, so thats what Ive always used. Plus it allows me to keep a bunch of WIX 51060 filters on hand to use in both my big block truck and my other hot rods instead of having to keep a bunch of different filters around.
for hose and fittings, I use this stuff:
hose
and use these fittings:
fittings
it is extremely high quality. If you decide to use that hose, DO NOT USE NORMAL BARB FITTINGS. I learned this the hard way. Even with hose clamps i pushed lines off the barbs while driving around. You absolutely must use the fittings designed for the hose and do not use hose clamps on it. When assembled correctly, you will have to cut the hose to get the fittings off.
Those pictures above are from my old galant. I just got another one and will be putting most of that stuff on it today. Ill try to take pictures of how it ends up and ill post them up here. I will be doing it a little bit different this time, with better fittings.
