spark plug question (picutures)
yeti
san diego california
this is carbon deposit?
ALSO Any recommendations on good spark plugs or whatever the guy at Kragen says
the ones in the picture are NGK
524of1000
San Antonio, Tx
NGK bpres7 gapped @ 0.027-0.028 are the prefferd plug of choice around here.
Brunoboy
San Bruno,CA Home of SFO
Start with Bpr7es gapped at .028.
steve
NJ
^ This.
yeti
the the bpr7es gapped at 0.028
took it for a spin around the blocks a few times got it to operating temp.
it felt really rough at first then towards the end started to feel a little bit better
THEN MY BATTERY DIED so back to the alternator?>
anyways back to the thread i took one of the plugs out after i got back from a test drive
^THAT'S THE BRAND NEW PLUG^
is that NORMAL AFTER A FEW TIMES AROUND THE BLOCK??
any input is appreciated
(still sputtering and hitting full boost at 4000rpm)
Looks a little lean.
yeti
What are the causes of this.
And anything I could do to fix?
+book says its carbon deposit and is cause of rich mixture or pre-ignition
14u2nV
Agency/St. Joe, MO
Fix your charging problem before you mess with anything else. trying to diagnose 5 things at once is pointless.
Agreed, a low battery will cause high RPM stumbling.
Had the same issues when I had a small battery. Got a full sized battery and fixed it instantly.
After fixing your battery issue if it still sputters under boost recheck
the gap on the plugs depending on how much boost you are running you may
have to close the gap down even more on the spark plugs......
Adorsey
mass
You made sure the battery was charged before you put it in right?
You dont want that new alt. doing all the work, itll just wear it out/possibly go bad.
Yeah if the voltage is low it can cause that fuel pump to not have enough juice on the top end. That being said it doesn't look *that* lean to me. The flash on the camera may make it look more white than it is. The first pics look gray like what you want. Doesn't look like its too far off.
yeti
battery was recharged before i put it in
its getting recharged now i am going to drive up and pick that one up and check the alternator at autozone
Rausch
Cleveland, OH
7's are one heat range colder.
NYC86ZC
Long Island, NY
Is your engine blowing black smoke when you get on it? Those plugs are showing you're running quite rich.
