Power folding mirrors - somethings wrong here.
So i picked up a power folding mirror kit. and i am going over the wiring diagrams generously provided by misterfixit. i understand the mirrors and the switch. but i was sitting here for an hour scratching my head like "wtf is this crap!". so i pulled up a picture from tunersnation.com... oh well thats just not right. the relay they sent me is "MB852142" marked with X6T34171, 2X15. the wiring is:
1234
5678
1 = BrL
2 = BrW
3 = blank
4 = blank
5 = L
6 = Br
7 = B
8 = BrB
so... did the guy send me the wrong relay? or is this a older unit? the plug doesnt even match. mine is square with 8 and misterfixit diagram is a rectangle with 13. /ubbthreads/images/graemlins/dunno.gif
misterfixit relay diagram is
1 2 3 X 4 5 6
7 8 9 10 11 12 13
1 = Lg
2 = Br
3 = LgR
4 = BrB
5 = LW
6 = BrL
7 = B
8 = blank i think
9 = BrR
10 = LgB
11 = BrY
12 = LgY
13 = BrW
thanks for whatever help you guys can provide.
progress...
part number: MB852142
Pin out:
1234
5678
1 = BrL to control switch
2 = BrW to control switch
3 = blank
4 = blank
5 = L +12v
6 = Br to mirror
7 = B ground
8 = BrB to mirror
still trying to figure out the Mirror side - Left: Lg, LgB and Right: LgY, LgR. they go into the diagrams relay below and come out as BrL and BrW.
diagrams: https://www.galantvr4.org/ubbthreads/showflat.php?Cat=&Board=UBB3&Number=390258&Forum=c2&Words=relay&Searchpage=0&Limit=25&Main=388496&Search=true&where=bodysub&Name=1761&daterange=1&newerval=&newertype=&olderval=&oldertype=&bodyprev=#Post390258
nickbuilt
queens, ny
would anyone know what each wire is for on the harness connector on the jdm mirror switch i am also stumped with this i have mine set to a regular switch and normal automotive 5 wire relays i would love to find out how to make my oem switches work!
-nick
Nick,
if you have the same kit/set as seen on my tunnernation link above then the setup/wire colors/diagram is easy to follow. i am no electrician, obviously but i used the DSM electrical manual to help me read these diagrams:
if you're just wonder which wire does what then you want to focus on "BrL (#2 on the plug), BrW (#1 on the plug) and LB (#10 on the plug)" #10 is ACC and the other two are the monetary connections to trigger your relay. "L" stands for Blue.
hope this helps. i am going to keep my eye out for a relay, meanwhile i'll setup my mirrors with dual relays utilizing the stock switch.
steve
NJ
tunersnation is run by our very own Garfield Wright, you might try to PM him. click
