Check the clutch pedal. there is a switch (plunger, press type) the clutch pedal lever presses in. Maybe its disconnected or disabled.
edit again...
My 3000gt starts without a clutch because it has remote start. If you have remote start then that is why.
edit yet again...
The galant plastic nipple that presses this clutch switch in from the level can become old, fall off, whatever.
I use a large zip thigh to replace this (just zip one in there and cut off the remainder. Why they didnt make a medal one or just kept the hole filled is beyond me.
Maybe this is what happened and the past owner disabled the switch. You cant drag race without a clutch safety switch, so keep that in mind.
You will understand what im talking about once you inspect your clutch pedal. If you dont see a white plastic part that could press the clutch switch, then its missing. Then you will only see a hole where something should go to press the clutch sensor in.
hell, maybe your switch is even missing.
