What would cause this to ecu
OMFGeofffff
Burnsville, MN
Should I be worried if I replace the ecu that it's gonna happen right away?
belize1334
Bozeman, MT
Someone will likely correct me but I believe those are the ISC drivers. A faulty ISC will fry them and it'll do it again to the next one. Replace the ISC motor (or block it off) before you replace the ECU.
OMFGeofffff
Burnsville, MN
Also can I use a 1g ecu? I think I noticed that the cases are slightly different? Can I just switch it between cases or is that a big no-no?
Yes, ISC shorted out causing a blown driver.
Yes, 1G ECUs are the same but have a different eprom chip, but it will run as long as it is for a 5speed. Auto ECUs are programmed for smaller injectors.
If you get a 1G ECU and want to be completely correct, Send the blown ECU and the new 1G ECU to me and I will recap, clean, and socket the new ECU and then pull the chip out of the GVR4 unit and slide it into the new socketed 1G.
And then if you ever want to do a Keydiver chip or DSM Link, your all set.
BTW - Sometimes a blown ECU can be fixed. If I can repair it, it would cost you $20 for labor/cleaning and $5 each for drivers. PM me if you want more info.
OMFGeofffff
Burnsville, MN
What would cause it to short out? I bought the isc a few months ago from autozone with warranty(maybe not the best idea?)
1 of the 4 coils inside an ISC shorts out or a shorted wire from ECU to ISC.
OMFGeofffff
Burnsville, MN
Ok. PM sent and I'll check out the isc and wiring.
holeshotmoe
MD
The chip might have already been cooked by your old ISC. The new ISC is probably fine. I replaced mine and then found the smoked driver later when I was checking the caps for leaks. There's a simple procedure to check it ISC CHECK
OMFGeofffff
Burnsville, MN
Will I be ok throwing in a 1g non-eprom ecu while the original is getting repaired?
Yes, as long as the ISC checks out OK. If it is from an Automatic car, just drive it easy, the injectors will be mapped for 390 injectors instead of 450s.
Wizardawd
Franklin, NC
No need to drive it easy...the AT ECU actually adds a touch too much fuel. But, it actually works out fairly close as the 1g AT 390cc were run at like 43psi and the 450cc 1g MT were at 32psi.
Wiz
OMFGeofffff
Burnsville, MN
Threw in the 1g ecu. Doesn't start. The fuel pump won't kick on until after I get done cranking the engine. No matter how long I crank. My old ecu works but obviously the idle is eff'd.
ktmrider
Tempe, AZ
Why won't the 1g ecu work?
click - Maybe from a 90 and/or needs the wire swap as per link
stevep
St. Charles, IL USA
There is no difference on a 90 ECU that would cause issue with activating the fuel pump. It's likely the other ECU is also damaged.
I just noticed that both ISC drivers are blown on the original. IC105 went big time but IC107 is also blown.
OMFGeofffff
Burnsville, MN
Yea I gotta figure out what I want to do. Get my original sent off and wait it out. Or just buy a known working ecu and get it socketed/chipped. Sending mine will probably be cheaper eh?
A spare is not a bad idea if this is a DD.
OMFGeofffff
Burnsville, MN
I just bought an auto eprom ecu. Terry can I send my ecu's to you to switch out my old chip into the automatic? The auto is already socketed but my original isn't. If anyone knows who else can do this for let me know. Terry I'm sending you a PM too if you don't look at this.
I can swap things around for you.
