Can not build boost past 10.6 psi
I am running a GM 3" MAS with a translator box and 780cc injectors the orignal promblem fuel would cut out between 15 and 17 psi I had a stage 3 chip made to correct this problem but now I can only get 10.6 psi before the car cuts out acting like a rev limiter, Fuel ratio goes between 12.1 to 13.4 but does not cut off. Changing the settings in the translator box does not help does anyone have a clue what causes this, I am going to recheck the timing and change the plugs other than that the car is useless other a slow sunday drive.
belize1334
Bozeman, MT
If you have it chipped I would guess that the fuel cut code is no longer present so it shouldn't be an airflow thing.
Check your timing. I once messed up my timing changing my tb (had to remove that bracket between IM and CAS) and I didn't realize it. The car wouldn't build more than 8 psi before it started bucking. Turns out that I was running like -10 base timing and the spark was just blowing out when the boost got high. I reset the timing and all was well.
Jesh
Soldotna, Alaska
the CAS does it matter what angle its at or will the ECU automatically know?
Yes it matters. The angle of the CAS is used to set your timing. It should be at 5 BTDC at idle. Check VFAQ if you need more info as it has a nice writeup.
